Old 01-14-2017, 02:51 PM   #29
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
http://www.ft86club.com/forums/showthread.php?t=113438
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 01-14-2017, 03:44 PM   #30
Ashikabi
Ashikabi's Avatar
Originally Posted by Bramick View Post
Thanks
Old 01-15-2017, 07:45 PM   #31
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Where are we at on that wing btw
It's not going to be anything done in the next month or two, a lot still has to happen to make it happen but we're working on it!
CFD images are uploaded .
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Bramick (01-16-2017)
Old 01-27-2017, 01:17 PM   #32
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I can't find the weight of the front and side splitters. Did I miss something ?
Envoyé de mon Nexus 6 en utilisant Tapatalk
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 04-15-2017, 08:36 PM   #33
NoGoodNames
Drives: Toyota GT86
Is the new two piece kit the performance equivalent of the old one piece but significantly cheaper?
NoGoodNames is offline   Reply With Quote
Old 04-15-2017, 08:43 PM   #34
VerusEric
VerusEric's Avatar
I'll work on getting an estimate on the next batch of these.
That's correct but the two piece does not receive the strakes currently. It's something we're looking into doing in the future.
Thanks,
Eric
Old 11-25-2017, 06:13 PM   #35
arthur93
Drives: Toyota 86 GTS
Hi in regards to these side splitters. Once installed, can the jack stands still be placed on the pinch welds? Looking at the design, it seems as though if the vertical piece is installed, you won't be able to but if just the side splitter is installed, looks like you may be able to
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Old 11-26-2017, 06:23 AM   #36
johan
Drives: '14 981CS, '99 NB1
I don't. It's definitely not a good idea. There's not enough clearance.
Directly behind the pinch welds where you would have placed the jack stands, there are little "bumps" in the floor pan that are actually the perfect size for jack stand teeth. I lower the car onto those, carefully.
I've had the car up in the air many many times since installing the splitters, it's a bit of a PITA but once you get used to it, it's fine.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
arthur93 (11-26-2017)
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
YCW Engineering Dry-Carbon Driveshaft YCW Transmission and Driveline 0 09-29-2016 01:36 AM
USED CARBON FIBER APR FRONT SPLITTER genometuning Exterior Parts (Aero, Lighting, Etc.) 9 04-27-2016 03:01 PM
FS: carbon fiber Password JDM side skirts and carbon fiber 3 pce BRZ front splitter protpibe Canada Classifieds 9 02-07-2016 10:37 PM
Carbon fiber splitter 300 Mr. Exterior Parts (Aero, Lighting, Etc.) 10 10-18-2015 11:10 AM
