| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
I love the general forum.
#16 |
Drives: BRZ 2017 Pure Red, MT
Sure the keys can be reprogrammed, but in this case, it's the car that need to be reprogrammed, so that all 3 cars have the same code. Maybe it's possible, but i'm sure there is no "official" way to do it by the dealer. That would really be complex to do I think.
#17 |
Drives: 2017 BRZ Ltd Perf-Pack
Keyless access fobs can only be programed to one car, if it has been done once, that's it. It cannot be reused for another car unless someone has a way to unbind the fob'so memory setting (Subaru cannot IME). Keyed cars I BELIEVE would be able to technically learn the security portion to multiple vehicles, but between the fob and mechanical key issues it's pointless.
#18 | |
Funny that on a forum where people don't think twice about swapping an engine and all the electronic requirements that go with it are so positive that this can not be done. Of course it can be done but nobody in their right mind is going to pay what it would cost to do it.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (01-21-2017) |
#19 | |
This all sounds like a business opportunity to me (multiple car key fob, like a universal remote). I guess it depends on whether or not the specs are published so you could do it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#20 | |
#21 |
Drives: '14 Subaru BRZ
I can't comment on Subaru, but when I worked at a Chrysler dealer we could only have one programming on the fob (which is the key). So you couldn't buy somebody else's old fob and get it reprogrammed to your car.
Now I work at a BMW dealership. There's no programming/reprogramming of keys. When the car is built there are a total of 10 keys made. Two keys come with the car, and the other 8 stay in Germany. If you need a new key, it gets shipped from Germany. If for some reason you lose all 10 keys, you need a new CAS module. The CAS is basically and anti theft device. The key communicated to the CAS etc, etc. Everybody does things differently. I'm not saying it's impossible to have it done, but it's highly improbable. The only way I see it working is to get a car that doesn't have push button start, code the three cars' ignition and doors locks the same, and then use one key for all three. But if you're too lazy to grab the proper key for the car you're taking, you're probably far too lazy to unlock your doors with an actual key, then put the key in the ignition, and then turn it.
Life's too short to drive a boring car
| The Following User Says Thank You to HeadBanger For This Useful Post: | why? (01-21-2017) |
#22 | |
Only happy when it rains.
Drives: series.blue
I just assume their key machine was barely changed between each key, and they figured the odds of two numbered cars going to the same place was next to zero. |
| The Following User Says Thank You to why? For This Useful Post: | Dadhawk (01-21-2017) |
#23 | |
Coincidentally, just had to do this with the key fob from MomHawk's Mustang. She got new ones as a gift that had a pink cover (the buttons on her originals are starting to act up). Pretty simple process, and makes me think its the car that is programmed to the Fob, not the fob to the car. With the door closed and your foot off the brake, you turn the ignition from Off to Run 8 times in 10 seconds. The locks will cycle once to let you know its in program mode. You then press the door lock button on every fob you want to work within 20 seconds (including the originals). I did four of them. I'm guessing if you had another Ford (I don't) you could do the same thing on a second car and have the fob open both cars. The list on the instructions pretty much listed every major model Ford built between 2002 and 2012. That, of course, doesn't help with the key. For the key you would have to physically change the locks. I would imagine that the tech for keyless start is more sophisticated though.
| The Following User Says Thank You to Dadhawk For This Useful Post: | why? (01-22-2017) |
#24 |
I think I saw once it was once out of about every 3,000 cars have the same locks around that time.
The killer part is it was the same model/color and that we both parked in the same parking lot close enough for me to find it (my car was just a few spaces further out in the same row). Probably used up all my lottery luck on that one.
#25 |
Drives: BRZ DGM Limited
Just tape all three fobs together with electrical tape and you're good to go.
| The Following User Says Thank You to BRZnut For This Useful Post: | Dadhawk (01-23-2017) |
#26 | |
Drives: DE5 Integra Type S
best solution! Solved...
"Precision without speed is empty, speed without precision, chaos."
| The Following User Says Thank You to Ghost of Akina For This Useful Post: | Dadhawk (01-23-2017) |
#27 |
In high school my buddy had a 71 Dart, one day we found out quite by accident that his door key opened another Dart and the ignition key worked on it too. We thought it was pretty cool so we started trying it on other Darts as we cam across them then Dusters and then we figured why not try all sorts of other Chrysler products. Those keys worked on so many cars it was amazing. We always wanted to just move cars around but never had the balls to follow through until a friend of ours whose dad was a cop had a Dodge Aspen and we found out that the ignition key worked on that too. Well this guy was a real ****, slept around, abused his mom, etc. so one night when he was passed out drunk we took the car from his house to his girlfriends house and left it there. The next day when his mom left for work they realized it was gone so he called it in but she spotted it first on her way. You can imagine the shit pretty much hit the fan at that point. We were so proud of ourselves
| 19 inch ESM 002R (bbs look alike) | MileHighBRZ | Wheels and Tires | 6 | 05-03-2015 05:23 PM |
| Great minds think alike .a little sibling rivalry | suaveflooder | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 04-20-2014 12:40 AM |
