Old 02-06-2017, 01:05 PM   #29
It isn't a "problem". Those that think it doesn't move just aren't seeing it. It is not a fixed part of the structure of the car and is going to move.
Thanks but no. It may not be a problem but let's not make broad generalizations about others' lack of observational skill.
Believe me. I look for it every time I'm at those higher speeds on closed courses. If my hood visibly fluttered even a little bit it would bug the shit out of me.
winstonscifi (02-06-2017)
Old 02-06-2017, 01:13 PM   #30
Not making any form of generalization since I didn't say not observing it I said not seeing it. It could be a small enough movement that it isn't readily visible but it is still moving. Some just move more that others and are more visible but it doesn't hurt a thing. Unless you have welded the hood shut there is going to be some lift. It is unavoidable with the way the mech works.
Old 02-06-2017, 02:58 PM   #31
Ok. Now I just need somebody to pet my fur back down.
Old 02-06-2017, 03:01 PM   #32
How would you phrase it?
Old 02-06-2017, 03:28 PM   #33
I think it comes down to how "move" is defined. I would lazily say mine doesn't move but I would be technically wrong. And you know that's important to me. It's not just semantics.
Maybe if we focus on visible movement or visible deflection we would weed out the "mine doesn't move" group.
Even at elevated speed, I do not observe any visible deflection or flutter in my hood. I have seen that in other vehicles and I've adjusted plenty of latches and bump stops.
I think that if an owner observes movement AND finds it annoying then, based on personal experience with my sample of one, I think it's reasonable to look for, and try to take up the lash.
Old 02-06-2017, 03:37 PM   #34
The question posed was "is this normal?". The answer to that is yes. If the question had been "can I do anything about it?" my responses would have been different. Mine really only does it when there is a gust or other burst of air so it does not bother me. It isn't going to fly open, warp or bend, or cause any other problems and as such is not an "issue" unless it bugs you.
On a related note anybody that has ever had somebody push the down button on a convertible while travelling at 80mpk knows the results are spectacular (and vey messy).
Ultramaroon (02-06-2017)
Old 02-06-2017, 05:12 PM   #35
dudeslife
here it is... look at the edge.
http://webho.net/pics/IMG_2392.MOV
2016 Halo Manual
dudeslife is offline   Reply With Quote
Old 02-06-2017, 05:16 PM   #36
ChimpMania
Drives: 2014 WRB BRZ 6MT
i didn't see anything
ChimpMania is offline   Reply With Quote
Old 02-06-2017, 05:26 PM   #37
I didn't either ...... or was that the point ...... ??
Old 02-06-2017, 05:29 PM   #38
ChimpMania
i saw a shakey camera though
Old 02-06-2017, 05:39 PM   #39
You may be onto something, there.
Maybe, just maybe, the folks that "see" their car's hoods shake ....... maybe it's their eyes or brain that is shaking and the hood is stationary .....
Especially the older folks .......
Old 02-06-2017, 06:52 PM   #40
Oh, I see it. I also see that the edge of your hood is not flush with the fender line. :/
To tcoat's point, and I agree with him, it's a known and common "issue." Something about your hood looks funky though. It will definitely catch air if it doesn't close so it's leading edge matches up with the trailing edge of the bumper fascia. (is that what it's called? the bumper cover thing.)
Last edited by Ultramaroon; 02-06-2017 at 10:01 PM. Reason: fixed a double negative
Old 02-07-2017, 12:05 AM   #41
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Its called a bumper cover.
And that gap looks exactly like my MR2 hood on the highway. Min sits flush, no weatherstrips are missing, etc. Its kinda wierd but i just wrote it off as it being what it is
Ultramaroon (02-07-2017)
Old 02-07-2017, 09:46 AM   #42
dudeslife
The video clearly shows the edge of the hood above the fender bump or whatever its called. I don't expect you to see the hood vibration. thats why I said look at the EDGE
2016 Halo Manual
BRZ replacement hood with "rdot" sticker rookie BRZ First-Gen (2012+) — General Topics 8 09-10-2016 12:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Just some F1 drivers in "normal" Ferraris.. CSG Mike Other Vehicles & General Automotive Discussions 16 03-15-2013 03:42 AM
