| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#351 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Definitely like it better than the +45 offset wheels though. |
#352 |
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
![]() I knew I wasn't going with wider tires (wider than 245's) before getting the set of +35's. I've seen the minimal poke of the same wheel setup that I have last summer and I thought it's acceptable. If I were to go with wider tires, I'd have gone with the +45 and added a 3mm spacer to avoid tie rod rub. I was torn between the RPF1's and the MachV Awesomes in 17x9 +42. I decided to go with the RPF1 17x9 +35's for a few reasons. I wanted to see what having a lighter wheel/tire setup would feel like. Was pretty dead set on MPSS' and they don't come in 255/40's... I didn't want to have to deal with spacers (so I didn't get the +45) to avoid tie rod rub on full lock. No extra holes on the wheel from a different bolt pattern. ......... If the Mach V awesomes didn't have the extra holes for the 5x114....it'd have made things a lil more tougher to pick between the two. I may have gone with it cause it'll keep the tires from poking out better...plus the ability to fit a BBK. If I get bored of the RPF1's, I may get a set of awesomes along with some DWS06's or P Zero AS. Last edited by SHWNBRZ; 01-19-2017 at 07:38 PM. Reason: Car pic |
| The Following User Says Thank You to SHWNBRZ For This Useful Post: | smg1138 (01-22-2017) |
#353 |
Drives: 2013 Asphalt FR-S
Size: 17 x 9
Offset: +35 Color: Bronze Tires: Continental ExtremeContact DW Tire Size: 245/40/17 Drop: H&R Super Sports |
| The Following User Says Thank You to FatFree For This Useful Post: | korhun (06-16-2019) |
#354 | |
Drives: GT86
HKS UEL manifold
Milltek overpipe Berk frontpipe with 200 cell cat iNvidia Q300 catback exhaust JBL OEM sound system |
#355 |
Drives: 2013 Ultramarine FR-S
For +45 17x8 is pretty much identical to stock wheels. Stock is 17x7+48? At +35 it should make you sit more "flush" as it pokes your wheels out more fitting the space better imo. 17x9+35 is the way to go though. There should not be any additional wear of any kind on stock height.
#356 |
For those wondering what having the 17x9 +35 with 245/40's on -2.0 camber up front....0 toe. Steering wheel was straight for the shot. I'm dropped about 1.2" from Tein Flex Z's. Everything else is stock. No additional camber bolts and what not.
![]() ![]() ![]() ![]() ![]() Note the angles of the shot. The fender doesn't go straight down...it's angled...you can see how the tire tucks in relative to the angle of the fender's flat part. |
| The Following User Says Thank You to SHWNBRZ For This Useful Post: | FatFree (01-24-2017) |
#357 |
#358 |
#359 |
Drives: 2013 Pearl FR-S
#360 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
Where can we source Enkei GOLD touch up paint for the RPF1s ?
(tried searching, no luck yet) anyone got a source or a color code ? |
#361 |
Drives: SWP BRZ Limited Manual. 2014
Tried searching but anyone on 245/45R17 MPSS?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
#362 |
Enkei refuses to sell customers touch-up paint in its "secret recipe" colors. This is a lost revenue opportunity and pisses off their customers.
So I searched around and found this touch-up pen in a 99% match for Enkei Gold, see pics below. It's an old Subaru OEM color. Pen costs about $20 shipped. It's crazy how much enkei's paint color appears to shift based on lighting conditions. Every paint vendor has their own blends, some match better than others. This particular one is really close. YMMV! link: http://www.2-tip.com/products/2tip-1308-35681 ![]() UPDATE: Second source, 99.9% match !! http://www.ebay.com/itm/172311854193 Last edited by canyons; 02-18-2017 at 12:09 PM. Reason: tags |
#363 |
Yes, running 245/45R17 MPSS on 9 inch rear wheels. Fronts are 225/45 R17 8" wheels. ![]() here's another angle: http://imgur.com/szaFody |
#364 | |
Drives: Asphalt Scion FR-S
I've been looking for bronze for almost a year now ![]() Sent from my iPhone using Tapatalk
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 11:34 AM |
| Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question | Victor Draken | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-19-2013 01:28 PM |
| Track wheel Enkei RPF1 in 16" ?? | stockysnail | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-07-2013 09:13 AM |
