Old 01-12-2017, 01:01 AM   #253
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Yep...the youngins woke up ...time to vacate... LMBO
vintagemxer is offline   Reply With Quote
Old 01-12-2017, 02:07 AM   #254
YW-Slayer
Drives: 2013 BRZ (MT, WRB), 2005 Legacy B4
I have a manual and drive it I hilly and congested Hong Kong. I rented the automatic when I went to Australia, and while it's fine, I feel that it really dampens innate character, involvement, and purpose of the car. Manual all the way for this car.
Sent from my SM-G930F using Tapatalk
YW-Slayer is offline   Reply With Quote
Old 01-12-2017, 02:39 AM   #255
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by ysu View Post
Err...can I just interject here a bit?
Not quite correct cons for A/T:
You've pretty much full control over it when you want to, using the paddles (move the shifter sideways and apart from 1st gear start, it's like any other gear change except you get rev matching added)
Of course you can.
Procedure:
- Get rid of the TC (5s button press)
- Press the brake hard
- Step on the throttle
The revs will start rising. The rears will start spinning somewhere slightly over 2k rpm.
Burnout achieved.
Having stock tyres helps, sticky ones are harder to get spinning, and keep spinning.
If you step on the gas slightly first and then the brake I have heard you can rev past 2k even. Have yet to try it myself though
Ultramaroon (01-12-2017)
Old 01-12-2017, 02:41 AM   #256
ysu
Drives: Toyota 86 GTS Auto
I've tried that a number of times, but it just did not work. I don't know why it would work to be honest. I think it's a misinformation.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
The Following User Says Thank You to ysu For This Useful Post:
Old 01-12-2017, 03:13 AM   #257
Razgriz
Drives: 2016 Scion FRS Release Series 2.0
Late to the party but I drive an auto and I enjoy it. Would I have prefer a manual, sure but there were many reasons that made the decision for me to get it as an auto. There are pros and cons to be and it will always be a personal choice. As Ultramaroon said way earlier if you're even asking this question it's probably best you do or learn it and then decide if you want it as a manual otherwise you'll always have this lingering doubt in your head about it.
Main reason I went auto was I wasn't going to be the only person driving this and the price difference between the base model and the RS 2.0 which was available only as an Auto wasn't nearly as drastic and so I went with that.
Razgriz is offline   Reply With Quote
The Following 2 Users Say Thank You to Razgriz For This Useful Post:
arrow34 (01-18-2017), Ultramaroon (01-12-2017)
Old 01-12-2017, 03:24 AM   #258
I truly feel the auto in this one is the best I've ever experienced. By second gear the torque converter is completely locked and the shifting in manual mode is crisp and already faster than the best, lightest manual in existence. The only thing faster is a DCT but I've never had the pleasure.
Old 01-12-2017, 11:49 AM   #259
Twrx2013
Twrx2013's Avatar
Drives: 2013 Subaru Impreza Wrx
I learned manual on my wrx, it's fun and makes driving the car more exciting. save the manuals
Sent from my D6603 using Tapatalk
Twrx2013 is offline   Reply With Quote
Old 01-12-2017, 11:57 AM   #260
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
What!?...misinformation on the internet? I can't believe it.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
why? (01-16-2017)
Old 01-18-2017, 11:32 AM   #261
Darkone
Darkone's Avatar
.... seriously missing out on the experience I think..the standard is allot more engaging which is the whole idea of this car...
No mind? TakuanSoho:.. even if your mind seems to be moved, do not let your mind be taken.
無心の心
Darkone is offline   Reply With Quote
Old 01-18-2017, 12:08 PM   #262
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
While I agree it is more engaging and some magic is lost not having the 3rd pedal and shift gates, in manual mode it's a pretty good automatic for aggressive driving. The handling aspect of the car is unchanged, and it's still very fun and engaging. They could have tossed any crappy slushbox in here, but they put a decent one in here that can pull double duty for commuting and for fun driving.
My left leg sure is getting lazy these days, though...
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 3 Users Say Thank You to Overdrive For This Useful Post:
arrow34 (01-18-2017), Tcoat (01-18-2017), why? (01-20-2017)
Old 01-18-2017, 01:28 PM   #263
arrow34
Drives: Firestorm red FRS 2015
I just give you props for driving in Hk. Downtown central is crazy and I have never driven in hk... Frankly afraid to! The bus drivers alone are pin-point drivers.
arrow34 is offline   Reply With Quote
Old 01-18-2017, 01:40 PM   #264
And doing elevens is not "burning out". In fact if you burn out on launch with these you will be lucky to get 12s.
Oh, I just got this. I wasn't talking about ET.
These are "11s."
Tcoat (01-18-2017)
Old 01-18-2017, 01:57 PM   #265
Da Brz
Drives: 2016 Subaru BRZ
One pro for an auto is that you're resale is probably a couple grand better when you try to trade or dump it.
Da Brz is offline   Reply With Quote
Old 01-18-2017, 02:58 PM   #266
Darkone
Darkone's Avatar
Well if I drove the car as a daily driver... I would have opted for an automatic. Shifting during rush hour traffic in traffic jams is no fun...
無心の心
know it all, richardsfrs sucks
