Old 01-24-2017, 11:29 AM   #1
celek
Resident Gear Head
celek's Avatar
CAN Language for Cluster
Does anyone know, I am sure there are some companies that I have seen for CAN converter to communicate with the OE cluster.
Are the CAN signals Subaru based from the ECU? I would assume so. OR Toyota?
Has anyone decoded and reverse engineered the CAN language?
Is it published somewhere?
Would love some help on a spare shell I have sitting around. The stand alone I want to run has its own CAN language and I would need to build an IO converter to run the stock cluster... Or a Race pack
celek is offline   Reply With Quote
Old 01-24-2017, 11:40 AM   #2
MRS-Colin
Drives: 2001 Impreza 2.5 RS
The signals are Subaru, but with the newer Subarus they changed the message ID's and some of the data got moved around.
I've worked pretty extensively to reverse engineer the signals, but I've only gotten so far. What standalone are you planning on using? Documentation for most aftermarket ECUs is pitiful at best when you really know what you are looking at.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 01-24-2017, 11:46 AM   #3
celek
Resident Gear Head
celek's Avatar
https://www.diyautotune.com/product/...harness-w-ecu/
https://www.ampefi.com/_downloads/ms...nual_1.4.0.pdf
Old 01-24-2017, 11:58 AM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Did you change your engine plans? :
Old 01-24-2017, 12:13 PM   #5
celek
Resident Gear Head
celek's Avatar
No I found a spare shell
The Following User Says Thank You to celek For This Useful Post:
DustinS (01-24-2017)
Old 01-24-2017, 12:14 PM   #6
DustinS
DustinS's Avatar
I am an idiot. You even said that in your first post. Sorry!! Excited to see where you go with both cars.
Changing nav unit language? Garuda Electronics | Audio | NAV | Infotainment 4 02-23-2015 03:46 AM
DANG! Porsche from hell! NSFW (Language) suaveflooder Other Vehicles & General Automotive Discussions 18 04-18-2014 02:59 PM
led cluster help Grip Ronin Cosmetic Modification (Interior/Exterior/Lighting) 12 02-14-2014 12:29 PM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 11:09 AM
AutoWeek vid review on GT-86 (german language) HitTheGas FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 04-07-2012 03:06 AM
