#4019 | |
BoostedBRZ
Drives: Turbo BRZ
#4020 |
Drives: Scion FRS. Silver with black badges
Thanks pgrandberg11
#4021 |
Stuck In a Sandbox
Drives: FRS RS1.0
I had no idea Kraftwerks provided a BOV for this kit. Does anyone on here run it? would you recommend it?
#4022 |
BoostedBRZ
Drives: Turbo BRZ
If you are talking about the one that is provided with the kit, yes you would need to run it. It dissolves boost pressure when you are street driving and not on WOT. The bypass valve will shut close when at WOT to allow the psi to climb. If you didn't have this installed, you would have a huge hole in your hot side intercooler piping and you would never be able to build boost as all the pressure would shoot out the hole from the rubber molded hose. You can run this recirc or vent to atmosphere.
#4023 | |
Stuck In a Sandbox
Drives: FRS RS1.0
I was referring to the one that was shown on 86speeds website. I saw the Kraftwerks one and a Turbosmart one. I just assumed they were upgrades or different sounding BOVs. |
#4024 | |
BoostedBRZ
Drives: Turbo BRZ
http://www.86speed.com/performance/k...blowoff-valve/ http://www.86speed.com/new-products/...blowoff-valve/ (this one comes with the kit) I don't think I'd recommend the large BOV since it states that it should be used in applications with 18+ psi. If you're not running enough boost, you'll never be able to completely close the valve. I'd just stick the standard one. The standard one is actually pretty loud in my opinion especially if you let off after hitting redline...
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Super Dave (01-30-2017) |
#4025 | |
Stuck In a Sandbox
Drives: FRS RS1.0
ahhhh ok. I was under the impression that the "standerd one" you linked didn't already come with the kit. Im waiting for my setup to come in the mail this week which is why I wasn't sure. You tha man for answering so many questions here! |
#4026 |
BoostedBRZ
Drives: Turbo BRZ
sweet! enjoy the boost once you get it all set up!
#4027 |
Drives: '13 Sport Tech
I just wanted to give a shout out and huge thanks to CJ @KraftWerks
As I was looking to purchase a car with an SC in it, he was extremely helpful answering all of my questions, and went above and beyond in helping us sort a few things out in an unbelievably tight timeline. I don't expect companies to provide this level of customer service anymore. Well done! I'm really hoping they release a DIY video regarding belt tension, seems like it would alleviate a lot of the stress around this system. |
| The Following User Says Thank You to tawheed For This Useful Post: | bfrank1972 (01-31-2017) |
#4028 |
Drives: 2014 Red Subaru BRZ
It really doesn't get any simpler than this explanation from pgranberg11.
"Use the half belt twist method. There's a little cutout on the bottom of your supercharger plate that you can't fit your thumb through. Try grabbing the SC belt and twist it half way. With your right hand, put your thumb on first and put your pointer finger on the back of the belt push up on your thumb and pull down with your pointer finger until the belt twists half way." The stress regarding this system will be there for a while until more owners testify to having no problems than when the system first came out. I was hesitant to purchase this system, too, but the price and how "clean"/ OEM the setup looks won me over. We'll see how reliable this kit is in the long run. I did purchase a spare belt just in case. The other SC I considered for this was the Cosworth kit, but I didn't want to spend that kind of money since I have my car getting a V8 swap. Two car projects running simultaneously puts a hurting on the budget. |
| The Following User Says Thank You to Helios For This Useful Post: | pgranberg11 (02-06-2017) |
#4029 |
Drives: Subaru BRZ DGM
Just bought this kit!! Coming in by the end of this week and installing next Monday. So excited! Any tips on installing the oil reservoir?
#4030 | |
BoostedBRZ
Drives: Turbo BRZ
https://www.mrosupply.com/synchronou..._gates-rubber/ In regards to stress, I believe people tend to make it a lot more worse than it really easy. Honestly, the biggest pain in the ass with this kit was figuring out the belt and the oil cooler setup up (if you plan on tracking, not necessary if you don't). But once you figure out the belt, the kit is nice to drive.
#4031 | |
BoostedBRZ
Drives: Turbo BRZ
good luck and enjoy the boost!
#4032 |
Sounds good. Going to install at my shop with the mechanic I work with. But for the placement of the reservoir where did people install them? Ive seen people with it in the front in the middle by the bumper. Any reason why it would benefit from being located there instead of being by the battery?
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
