#127 |
For me there's no added play. If you don't like it you can easily just put it back in.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | funwheeldrive (01-30-2017) |
#128 |
Drives: 2013 Firestorm FRS
| The Following 2 Users Say Thank You to continuecrushing For This Useful Post: | funwheeldrive (02-02-2017), VerusEric (02-09-2017) |
#129 |
Drives: 2013 Subaru BRZ
Literally just did this on my lunch brake haha
Took about 5 minutes and the difference is definitely worth it!!! As for the play? there's maybe a few mm of it. Nothing that bothers me. |
| The Following User Says Thank You to TheDetailer718 For This Useful Post: | funwheeldrive (02-02-2017) |
#130 | |
Drives: 2016 ZC6
You could try swapping the stock clutch spring with the MTEC clutch spring. Supposed to be better feel than stock without the slop at the top. And in the middle of changing it, with the clutch spring out, drive around a bit and see if you like total spring removal before installing the MTEC one.
My build thread: Pointmutation's WRB BRZ build
| The Following User Says Thank You to Pointmutation For This Useful Post: | funwheeldrive (02-02-2017) |
#131 | |
#132 |
Drives: 2016 ZC6
I haven't adjusted the clutch pedal height yet. It's one of the mods I'm debating. That and the mtec spring swap since sitting in traffic is more irritating after a good leg workout since I removed the spring. Haha
#133 |
Drives: Man
Just removed the spring in my FR-S last night. Holy Sh**! It's really not that stiff, but it feels so much better. The pedal feels like it sits a little lower but I can fix that tonight.
| The Following User Says Thank You to kakacarrotcake For This Useful Post: | stevesnj (02-05-2017) |
#134 |
Drives: 2013 Scion FR-S firestorm
IT is so much better, i did mine last week. It feels like every other manual i have driven. It was my only complaint about the car!
#135 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
I'm glad you guys are enjoying the DIY and the clutch spring removal, for the most part ![]() .Eric |
| The Following 2 Users Say Thank You to VerusEric For This Useful Post: | 86 South Africa (11-07-2017), continuecrushing (02-09-2017) |
#136 |
Drives: 2014 GT86
Today tried mtec spring install there. Failed. Had removed e-clip, pin was out .. but no matter what i tried, couldn't get stock spring and it's top mount off the pedal. With pressed pedal, depressed pedal .. tried to squeeze spring with pliers and press pedal :/. And yet it was 5min job for some .. HOW? :/
#137 | |
The Gunshine State
Drives: '14 BRZ Limited
![]() Current DD: M235i |
#138 |
Drives: 2014 GT86
On second attempt succeeded. Without screwdriver, or pliers for that stage ..
1) pedal pressed in fully, for spring to be at longest state 2) i needed to push it with fingers in direction of wall, not to myself (probable reason, why i failed in first attempt). Slight wiggling and finally off. Luckily e-clip was easy to get off/pin push out. Probably i bent clip in first attempt to ease that .
#139 |
Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
You guys should see how much effort we have to put in for RHD :P
I managed to remove the spring and reinstalled the spring holder in about an hour with lots of help from @Law's DIY. First impression is how 'bouncy' the clutch feels now, the pedal return is really fast and smooth unlike stock. I don't believe I can feel the friction/bite point any clearer but since it's so linear, there's minimal stuttering and see-sawing when i shift. It's definitely stiffer but the left leg will get used to it. I'll need to drive more before I can really tell the differences but I can wholeheartedly say that the spring's not going back anytime soon. EDIT: Also since i reinstalled the spring holder, there's no play at all in the pedal. It's as solid as when the spring was there. Last edited by enouf; 05-26-2017 at 09:45 AM. Reason: No Play |
| The Following 2 Users Say Thank You to enouf For This Useful Post: | funwheeldrive (05-26-2017), jcw99 (05-26-2017) |
#140 |
Drives: '13 Sport Tech
I just did this on my 2017 86 yesterday.. Has it been determined that there will be no ill-effects to the clutch itself? I see conflicting information, thanks.
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 12:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-14-2017 11:44 PM |
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 03:42 AM |
| Clutch spring removal | Sandy | AUSTRALIA | 4 | 07-22-2015 10:14 PM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 08:08 PM |
