#15625 |
Drives: red 2014 FR-S
The main point was to be able to point the camera up more. the second was to hide it. My paint is reflecting the camera. here I photo shopped the reflection out so you can how much the camera is actually showing. this is also viewed from an angle lower than the car would normally be viewed from.
#15626 | |
Drives: 2009 Nissan Altima, 2015 Scion FR-S
Sent from my XT1650 using Tapatalk |
#15627 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
It's on the previous page in his first post.
-O/D
2016 FR-S, Hot Lava |
| The Following User Says Thank You to Overdrive For This Useful Post: | fx1mark (01-31-2017) |
#15628 |
Ha my bad didn't realize the topic started a couple pages back, usually read the forum on my app. Looks good, I reversed into a BBQ pit last week and am going to drop off my car for repair Friday. Totally considering adding a cam now lol.
| The Following User Says Thank You to g33k For This Useful Post: | Overdrive (01-31-2017) |
#15629 | |
Drives: Scion FR-S Series 10 #2462
#15630 |
I used this kit.
http://www.ft86club.com/forums/showp...ostcount=14758 install was fairly easy. hardest part was the reverse trigger wire. I would recommend buying one pre-made. you need to tap into a jack in the back of the head unit. the jack is empty in that slot. some people jam a wire in. I didn't want to do that. It happened that I had a pin that would work. then connecting to the wire behind the drivers side kick panel is not an easy reach. I did manage to strip and solder the wire. the wire you are tapping into is pretty small. I used a 22 guage for the jumper and it was a little smaller than that. I tucked the wire going back to the camera under the center console and under the back seat. that simplified the install. here is a pre-made trigger wire. http://www.autoharnesshouse.com/19867_add.html |
| The Following User Says Thank You to fx1mark For This Useful Post: | MJones_RB (02-01-2017) |
#15631 |
First 86 Driver Baby!
Drives: FR-S, Flex
Didn't do this today, but recently installed a rear seat delete...
#15632 |
Drives: Asphalt 2013 FRS
Changed transmission fluid.
#15633 |
Sittin' Sideways
Interesting. Does that panel still drop to give you a pass through for larger items, or is your trunk full of woofer now?
-O/D
#15636 |
Drives: 13 FRS - Boosted
![]() Added the D to the Edelbrock. One more D to go ![]() Sent from my SAMSUNG-SM-G935A using Tapatalk |
#15637 |
Sittin' Sideways
...does it like the D?
-O/D
| The Following User Says Thank You to Overdrive For This Useful Post: | MJones_RB (02-01-2017) |
#15638 | |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
