Old 11-20-2014, 01:00 AM   #29
wrb.brz
Drives: 2015 Series.Blue BRZ
Same here ^. Mine started squeaking with less than 2,000 miles, glad to know I'm not the only one
wrb.brz is offline   Reply With Quote
Old 11-20-2014, 01:57 AM   #30
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Mine just started doing this at 13000 miles.
Makes a crunchy/tin like sound.
Old 11-20-2014, 08:30 PM   #31
torqdork
torqdork's Avatar
Drives: RV-7
If it does, with the Perrin unres I've never noticed.
torqdork is offline   Reply With Quote
Old 01-15-2017, 07:00 PM   #32
fl4t
Drives: '13 WRB BRZ '05 STi OBP
A way to fix the problem is to pull the carpet back a bit and spray WD40 on the Christmas tree thing. You need the straw tip for the WD40. Just use your fingers to be sure you're spraying on the right spot. It's not squeaking any more for me!
fl4t is offline   Reply With Quote
Old 01-16-2017, 01:29 AM   #33
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Nice necro. I may actually try this just so my car make one less noise
Old 01-16-2017, 03:05 AM   #34
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
Mine does it.
GenRuleAThumb is offline   Reply With Quote
Old 01-16-2017, 08:57 AM   #35
fl4t
It's still silent today as I drove to work Which I'm so happy about since I place my foot there 90% of the time. Honestly my car does not rattle at all and I've been putting on 20k/yr on roads that aren't in the best shape. It does have the fuel pump cricket noise though
Old 01-16-2017, 12:47 PM   #36
finch1750
finch1750's Avatar
113k on the odo plus bushings, camber plates, and a sway bar has lead to many clunks and weird sounds starting. The exhaust and music drown most of it out though
Old 01-16-2017, 12:52 PM   #37
If you can't fix something with baling wire, duct tape or WD40 then it can't be fixed!
Old 01-16-2017, 01:13 PM   #38
finch1750
finch1750's Avatar
Close enough. My tool box consists of duct tape, wd40, zip ties, a hammer, and a bigger hammer.
The bigger hammer is for when nothing else works you and just want to destroy whatever it is for therapeutic reasons
Old 01-16-2017, 01:15 PM   #39
PSi
Drives: 2017 86
wtf is a dead pedal?
did he mean the foot stabilizer?
PSi is offline   Reply With Quote
Old 01-16-2017, 01:23 PM   #40
I suppose zip ties have replaced bailing wire in the modern world!
Old 01-16-2017, 01:32 PM   #41
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
https://en.wikipedia.org/wiki/Dead_pedal
Old 01-16-2017, 01:33 PM   #42
finch1750
finch1750's Avatar
It's a common term. Been around a while and companies selling aftermarket pedals even market it that way.
https://en.m.wikipedia.org/wiki/Dead_pedal
Found Loose wire...?? IDK what it is rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 34 06-10-2020 01:42 PM
Red stitching is coming loose. Chip Issues | Warranty | Recalls / TSB 7 11-01-2012 11:02 AM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 01:50 PM
FR-S Stock Carpet Mats - anyone else's doing this? kramerica_industries Scion FR-S / Toyota 86 GT86 General Forum 27 08-24-2012 12:29 AM
Dead pedal height bqe-lie-fdr Scion FR-S / Toyota 86 GT86 General Forum 0 02-25-2012 09:21 AM
