Old 09-07-2016, 04:54 AM   #127
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
- Paolo / pcuerpo
- GReddy T518Z
- Petron Blaze (100 Octane, not sure about RON conversion)
- GrimmSpeed boost controller, Omni 3 bar map sensor, FIC 1100cc injectors, DW 65c Fuel Pump, 2.5" to 3" Custom overpipe and frontpipe, GReddy Revolution RS exhaust
- EcuTek tuned by Speedworks Engineering
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 09-23-2016, 09:56 PM   #128
SheilaBRZ
SheilaBRZ's Avatar
Drives: 2016 Subaru BRZ Limited
SheilaBRZ
Jackson Racing C30 Supercharger Kit
7-9 psi (no boost gauge yet)
Rest of car currently stock
Tuned at National Speed in NC by Vlad
SheilaBRZ is offline   Reply With Quote
Old 09-24-2016, 12:22 AM   #129
Amputechture
Drives: 2014 BRZ
Originally Posted by SheilaBRZ View Post
SheilaBRZ
What is the difference of the baseline, 93 vs FF? Or Carb vs his tune?
Amputechture is offline   Reply With Quote
Old 09-24-2016, 01:47 AM   #130
SheilaBRZ
SheilaBRZ's Avatar
The baseline was the 2nd run he did based off the Jackson racing canned tune (originally the first dyno pull before he tweaked it was 236 hp, 183 torque from just installing the tune that comes with the kit)and that was supposed to be for 91 octane and cali compliant. The custom tune got me to the 295/211 and was for 93 octane. I guess the Jackson racing was just a extremely conservative tune. I really didn't expect to go in there and come out with 60 extra horses. Also it drives more like stock now and not as jerky as with the canned tune. Before the custom tune it seemed as if there was a delay in throttle response that is now fixed as well.
The Following User Says Thank You to SheilaBRZ For This Useful Post:
CxG (01-18-2017)
Old 11-04-2016, 05:12 AM   #131
DHitHim
Drives: 2015 CWP Limited BRZ
332whp 252 torque on Dynojet
- Dhithim
- Fullblown base gt2871r
- E80
- 0.8 Bar
- 1000cc FIC injectors, Flex Fuel, shorter intercooler piping after turbo to intercooler. 3" JDL OP+FP, 2.5 inch tommy kaira titanium catback
- Delicious Tuning Flash and Go. Trying to finalize tune with flash and go via data log on dyno.
DHitHim is offline   Reply With Quote
Old 11-15-2016, 04:49 AM   #132
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
FI Dyno thread
Mustang dyno
Edelbrock
Delicious tune
D-box
ACE CS400 header/op
HKS FP (stock on dyno pull)
Tomei 60s
91 octane
Stock injectors
Stock fuel pump
254whp
205tq
Silverfox is offline   Reply With Quote
Old 01-23-2017, 07:44 PM   #133
Unclewonka
Drives: Red GT86 manual (July build)
AVO kit running just under 10psi
Hypertune intercooler
Delicious Tuning flex fuel kit
DW65c pump with ID 1000cc injectors
Empire 2.5" downpipe, MAP Performance 2.5" catless frontpipe with resonator, AVO 2.5" resonated catback
Dyno Dynamics, E85, tuner Jai Philps of Big Rock Toyota. Usual stock baseline here is 145whp
Unclewonka is offline   Reply With Quote
Old 01-31-2017, 12:16 PM   #134
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
Originally Posted by xsnapshot View Post
Before: Moto-East e-tune
After: DBW motorsports dyno-tune
Relevant Mods:
Automatic trans (According to Doug @ DBW, they run about 8-10% less on his dyno than a manual)
Jackson Racing supercharger
High boost pulley
Flex fuel with E72 in the tank
Full catless exhaust
This is hitting 12 psi at the very top with the high boost pulley.
Do you know how his automatic FRS is handling the high boost pulley? Im running the c38 and debating about going HB and flex fuel but am afraid that the tranny wont hold up.
Hook Em'
zkahle is offline   Reply With Quote
Old 01-31-2017, 01:11 PM   #135
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Originally Posted by Silverfox View Post
Mustang dyno
Edelbrock
Delicious tune
D-box
ACE CS400 header/op
Tomei 60s
91 octane
Stock injectors
Stock fuel pump
254whp
205tq
I kinda expected more tbh. But also dont Mustang Dyno's read kinda lower? I saw someone on a Dynojet with the CARB tune who made 250. Hard to believe the Delicious Tune only saw a gain of only 4 hp.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 01-31-2017, 03:15 PM   #136
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
When you say "his" do you mean me? I have the car you quoted. Doug had a turbo'd manual FRS.
My BRZ has been holding up fine so far. The C38 is a beast though. I'd think carefully about going HBP and flex fuel on a stock motor/tranny with the C38. You'd PROBABLY be fine for a while, but I'd definitely start saving for a rebuild.
xsnapshot is offline   Reply With Quote
The Following User Says Thank You to xsnapshot For This Useful Post:
zkahle (02-04-2017)
Old 01-31-2017, 04:10 PM   #137
Silverfox
Silverfox's Avatar
I did not do a baseline dyno, but yes, this mustang dyno reads low consistently and the dyno jets tend to read much higher than mustang dynos.
About to run E-85 and expect around 330 whp 240tq.
Old 02-04-2017, 12:12 PM   #138
zkahle
zkahle's Avatar
Thank you very much for the info. And sorry for some reason when I read your original post I thought you were talking about a friends FRS. If you were to recommend one or the other "flex fuel VS HBP" which would you go and why? Im just looking for a little more power. The c38 is nice and of itself but I just need a little more lol.
Hook Em'
Old 02-04-2017, 12:52 PM   #139
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
From what I'm reading, Flex fuel first if you have access to E85. HBP will increase the power output dramatically and needs higher octane anyway, so start with E85 first. It should be plenty more power from there.
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
zkahle (02-04-2017)
Old 02-05-2017, 11:16 AM   #140
xsnapshot
Fast enough
Definitely flex fuel. You'll get a very nice power bump on just the stock pulley. And the HBP is an easy upgrade should you want it later.
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 11:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
