Old 12-05-2016, 10:29 PM   #1
Mazikowski
Drives: 2013 GBS BRZ Limited
Shifter rattle
I recently replaced my clutch and throwout bearing because the bearing collapsed on me. Once I got the car put back together I noticed it has developed a rattle in the shifter. At first I thought I just forgot to tighten the rear shifter bushing, but I went back under the car and it's just fine.
I found that when it is rattling I can push it between 5/6 or over toward reverse and the rattling will stop. I'm guessing it's the shift linkage. Everything is together like it should be.
Upon further inspection there is some sort of green grease looking stuff on the transmission tunnel above where I believe the linkage goes in... any ideas?
Mazikowski is offline   Reply With Quote
Old 12-06-2016, 02:49 AM   #2
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Does it only happen when above 4000rpm?
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
Stang70Fastback (12-08-2016)
Old 12-06-2016, 06:18 AM   #3
Mazikowski
No, it happens at idle and low rpms mostly.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old 12-06-2016, 08:26 AM   #4
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
Green grease? Do you have a kartboy short shifter?
Those are cursed with rattling but usually at higher rpm. It is because of the reverse lock out spring.
Kayysonie is offline   Reply With Quote
Old 12-06-2016, 08:50 AM   #5
Mazikowski
Nope, stock shifter. The grease is further up the tunnel.
Old 12-06-2016, 08:56 AM   #6
Mazikowski
Here it is sitting in a parking lot at a warm idle.
Old 12-08-2016, 03:28 AM   #7
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Not to jack the thread but I actually have this issue lol, is it common? I hear a buzz/rattle from the shifter when I'm accelerating hard, especially in like 3rd gear. If I put any slight pressure on the shifter while in gear, the buzz stops. I have a Perrin RLO but I had that installed months before I ever started hearing this noise.
@Mazikowski where is the rattle noise originating from? Under the shifter? In the video it's hard to get an idea for any positioning on the rattle.
treminaor is offline   Reply With Quote
Old 12-08-2016, 07:15 AM   #8
Mazikowski
@treminaor it sounds like it's under the shifter, yeah. Not like the shifter is loose, but a little further down. Like I said, at first I thought it was the rear shifter bushing based on where it was coming from.
Old 12-08-2016, 02:36 PM   #9
treminaor
"DGM BRZ"
treminaor's Avatar
Have you tried running the car with the shift boot off to see if you can further narrow down the noise?
Old 12-08-2016, 02:45 PM   #10
Mazikowski
Not yet, but that's a good idea. I'll give it a chance when I have time to take the interior back apart.
Old 12-08-2016, 06:54 PM   #11
dhuang
dhuang's Avatar
Yeah, it's a common issue. I believe it's from the reverse lockout ring.
http://www.ft86club.com/forums/showthread.php?t=50512
treminaor (12-08-2016)
Old 12-08-2016, 10:33 PM   #12
Guys, that's coming from inside the transmission. Something about the gear selector components is slightly out of adjustment or sticking. I haven't yet had mine apart but I've heard similar.
Try while running at a standstill with clutch engaged just like in the video clip. Nudge the gearshift towards third and fourth ever so slightly. Does either direction make it stop or get worse?
Old 01-30-2017, 09:30 AM   #13
Mazikowski
I crawled back under the car this weekend to have another look around. Turns out one of the nuts holding the transmission mount bushing to the mount had backed off so that the bushing was able to flex and was causing the rattle. I replaced the nut and haven't heard anything since.
The Following User Says Thank You to Mazikowski For This Useful Post:
Tcoat (01-30-2017)
Old 01-31-2017, 05:08 PM   #14
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I got a new transmission two weeks ago and I *think* the rattle I had over 4k RPM ever since I bought the car is gone!
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Audible shifter rattle Hanzo Issues | Warranty | Recalls / TSB 134 08-17-2022 02:34 AM
Shifter rattle? ThisGuyRett Issues | Warranty | Recalls / TSB 11 07-30-2016 11:23 AM
TRD short shifter rattle fix morrisonmagic Engine, Exhaust, Transmission 2 06-01-2016 10:30 AM
rattle from shifter at 5k.+ rpm MurderRider Issues | Warranty | Recalls / TSB 11 02-01-2015 05:02 AM
BRZ Shifter Rattle TSB sc0urge BRZ First-Gen (2012+) — General Topics 2 08-26-2013 08:53 PM
