Old 02-04-2017, 12:44 AM   #1
Impureclient
Drives: 2015 FR-S
Buzzing from dash
It sounds like a bee buzzing inside a plastic bag.
Any ideas?
Old 02-04-2017, 12:45 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Any ideas?
Video does not work. Set to public.
N1rve
The Following 2 Users Say Thank You to N1rve For This Useful Post:
humfrz (02-04-2017), Impureclient (02-04-2017)
Old 02-04-2017, 01:31 AM   #3
Any ideas?
Speedometer cable needs oil ........
N1rve (02-04-2017), Tokay444 (02-05-2017)
Old 02-04-2017, 02:18 AM   #4
N1rve
N1rve's Avatar
Maybe he needs to replace his blinker fluid
N1rve
Old 02-04-2017, 02:58 AM   #5
Impureclient
Drives: 2015 FR-S
Fixed it.
Old 02-04-2017, 03:38 AM   #6
Fixed it.
Sorry, I can't sort out any sound from the engine running sound ......
Does it make the noise even when the temperature controls are all turned OFF .. ??
Old 02-04-2017, 10:50 AM   #7
Traffic
Drives: 2016 BRZ Limited Automatic
Remove any items from the side door pockets and the center console and see if the noise is still there. I heard the noise in your video and I have found that a lot of the noises were cause by stuff rattling in the cup holders and pockets.
If it is still there after you do that, start pressing the odo glass, dash and panels with your hand to see if the sound stops. you may have a fastener or seam that is loose and rubbing up against an adjacent panel.
Traffic is offline   Reply With Quote
The Following User Says Thank You to Traffic For This Useful Post:
jcw99 (02-04-2017)
Old 02-04-2017, 12:21 PM   #8
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I can't watch your video right now as I don't have speakers on my work computer, but I have recently had an extremely annoying rattle coming from my windshield area when it dips down into the extreme cold range.
I'm sure it's caused by something contracting because of the cold, but I can't for the life of me figure out what exactly is rattling. It's definitely more of a loud rattle than a buzz, like someone shaking marbles in a plastic cup. I've tried putting pressure on the windshield, and various parts of the dash, to see if I can pin-point where it's coming from, to no avail.
It is infuriatingly annoying when driving at speed, as it rattles with every minor undulation in the road. So much so that I have to turn my music up louder to try to drown it out, lest I develop an eye twitch.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 02-04-2017, 12:40 PM   #9
Impureclient
Drives: 2015 FR-S
Nothing in center console, doors or anywhere something could be moving. Temperature doesn't matter, it's always there.
It starts around cruising speed I think about after 45 mph and is definitely there going 60+ mph like this video. I tried pushing
on a bunch of things on the side where it's coming from but it hasn't stopped temporarily. This has been in the car since the day
I got it. It only bothers me when the windows are up and radio is off which is not that much but when those conditions are met,
it is annoying the crap out of me. When cruising in 6th , if I tap on the accelerator driving RPMs up, it will subside so it's pretty
much a certain RPM that creates the right frequency for it to start. Temp controls all off, still there.
I guess I can go out really late at night when there's no traffic and put it in cruise control and start pushing on things on by one
to see if that narrows it down.
It is way under warranty still so is this something a dealer would even attempt to fix?
Old 02-04-2017, 02:18 PM   #10
Traffic
Taking it to the dealer is an option but usually rattles that are behind the dash requires removing the dash itself. I have learned from experience that unless you have a very competent tech it can cause more issues.
Then again the dealer may have already dealt with this on other cars and have an idea where to start. If you exhausted everything it may be worth a shot.
Old 02-04-2017, 03:47 PM   #11
I would suggest you take a co-pilot along, to try to isolate the buzzing sound when you are at speed. I have found that sometimes another set of ears, sitting in a different position, can find the source of unwanted sounds better than the driver sitting behind the wheel.
I doubt that the dealer will be much help ......
Old 02-04-2017, 04:03 PM   #12
Impureclient
Drives: 2015 FR-S
So a small child in my lap that can crawl around and pinpoint it? I know the seatbelt laws are in effect but OK if you say so, I'll do anything to stop this buzz.
Old 02-04-2017, 04:10 PM   #13
I'm not following that ......
Small child .....???
Old 02-04-2017, 06:42 PM   #14
phrosty
I may have the same thing. Sounds like something is swinging around when on a bad road at low speeds. Took the dash apart last week and didn't find anything that looked unusual, but I'm no expert.
Only happens on cold days (like, below freezing cold).
phrosty is offline   Reply With Quote
Buzzing at 2.5k rpm oppiee Issues | Warranty | Recalls / TSB 9 03-06-2017 10:22 PM
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 10:34 PM
High rpm buzzing noise Frsultramarine15 Scion FR-S / Toyota 86 GT86 General Forum 21 11-13-2014 02:58 PM
Buzzing speakers FRS_Sovereign Electronics | Audio | NAV | Infotainment 8 06-09-2013 03:41 PM
exhaust buzzing 3k to 4k input please! ft86me Engine, Exhaust, Transmission 11 03-24-2013 02:02 AM
