Master Cheif
Drives: Subaru BRZ 2016 Metallic Ice Silver
BRZ intergrated mirror turn signals
Full replacement Led mirror turn signals convex and defroster polarized blue lens pictures of install.
The company that produces them Thespeedline cost about $105 shipped Install requires removing the door panel, mirrors left and right side, and taping into the factory turn signal wires located beneath the drivers fuse box. Install time 3hrs if you haven't removed a door panel, center shifter panel before. Tools needed, wire strippers, Philips #2, socket and ratchet, nitrile gloves for rubber butyl removal, small angled wire cutter, heat shrink, crimpers, t-taps RED, zip ties, test light/multi meter, electrical wire to extended passenger wire to fuse box. Quality of mirrors feel of good quality and workmanship I recommend these. REXS EED mirrors come from the same factory as these without the intergrated turn signals FYI. "Tip when routing wires from the mirror housing run the wires thru the top of the weather strip lining don't go thru the gasket between the door and body because it is one long piece starting from the top and runs down the gasket into the vehicle" if you ever seen the diode dynamics video on installing their full replacement mirror assembly they pull off the gasket and run the wire on top of the gasket and not inside, that can cause a short and wires are visible and can lead to chafing of the wires. Last edited by BRZ-086; 01-27-2017 at 08:15 AM. |
#2 |
Certainly increases visibility a bit.
#3 |
Drives: 2016 Subaru BRZ Series.Hyperblue
Any pics of what the mirror looks like with the LEDs off?
#5 |
*Some really cool title*
Kind of stupid imo. If I wanted that I would've bought a mercedes
#6 |
The Gunshine State
Drives: '14 BRZ Limited
I'm surprised side blinkers weren't a standard option, almost all the cheap econobox cars have them already. They actually are very useful when changing lanes.
![]() Current DD: M235i |
| The Following User Says Thank You to 8RZ For This Useful Post: | Premium 615 (11-01-2017) |
#7 |
Drives: 2014 FR-S
Convex too?
#8 |
Master Cheif
$104.20 shipped.
It is also convex, eliminates blind spots Below turn signals off shown. Last edited by BRZ-086; 01-27-2017 at 07:28 AM. |
#9 |
Master Cheif
#10 |
Master Cheif
Just posted some, your welcome
Secrecy is security and security is victory.
#11 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Looks nice
#12 |
Drives: stx class lava frs
Looks nice.
#13 |
Drives: Toyota 86
I just bought my 86 and I got these mirrors.
I'm thinking about bringing it in for them to fix some annoying rattling on both doors. Think I can convince them to install these for me when they have the door panels off anyways? |
| Tags |
| brz, intergrated, led, mirrors, turn signals |
| How to take apart frs Turn Signals? | Hentai | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 10-12-2016 12:49 PM |
| Turn signals don't always automatically turn off | one2onejackpot | Issues | Warranty | Recalls / TSB | 6 | 04-18-2016 07:35 AM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| LED turn signals on side mirror | Shindig | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-22-2013 12:40 AM |
| Need help with LED turn signals. | Khalis | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-11-2012 11:23 PM |
