Old 01-25-2017, 12:33 PM   #183
Racecomp Engineering
Blerp
Old 01-25-2017, 03:14 PM   #184
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
teaser
Expected pricing and availability? Are they expected to fall between the T0 and T2 on pricing?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 02-01-2017, 06:19 PM   #185
yberther
yberther's Avatar
Drives: '13 SWP Limited
...We will be releasing a custom valved Bilstein non-ajustable coilover soon with 400 lbs/in springs (linear) soon. Price is more than B14s but remember these are custom valved with custom linear springs. From our testing...AWESOME ride quality and performance that's great too...
B14's are ~$1k. Hinted at both stock top hats and aftermarket adjustable ones.
yberther is offline   Reply With Quote
Old 02-02-2017, 02:17 PM   #186
PMing you.
Hyper4mance2k (02-04-2017), yberther (02-15-2017)
Old 05-02-2017, 11:18 AM   #187
Kenny_LongWrench
Tacticool_BRZ
Kenny_LongWrench's Avatar
Drives: ZC6 - AW11
Little of an old bump, but I didn't feel as if this needed a new thread.
Looking into going linear for my B14's, sticking with 60MM Swift springs in 5k/6k or 6k/6k. Also using DIF tophats (1" extended)
The length of spring is where I'm at a loss. I have seen a few 6" with tender/helper springs in the front. Also have seen 7". Is it advisable to run tender/helper springs regardless? Do the rears need the same length or should I use longer?
EDIT: Looks like I missed a page on here. Questions answered.
Kenny_LongWrench is offline   Reply With Quote
Old 09-02-2021, 02:07 AM   #188
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Blerp
Resurrecting a dead thread.
Curious what the best linear springs rates would work best to fit into the B14.
I was thinking of doing Swift 60mm 8" 5k Front and 7k Rear
Not looking to revalve yet
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 09-02-2021, 10:56 AM   #189
What kind and what size tires? Any other suspension mods?
- Andrew
Old 09-02-2021, 12:13 PM   #190
Aztec
Aztec's Avatar
- Andrew
Running 265/35/18 square.
I was on OEM sway bars, but going to be adding a 22mm whiteline front sway on soft (115% stiffer than OEM)
16mm Perrin rear sway on hard (115% stiffer than OEM)
both added today.
Goals: Daily driving comfort (within reason)
Occasional Track day & hillclimb several times a year.
Be able to keep a similar ride height to what I have now, ~1"-1.5" drop all around. B14s allow height adjustment just need to ensure the springs match the shocks. I don't mind having the Shocks re-valved, but since it's a daily I don't want it too stiff either.
I am mainly trying to help with high performance handling and some of the 'bumpiness' that comes with the progressive springs on the factory B14.
Also helps that you get a ton more clearance with linear springs. (Running 18x10 wheels)
The 60mm 8" Swift springs were the ones I was primarily looking at, just trying to decide the spring rates.
Also trying to get a Cusco Tower Strut brace installed, but I have an Edelbrock SC and going to need some kind of custom tower strut tops/spacers to make it fit properly.
NEW CAR!🚨🏎️⛽
Old 09-02-2021, 12:26 PM   #191
What kind of tires? That's more important than width. (sticky 225 has more grip than 265 all season for example).
I am not sure if the progressive standard springs on a B14 will clear 265s, so yes linear springs make sense.
- Andrew
Old 09-02-2021, 12:40 PM   #192
Aztec
Aztec's Avatar
- Andrew
300tw Bridgestone Potenza Sports
A newer tire that is very similar to the PSS and PS4S.
I think when I get a dedicated wheel/tire set up I'll go down to 200tw and then get stiffer springs and revalve the shocks.
Hence my original plan of 5k front and 7k rear.
Currently running 3mm spacers in the front and I don't rub, but it's too close for comfort with the wider progressive springs.
NEW CAR!🚨🏎️⛽
Old 03-04-2023, 06:29 PM   #193
Mr_Brian
Does anyone have any pics of 6'' 5k springs in the front with helper springs? I'm most likely going to modify my b14s and want to see what the ride height is like with that setup. Also does anyone know of a good place in NJ or east coast that rebuilds/revalves bilsteins?
Mr_Brian is offline   Reply With Quote
Old 03-04-2023, 07:35 PM   #194
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They are on the west coast, but you may want to contact someone reputable like ShaftworksUSA about what you want to achieve. The price is pretty steep though, may be cheaper to sell the B14's and buy something different. A quick google search shows a few places that can do it though.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Mr_Brian (03-04-2023), strat61caster (03-04-2023)
Old 03-04-2023, 08:10 PM   #195
Mr_Brian
I got them for such a good deal I figured I'd have a go modifying them with different springs worse case scenario they suck and I sell them with stock springs.
Old 03-04-2023, 10:42 PM   #196
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I was a few tenths out from trophying my first time at Lincoln last year at Spring Nats with B16 and the progressive rate springs, good compromise on street/fun, but at Lincoln I had the damping turned all the way up with no more to give. Decided to switch instead of revalve.
East coast I’m aware of Redshift Motorsports, they usually work with BC but they may be able to valve the Bilstein to what you want.
When I contacted Bilstein they had shut down their in house revalve and service and pointed me to PSI in Sonoma CA. That might have changed though.
I used an 8” 325# spring up front with no issue, no tender, no good pictures unfortunately, you shouldn’t have much issue getting the ride height you want with some fiddling. I also used a stiffer 7” at some point iirc but my front were always pretty close with minimal spring preload so I only ever used helpers in the back iirc.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Mr_Brian (03-05-2023), NoHaveMSG (03-05-2023)
**NEW**Bilstein B8 HD Struts and Shocks Released FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 09-12-2016 02:54 PM
Bilstein B6/B8 and B14 shocks setting Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-26-2014 11:24 PM
Swift Spec R with Bilstein B8 shocks? JMoore412 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-23-2014 02:52 PM
Bilstein shocks & struts Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-31-2013 03:56 AM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 04:12 PM
