go_a_way1, MisterSheep
Old 01-31-2017, 05:11 PM   #15625
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
what am I missing? Looks the same as factory but 5 inches over?
The main point was to be able to point the camera up more. the second was to hide it. My paint is reflecting the camera. here I photo shopped the reflection out so you can how much the camera is actually showing. this is also viewed from an angle lower than the car would normally be viewed from.
fx1mark is offline   Reply With Quote
The Following 2 Users Say Thank You to fx1mark For This Useful Post:
MJones_RB (01-31-2017), notout86 (02-07-2017)
Old 01-31-2017, 05:31 PM   #15626
g33k
g33k's Avatar
Drives: 2009 Nissan Altima, 2015 Scion FR-S
Any shots of how it looks on the head unit or if it even looks any different?
Sent from my XT1650 using Tapatalk
g33k is offline   Reply With Quote
Old 01-31-2017, 05:51 PM   #15627
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
It's on the previous page in his first post.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
fx1mark (01-31-2017)
Old 01-31-2017, 06:09 PM   #15628
g33k
g33k's Avatar
Ha my bad didn't realize the topic started a couple pages back, usually read the forum on my app. Looks good, I reversed into a BBQ pit last week and am going to drop off my car for repair Friday. Totally considering adding a cam now lol.
The Following User Says Thank You to g33k For This Useful Post:
Overdrive (01-31-2017)
Old 01-31-2017, 07:08 PM   #15629
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I installed a backup camera this week. Driving it Saturday I decided I didn't like the camera angled down like it was. I had the idea of insetting the camera into the trunk garnish. That would allow me to angle the camera as I wanted and I could also make the camera as invisible as possible. I did it today. I made an aluminum bracket and attached it with some strong two sided adhesive foam tape. it seems rock solid. I think it came out pretty good.
How hard was it to wire up to the head unit?
MJones_RB is offline   Reply With Quote
Old 01-31-2017, 07:29 PM   #15630
fx1mark
fx1mark's Avatar
I used this kit.
http://www.ft86club.com/forums/showp...ostcount=14758
install was fairly easy. hardest part was the reverse trigger wire. I would recommend buying one pre-made. you need to tap into a jack in the back of the head unit. the jack is empty in that slot. some people jam a wire in. I didn't want to do that. It happened that I had a pin that would work. then connecting to the wire behind the drivers side kick panel is not an easy reach. I did manage to strip and solder the wire. the wire you are tapping into is pretty small. I used a 22 guage for the jumper and it was a little smaller than that. I tucked the wire going back to the camera under the center console and under the back seat. that simplified the install.
here is a pre-made trigger wire.
http://www.autoharnesshouse.com/19867_add.html
The Following User Says Thank You to fx1mark For This Useful Post:
MJones_RB (02-01-2017)
Old 01-31-2017, 09:24 PM   #15631
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Didn't do this today, but recently installed a rear seat delete...
kmbkk is offline   Reply With Quote
The Following 2 Users Say Thank You to kmbkk For This Useful Post:
Fidel_86 (02-03-2017), MJones_RB (02-01-2017)
Old 01-31-2017, 09:28 PM   #15632
auryn79
auryn79's Avatar
Drives: Asphalt 2013 FRS
Changed transmission fluid.
auryn79 is offline   Reply With Quote
Old 01-31-2017, 10:29 PM   #15633
Overdrive
Sittin' Sideways
Overdrive's Avatar
Interesting. Does that panel still drop to give you a pass through for larger items, or is your trunk full of woofer now?
-O/D
2016 FR-S, Hot Lava
Old 01-31-2017, 10:50 PM   #15634
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
No pass through capability anymore. The amp rack and sub enclosure take up roughly half the trunk, basically the part under the rear deck.
The Following User Says Thank You to kmbkk For This Useful Post:
Old 01-31-2017, 11:03 PM   #15635
Eman
Drives: 2013 Scion FR-S 10 series
Installed a Borla UEL header.
Eman
Eman is offline   Reply With Quote
The Following User Says Thank You to Eman For This Useful Post:
guybo (02-02-2017)
Old 02-01-2017, 01:19 AM   #15636
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
Added the D to the Edelbrock. One more D to go
Sent from my SAMSUNG-SM-G935A using Tapatalk
dejahboi is offline   Reply With Quote
Old 02-01-2017, 01:27 AM   #15637
Overdrive
Sittin' Sideways
Overdrive's Avatar
...does it like the D?
-O/D
2016 FR-S, Hot Lava
Old 02-01-2017, 01:46 PM   #15638
MJones_RB
MJones_RB's Avatar
I used this kit.
Thanks for the great links! Will def do this.
