Old 02-04-2017, 11:13 AM   #1457
Rezi
Drives: GT86
Originally Posted by Teseo View Post
http://www.datazap.me/u/teseo/log-14...og=0&data=1-12
Running Stg 2 UEL with 93oct. Stock intake, stock air filter also. @steve99 or @Wayno can chime in? Thanks
Do some 3x 3rd gear pulls to get meaningful results. One pull is nothing.
Also you run too rich + LTFT is way off.
Rezi is offline   Reply With Quote
The Following User Says Thank You to Rezi For This Useful Post:
Teseo (02-04-2017)
Old 02-04-2017, 07:42 PM   #1458
steve99
Drives: FT86
+1 on what rezi said its running way rich 11.2 and below what sensor is calibrated too on oft tune, and ltft needs work. Basicly maf scaling will fix it, assuming you dont have any intake/exhaust leaks
Teseo (02-04-2017)
Old 02-04-2017, 07:51 PM   #1459
Teseo
Drives: frs
I checked for leaks, but seems everything is fine. I will try to get more pulls, you think the car can run more aggresive tune like ofh tune?
Old 02-04-2017, 08:33 PM   #1460
Rezi
Drives: GT86
Without fixing the AFR and adjusting the MAF i wouldn't consider to try any more aggresive tune.
Check your O2-sensor if they are tight. Otherwise if you are 100% sure there are no intake&exhaust leaks try a slightly leaner MAF-Scale.
Teseo (02-05-2017)
Old 02-05-2017, 05:33 AM   #1461
Teseo
Drives: frs
Ok. I will check on a muffler shop and do a leak test. Im using 93oct, if i use 91oct would give me different reads?
Old 02-06-2017, 02:03 AM   #1462
svolo4
Drives: FRS
Hi Guys,
I am running on Toemi UEL, Milltek O/P and F/P, k&n drop in and OFT Stage 2 UEL. 91 gas.
I recorded logs for the very first time today and saw that IAM is dropping to 0.88 sometimes. Is this something to worry about? I'm bringing this car to track from time to time but all previous track days were on stock car. I'm trying to understand is it safe to go on track with this config.
Here's the log:
http://datazap.me/u/svolo4/first-run?log=0&data=1
svolo4 is offline   Reply With Quote
Old 02-06-2017, 10:54 PM   #1463
Teseo
Drives: frs
Some pulls, was on the morning below 70F.
http://www.datazap.me/u/teseo/log-14...1-4-5-6-7-8-12
Old 03-05-2017, 11:19 PM   #1464
BXRCHTR
Here's the first E85 pulls for the season. The two full throttle pulls are both in 3rd gear. Wayno's e85 tune. Tell me what you think and what can be improved on it. Would really like to fully optimize this car.
http://www.datazap.me/u/ivou158/e85-...&zoom=548-1014
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear god, protect my ride.
BXRCHTR is offline   Reply With Quote
Old 03-05-2017, 11:55 PM   #1465
phrosty
Wow. Lowest I've been on E85 is 40-45, curious how you'll find it on the 20-30 days we've got coming up.
phrosty is offline   Reply With Quote
Old 03-06-2017, 12:08 AM   #1466
BXRCHTR
hahah tbh, it's not too bad. I ran it until I couldn't take it anymore before winter and starting is a bit interesting. But the good thing is she loves the cold air haha. I've had the intake temps down to the negatives and damn does she pull harder than when temps are ~40. I'm just starting the season earlier so I can fine-tune the tune before race season
Old 03-06-2017, 09:43 PM   #1467
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Multiply 3.44V and above by 0.96.
Old 03-07-2017, 10:51 AM   #1468
Cole
Not a troll
Cole's Avatar
Am I ok?
Cole is offline   Reply With Quote
Old 03-18-2017, 03:44 PM   #1469
JW843
JW843's Avatar
Drives: 2013 BRZ Limited
Can anyone decipher the issues i'm having here? my STFT is all over the place, LTFT is +-5%, and i'm not sure if the distance between my command AFR and AFR is safe, it varies quite a bit. Most of the issues seem to be while cruising, for example at one point i'm just coasting at 5% throttle and the STFT is all over. Any help would be greatly appreciated.
Mods include:
Borla Header
HKS Front pipe
HKS catback
OFT running stage 2 UEL tune,
Stock intake
http://www.datazap.me/u/jwiggins864/...0?log=0&data=1
http://www.datazap.me/u/jwiggins864/...2?log=0&data=1
JW843 is offline   Reply With Quote
Old 03-19-2017, 12:25 AM   #1470
steve99
Drives: FT86
Mods include:
Borla Header
HKS Front pipe
HKS catback
Stock intake
Diagnosis ---- you don't have a problem.
STFT is supposed to vary widly in closed loop, and will be zero in open loop.
The LTFT of =/- 5% or less is good.
commanded afr and measured afr are close, maybe 3% rich top end but fine
IAM=1
no knock flkc or fbkc
all good
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
