| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2059 |
Drives: '13 SWP ZC6 R
Is this a track car or street car? I really doubt you'll see much of a real world difference between a 265 and 275 in terms of grip, and a 265 can be (relatively) easily shoe horned under your front fenders. With a square setup, you retain proper handling characteristics of the car and ability to rotate.
For "10" mm extra tread out back, you sacrifice so much....
#2060 |
Drives: 2014 UltraMarine FRS
Its just a street car... Im just going more for that "wow" factor. I love the tread design on the INVOs, thats mainly why Im going with those tires.
I originally was just planning on going with 235/40 and 265/35, which is a fairly common set up. And Im already planning on rolling the fenders to be on the safe side. I just happened to come across Texasbound's posts and wanted some thoughts and opinions
#2061 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
![]() If I'm choosing between tyres I'll check how the tread and side wall looks. I like a square side wall as well as a race-car looking tread pattern :-) Currently I'm using Bridgestone RE003 that I don't think are available in USA or they have a different model but do like the Nitto INVO "look" and had them before this set.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#2062 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
...racecars don't have tread patterns
| The Following User Says Thank You to Jive Turkey For This Useful Post: | DustinS (01-10-2017) |
#2063 |
Drives: FR-S 10 series
265/35/18 continental dws 18x9.5 +35
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
#2064 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#2065 |
Drives: WRB Brz / SR S14
#2066 |
Drives: 2017 WR BLUE BRZ
#2067 |
Never mind found your build thread, awesome car!
#2068 | |
My FR-S has 5 gears
Omar GC
| The Following User Says Thank You to OmarGC For This Useful Post: | ILLSMOQ (01-19-2017) |
#2069 |
#2070 |
My FR-S has 5 gears
You'd have to run a between a 10-15mm spacer up front I'd guess to not hit the frame at full lock would be my guess. Rear would be ok with an aggressivs pull
Omar GC
#2071 | |
I'm doing a LS swap and shooting for 500+ at the wheels, so I need big rubber under my car and I like how your car sits and looks in all the pictures...but I need it to be usable with aggressive driving in the "back roads" know what I mean? I'm pretty much thinking to go with your set up or do a wide body with 315's or 335's, though I'm not really excited to do a wide body. What would you advise? |
#2072 | |
My FR-S has 5 gears
I can't recommend doing adjustable RUCAS (rear upper control arms) or RUCAS offset bushings paired with lower control arms for camber correction enough. But honestly, I don't feel any need to go widebody. I'm pretty confident that a 305mm section width tire will fit under the 86's factory quarters. I'm going to attempt it in the future, I would like to go widebody... but the stuff I want isn't very affordable lol
Omar GC
| The Following User Says Thank You to OmarGC For This Useful Post: | ILLSMOQ (01-20-2017) |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
