How much "jiggling or play" is normal with the FR-S hood?
At 70-80 mph, looking down the driver's side line, the hood is rising up approx 1/4 inch and the hood seems to have some vibration. Is this normal? Thanks for any info.
2016 Halo Manual
Off Topic
It's not uncommon. Crosswinds make it worse. It's not going to go anywhere though. Tested above 100 mph on a closed circuit.
so nothing needs adjusting?
2016 Halo Manual
Drives: Grrrr
In order for the hood to close there has to be some play in the latch. Add the extreme light weight of the aluminum hood and the result is some lift when driving. All is good and nothing to worry about as long as it is flush when stopped.
thanks! my analtivity is causing it to really distract me.. I find myself just staring at it when I am speeding down the interstate.
2016 Halo Manual
All cars do it. The shape of the hood at the fender bulges on ours just make t more obvious than others. If it was flat it could lift as much but you just wouldn't notice it.
Drives: 2013 FR-S, 2023 BRZ
this might be a dumb question but are you sure its closed properly and you haven't accidentally hit the open latch from inside. 1/4 inch of play sounds like the hood isn't closed
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
![]() 2023 Ignition Red BRZ 6MT awaiting boost ![]() |
I doubt it is actually a 1/4 inch. Just seems like it. Love to see somebody climb out and measure it whale going down the highway.
#10 |
Drives: Grrrr
#11 |
Drives: 2013 FR-S 10 series [755]
i dont have this problem.
#12 |
#13 |
lool yea i figured as much but i guessed he looked at a reference and measured. Fwiw its never happened to me
#14 |
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
After about a month, at 1000 miles, I brought my FR-S in for an oil and filter change ( I negotiated a free one during the purchasing process). I had noticed the same thing - the hood on the driver side was a little "loose". There were no questions asked, the technician adjusted the stops and it now shuts tight. I don't have any trouble opening the hood. The OP might just want to bring it in and have them check it.
| BRZ replacement hood with "rdot" sticker | rookie | BRZ First-Gen (2012+) — General Topics | 8 | 09-10-2016 12:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Just some F1 drivers in "normal" Ferraris.. | CSG Mike | Other Vehicles & General Automotive Discussions | 16 | 03-15-2013 03:42 AM |
