Old 02-04-2017, 05:52 AM   #29
NLS8520
Drives: N/A
Car and Driver BRZ PP Review.
http://www.caranddriver.com/reviews/...t-drive-review
NLS8520 is offline   Reply With Quote
The Following 2 Users Say Thank You to NLS8520 For This Useful Post:
jmark (02-04-2017), Mr.Impreza (02-04-2017)
Old 02-04-2017, 11:44 AM   #30
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Originally Posted by NLS8520 View Post
For me, the Performance Package enhances an already great chassis.
Tires are not that expensive and are maintenance. Once the stock ones run out you can upgrade to a better set.
Power can also be improved easily and is a fun journey if you decide to go on it. However the car has plenty out of the factory. My Fit overtakes cars no problem on the highway with 100Hp....so people need to seriously stop complaining about power on his car. Which they won't obviously. Nor do they ever stop complaining that the STI doesn't have enough with 305hp
They added what most tuners don't. Better brakes. So I think they made the right decision. They are offering an even better car now for someone who just wants to enjoy it since a lot of people who tracked the car said that the brakes could be better from what I remember.
I know as a daily driver, it won't really benefit many people....but this is the PP....not the standard model. People who are buying the PP are most likely those who are more driver focused or track oriented.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following 7 Users Say Thank You to Mr.Impreza For This Useful Post:
BboyRuda (02-04-2017), Import_Lexus (02-04-2017), Lateral G (02-24-2017), Psilox (02-04-2017), spike021 (02-04-2017), Taka (02-04-2017), ~el~jefe~ (02-04-2017)
Old 02-04-2017, 11:59 AM   #31
Psilox
Drives: Nothing yet!
Well I for one am even more glad I'm getting mine with the PP. I've heard from multiple reviews that it also improves ride quality in addition to brake feel, so very happy with that.
You're right though, I don't think anything could stop people from complaining about paper specs--for a car that was Jezza's car of the year in addition to winning numerous other awards. It's almost as though most of the commenters haven't driven one...
Sent from my E6653 using Tapatalk
Psilox is offline   Reply With Quote
Old 02-04-2017, 03:06 PM   #32
gtengr
Drives: 2017 BRZ
The car doesn't really need better brakes though precisely because it's slow and under-tired. Brake upgrades are most effective with wider, stickier tires, repeated high speed stops, and with heavier cars. The 86 is the opposite of all of those things: narrow tires, lower top speed on the straights because of low power, and less kinetic energy transfer required during heavy braking because of its low curb weight and lower speeds. They're mostly an aesthetic mod that adds considerable brake weight and aren't the same as an aftermarket Brembo or similar quality BBK. They do look great though and are cost effective for the aesthetic effect.
gtengr is offline   Reply With Quote
Old 02-04-2017, 04:03 PM   #33
~el~jefe~
Drives: 2019 MX-5 RF
I must scientifically decline to agree here. Both in implications, and real world usage.
1. hp/tq of a car and mentioning this with Upgraded brakes is nonsensical. When you are braking, there is no power to the wheels as you are removing your foot off the gas. The weight of the car is the only factor, and then direction, if it needs to brake on a curve and has bad center of gravity or weight distribution.
2. Braking at high speeds with normal brakes can cause brake fade ON THE FIRST BRAKING. Yes, you can overheat brakes in one shot. If you are driving at 110mph on a straightaway feeling badass, then realize you must brake, your brakes will nearly ignite if you press them hard.
3. 2800 lbs is not a lightweight car. 300 lbs more and you have a camry at 191 inches in length.
4. No one will re-purchase the expensive summer low rolling resistance stock tires again. Any consideration to a good consumer reports or forum tested/tirerack tested tire will mean that owners will have very good gripping tires. To not first buy a cheap cheap cheap upgrade that costs thousands normally means that when you do get great tires in a year or two maximum, you will wish you had better brakes.
5. A hill. I know people forget that they exist, but the do. A hill will scorch a brake fast, reducing the consistency of its braking distance. Keeping a car in low gear will eventually red line. If you want to go down a mountain at 22mph, maybe not then. People brake often on a hill, and if you are new to a location, you will be braking a lot not knowing the turns. Then when you have to stomp on brakes in emergency, your brakes are heated.
6. instead of testing such brake fade in all conditions and reading 1000's of forum posts and test sites like Car and Driver to glean information, simply having upgraded rotors and calipers designed for no brake fade will take one's mind off worrying about the brakes fading. It is very important to know what the car will do in an emergency procedure condition. To wonder if your stopping distance is 4-6 ft less due them heating up, is to not know what the car will do.
~el~jefe~ is offline   Reply With Quote
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
Old 02-04-2017, 04:44 PM   #34
gtengr
Drives: 2017 BRZ
Horsepower determines how fast you're going at the end of straight. Kinetic energy is a function of velocity squared.
It's not a good idea to be driving that way without good brake pads and fluid.
2800 is lightweight for a RWD street car. The BRZ is a lighter than a Cayman, 991, M2, etc. Compared to pretty much anything but a Miata, Lotus, or racecar it is light.
Agreed.
The BBK has more heat capacity, but I wouldn't be using a street brake pad or fluid for that type of driving. A BBK doesn't make you invincible and can still fade rather quickly if you use a street pad and fluid. I'm not positive that's the case on this car because it's slow and light, but I have experienced fade with OEM Brembo's on other cars.
I don't mean to rag on the kit, just wanting to point out that it adds weight, it is generally accepted that a rear BBK isn't necessary on this car, and the aftermarket stuff is better and lighter than stock, whereas this is a weight gain.
Pads and fluid are the primary factors with brake fade though.
I want to emphasize that I'm not saying the kit is bad, just pointing out it's not the same thing as a quality aftermarket kit. Anyone who gets heavily into tracking will probably end up replacing everything that comes with the PP except maybe the rear brakes.
The Following User Says Thank You to gtengr For This Useful Post:
funwheeldrive (02-16-2017)
Old 02-05-2017, 03:20 PM   #35
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
For a car of this weight and power, I am not sure I would agree with this.
With proper cooling ducts, I can see this caliper to have less problems with spread than the stock floating caliper.
The real question I have (that I have not researched enough) is to know what pad options are available for that caliper. For example, the Brembo option on the MX5 Club fronts were expensive, forced a 17" wheel that was too narrow with more expensive tires, was slower/worse gearing, and thus not a good option to purchase.
Do these Brembo calipers on the BRZ PP have the same pad options as the STi and what are the costs? Link?
However, in general, I would think for the 7.5" wide tire (almost good enough to run 225s which I think are about all this car needs at this time), upgraded dampers, and brakes that won't spread/easier to change.... sounds like a good upgrade for 1195. And, it is factory, so thus does not change stock classing.
dowroa is offline   Reply With Quote
Old 02-05-2017, 09:06 PM   #36
~el~jefe~
would a fluid swap on the brakes void warranty claims for brakes or connected things?
it would be 'out of spec' to use racing brake fluid i would imagine
Old 02-06-2017, 02:36 PM   #37
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
No, its a maintenance item.
goldenfri is offline   Reply With Quote
Old 02-06-2017, 02:41 PM   #38
I wouldn't be too quick to say no. If they could blame the fluid used they will. Would be OK of course if in their recommended/required scope but anything outside of that could be used against a claim.
Old 02-06-2017, 02:46 PM   #39
goldenfri
goldenfri's Avatar
As long as you aren't using something obvious like the banned super blue, then its very highly unlikely that they would even think you are using anything different.
The Following User Says Thank You to goldenfri For This Useful Post:
Tcoat (02-06-2017)
Old 02-06-2017, 02:50 PM   #40
Oh no doubt. Pretty hard too tell brake fluids apart unless something weird. Just need to keep in mind that they could deny coverage if they did figure it out.
Old 02-15-2017, 05:16 PM   #41
2017-BRZ
Drives: 2017Crystal White Pearl BRZ Limited
Do NOT like that PP wheel..I would take that extra expense and purchase good looking 18" aftermarket wheels and performance tyres instead.
I think the stock brakes and suspension is performance with comfort. Perfect driving balance. Love it.
2017-BRZ is offline   Reply With Quote
Old 02-15-2017, 05:18 PM   #42
2017-BRZ
Subaru SHOULD have given the STI wheel as the PP package....then it would be worth it...and the RED center caps with the BIG RED BBK calipers would look PERFECT.
The Following User Says Thank You to 2017-BRZ For This Useful Post:
~el~jefe~ (02-15-2017)
Specs for BRZ Performance Package wheels? ~el~jefe~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 04-17-2020 07:31 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 11:04 PM
Someone tested the Performance Package... small but SOME info at least ~el~jefe~ BRZ First-Gen (2012+) — General Topics 13 11-29-2016 05:21 PM
2014 Subaru BRZ (Aozora Package Review) sik20fan FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 07-29-2015 05:10 AM
Crawford Performance BRZ (450 HP) review by Matt Farah (Drive) switchlanez BRZ First-Gen (2012+) — General Topics 66 09-20-2014 02:31 PM
