View Poll Results: What oil
Mobil 1 113 41.70%
Castrol Syntec 38 14.02%
Valvoline Synpower 6 2.21%
Quaker state/ Q horsepower 5 1.85%
Penzoil Platinum 17 6.27%
Royal purple 28 10.33%
Eneos 5 1.85%
TRD oil (dont know if still available) 6 2.21%
Castrol "think with your dipstick jimmy" Edge 10 3.69%
..... motorcraft?....... 2 0.74%
Other. please specify 60 22.14%
Multiple Choice Poll. Voters: 271. You may not vote on this poll
Old 09-19-2010, 06:05 PM   #71
Conor
Drives: '93 Toyota MR2 - V6
72 posts on oil and we don't even know much about the engine yet? :|
Dino juice every 3,000 miles will keep it running forever, if Toyota engineers are involved in any way. I run Mobil1 in my Toyota engines, but it's not really making a difference. I see tons of Toyotas with 100-200,000 miles on them that just come into the dealership for regular 5,000 mile oil changes and you couldn't ask any more from these engines..
They're just fine on regular ol' oil
Conor is offline   Reply With Quote
Old 09-21-2010, 12:15 AM   #72
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
this. my tacoma has 119,300 miles on it now. nothing but regular GTX or toyota (when i'm feeling lazy and i have them change it) oil every 3,000-4,000 miles and it's running like a champ.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 10-09-2010, 11:39 AM   #73
virobloc
virobloc's Avatar
Drives: Toyota GT86, MT, Kyuzo Red
I'll use what Toyota says in the manual. Surely Castrol...
I think that they would know better than me what's best for the engine.
In addition, I think, as miss Lauren said, standard is better
virobloc is offline   Reply With Quote
Old 11-09-2010, 03:18 PM   #74
Dark
Elite Padawan
Dark's Avatar
Castol GTX 5w30 conventional oil.
Dark is offline   Reply With Quote
Old 02-23-2011, 01:52 AM   #75
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
Shell Rotella 5W40
A lot of the STI guys on forums have had long discussions about this. Most tend to steer clear of Mobil1 5W30 Synthetic since it tends to sheer down to lighter weight faster than most other synthetics. Yes, the STI has a turbocharged EJ and we're getting a (most probably) NA FB series, but might as well keep it consistent with the Boxer.
(Note: I am NOT saying that Mobil1 synthetics are bad oils. In fact, many M1 oils like EP and HM are great, but 5W30 specifically seems to sheer in STIs.)
ryun84 is offline   Reply With Quote
Old 03-03-2011, 10:56 PM   #76
xantonin
Mr. Detail
xantonin's Avatar
Drives: 2003 Celica GT-S
I won't buy the car unless the dealer agrees to change all the fluids to Amsoil before it's driven off the lot.
rar
xantonin is offline   Reply With Quote
Old 03-04-2011, 12:11 AM   #77
NESW20
2.1L 3SGTE
and let me guess, then you'll go ahead and buy into the "oh, my amsoil is good for 15K miles without changing it! hooray!"
2008 Civic Si Sedan
Old 03-04-2011, 12:27 AM   #78
xantonin
Mr. Detail
xantonin's Avatar
No, because a new vehicle has more wear metals from the factory since it's never been broken into before.
Do you think I'm stupid or something?
On a side note, I do extend the oil changes on my current vehicle, and I also send in a sample of oil to be tested at OEM intervals.
I'd also install a bypass filter on this new car.
rar
Old 03-04-2011, 12:31 AM   #79
Dimman
Kuruma Otaku
Dimman's Avatar
Break-in wear is a bit of a myth. Properly working cars don't really have any metal-to-metal contact when they're running. Expect the rings.
Better for longevity is installing an accumulator and pressurizing your oiling system before turning the motor over.
Because titanium.
Old 03-04-2011, 12:33 AM   #80
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
I believe that will be unnecessary
Midship Runabout is offline   Reply With Quote
Old 03-04-2011, 12:36 AM   #81
NESW20
2.1L 3SGTE
i don't think you, personally, are stupid. no. i don't think what you mentioned is necessary, but i am all for preventative maintenance. i changed all oils (aside from transmission fluid) in my truck after 1000 miles, and then again at 3000 miles. 128K miles on it now, and runs like a top. no leaks, noises, or other problems. i just used normal oil, valvoline or mobil1, whatever they had in the parts store at the time that met all API guidelines and was the proper weight according to the owner's manual.
i *DO* think it's stupid when people don't change their oil for 15K miles, regardless of whatever marketing hype they believe. i am glad that you will change it closer to OEM intervals. it's not the lubricity that breaks down first, it's the detergents and other additives that are long gone by the time you hit 5K miles. normal, off the shelf oil will lubricate just fine up to 10K miles or more, not that i would recommend it, but it won't clean or protect for that long.
2008 Civic Si Sedan
Old 03-04-2011, 12:37 AM   #82
Midship Runabout
Again this will be unnecessary on a stock motor
Old 03-04-2011, 12:39 AM   #83
xantonin
Mr. Detail
xantonin's Avatar
I don't think filtration at 2 microns could hurt anyone. (Although I admit it may be excessive)
Also, for the record, the Camry's recommended oil change interval is 10,000 miles from Toyota, so I don't think 15,000 is that unrealistic. Although Amsoil warranties their oil to 25,000 with some of their filters. I could care less. I'd rather use an oil that is being backed by and guaranteed for longer and change it at shorter intervals than anything else.
rar
Old 03-04-2011, 12:41 AM   #84
NESW20
2.1L 3SGTE
i don't think it would be a bad idea to change the diff oil after a couple thousand miles. on my FT, i'll probably change the diff oil and engine oil at 1000 miles, and maybe do the trans at 10K.
the only thing i might consider doing as far as startup is concerned is bypassing the clutch-start switch so i can start the car without holding the clutch to the floor, shoving the crank against the thrust bearings. it's not a huge deal, though, as there are countless cars with multiple hundreds of thousands of miles on them that were started with the clutch to the floor.
2008 Civic Si Sedan
