Old 01-29-2017, 10:32 PM   #127
stevesnj
stevesnj's Avatar
Doesn't the added play in the peddle bug you guys? I've been considering this for a while, but I don't think I would be able deal with the added looseness.
For me there's no added play. If you don't like it you can easily just put it back in.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
funwheeldrive (01-30-2017)
Old 01-31-2017, 11:40 AM   #128
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
hehe...put it back in lulz
On a serious note, I think the play is, uh, overplayed? I don't really notice the extra play. If its there, having better clutch feel is worth it.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
funwheeldrive (02-02-2017), VerusEric (02-09-2017)
Old 01-31-2017, 01:42 PM   #129
TheDetailer718
TheDetailer718's Avatar
Drives: 2013 Subaru BRZ
Literally just did this on my lunch brake haha
Took about 5 minutes and the difference is definitely worth it!!!
As for the play? there's maybe a few mm of it. Nothing that bothers me.
TheDetailer718 is offline   Reply With Quote
The Following User Says Thank You to TheDetailer718 For This Useful Post:
Old 02-02-2017, 09:59 AM   #130
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Doesn't bother me. Better clutch feel outways the extra play at the top.
You could try swapping the stock clutch spring with the MTEC clutch spring. Supposed to be better feel than stock without the slop at the top. And in the middle of changing it, with the clutch spring out, drive around a bit and see if you like total spring removal before installing the MTEC one.
Pointmutation is offline   Reply With Quote
The Following User Says Thank You to Pointmutation For This Useful Post:
Old 02-02-2017, 11:29 AM   #131
funwheeldrive
Have you adjust the clutch pedal height at all? It seems like those who have don't have as much play?
Old 02-02-2017, 06:22 PM   #132
Pointmutation
Drives: 2016 ZC6
I haven't adjusted the clutch pedal height yet. It's one of the mods I'm debating. That and the mtec spring swap since sitting in traffic is more irritating after a good leg workout since I removed the spring. Haha
Old 02-04-2017, 11:45 AM   #133
kakacarrotcake
kakacarrotcake's Avatar
Drives: Man
Send a message via ICQ to kakacarrotcake Send a message via AIM to kakacarrotcake Send a message via Yahoo to kakacarrotcake
Just removed the spring in my FR-S last night. Holy Sh**! It's really not that stiff, but it feels so much better. The pedal feels like it sits a little lower but I can fix that tonight.
kakacarrotcake is offline   Reply With Quote
The Following User Says Thank You to kakacarrotcake For This Useful Post:
stevesnj (02-05-2017)
Old 02-09-2017, 11:57 AM   #134
machineica
Drives: 2013 Scion FR-S firestorm
IT is so much better, i did mine last week. It feels like every other manual i have driven. It was my only complaint about the car!
machineica is offline   Reply With Quote
Old 02-09-2017, 12:03 PM   #135
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
This hit the nail on the head for me! I honestly had to get under there, with my hand on the pedal to really notice it. If people didn't complain about it, I doubt I would have ever noticed it. There is play, but there is no feedback/pressure for that first 1/4" or whatever it is.
I'm glad you guys are enjoying the DIY and the clutch spring removal, for the most part .
Eric
VerusEric is offline   Reply With Quote
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
86 South Africa (11-07-2017), continuecrushing (02-09-2017)
Old 05-24-2017, 01:25 PM   #136
churchx
churchx's Avatar
Drives: 2014 GT86
Today tried mtec spring install there. Failed. Had removed e-clip, pin was out .. but no matter what i tried, couldn't get stock spring and it's top mount off the pedal. With pressed pedal, depressed pedal .. tried to squeeze spring with pliers and press pedal :/. And yet it was 5min job for some .. HOW? :/
Old 05-24-2017, 01:29 PM   #137
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Took me less than 5 to remove the whole spring assembly. You may need to get a screwdriver in there to pry the spring out. The pin was the only thing holding it all together.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-24-2017, 03:40 PM   #138
churchx
churchx's Avatar
Drives: 2014 GT86
On second attempt succeeded. Without screwdriver, or pliers for that stage ..
1) pedal pressed in fully, for spring to be at longest state
2) i needed to push it with fingers in direction of wall, not to myself (probable reason, why i failed in first attempt). Slight wiggling and finally off.
Luckily e-clip was easy to get off/pin push out. Probably i bent clip in first attempt to ease that .
Old 05-26-2017, 09:44 AM   #139
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
You guys should see how much effort we have to put in for RHD :P
I managed to remove the spring and reinstalled the spring holder in about an hour with lots of help from @Law's DIY.
First impression is how 'bouncy' the clutch feels now, the pedal return is really fast and smooth unlike stock. I don't believe I can feel the friction/bite point any clearer but since it's so linear, there's minimal stuttering and see-sawing when i shift.
It's definitely stiffer but the left leg will get used to it. I'll need to drive more before I can really tell the differences but I can wholeheartedly say that the spring's not going back anytime soon.
EDIT: Also since i reinstalled the spring holder, there's no play at all in the pedal. It's as solid as when the spring was there.
enouf is offline   Reply With Quote
The Following 2 Users Say Thank You to enouf For This Useful Post:
funwheeldrive (05-26-2017), jcw99 (05-26-2017)
Old 08-09-2017, 12:28 AM   #140
tawheed
Drives: '13 Sport Tech
I just did this on my 2017 86 yesterday.. Has it been determined that there will be no ill-effects to the clutch itself? I see conflicting information, thanks.
tawheed is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-14-2017 11:44 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
