Old 12-29-2016, 04:13 PM   #43
VeganGirl
Drives: Scion FR-S 2013
I really don't care that it gets bad gas mileage, I knew that forced induction wasn't only going to be an upfront cost, I knew that it was going to be a long term cost one also.
I just assume I get bad gas mileage cause my car is older, it was sold in 2012. And I have 70+ thousand miles. I can't expect to get perfect gas mileage when my car has been driven into the ground
VeganGirl is offline   Reply With Quote
Old 12-30-2016, 12:45 PM   #44
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Wait how is your mpg that low in Orlando? Traffic here is way worse and I still managed 18+ with Edelbrock.
Although if I were in Orlando I'd be taking 417 everywhere at like 90+ so mine would probably look like that too.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 01-06-2017, 08:20 PM   #45
VeganGirl
After doing a 90 mile highway trip my average went up to 16.5, I gues the traffic where I work is just terrible. Plus I only live about 2 miles from my job and it's all stop and go traffic
Old 01-14-2017, 02:33 PM   #46
iceman6666
Drives: 2014 FRZ
I'm getting 24 or so summer and 23 in winter. Spirited driving. Automatic
iceman6666 is offline   Reply With Quote
Old 01-15-2017, 11:17 AM   #47
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Seems like something's not right. I did a similar 100mi freeway trip with hills and averaged 29 mpg. Jumped up to 34 mpg after the supercharger was taken off.
Old 01-15-2017, 03:22 PM   #48
VeganGirl
I think a lot of it has to do with my rims.
After putting rims on my car I went from having 25-27 down to 19-20. Then after super charging, now I'm 15-16
Old 01-15-2017, 03:42 PM   #49
Somerandom18
Drives: 2017 manual BRZ
35lb rims?
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 01-16-2017, 07:43 AM   #50
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Things aren't that much better with a centri. I make the trip from Sanford to the airport a couple times a month running steady 75mph on 417. Before the Jackson Racing kit, the indicated gas mileage was 33- 35 mpg on 93 octane. I run E85 exclusively now and the indicated mileage is now 17-18 mpg. That drop is more than you would expect from the change in fuel. I may fill up with 93 one of these days just to compare the difference.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 01-16-2017, 08:45 AM   #51
VeganGirl
Omg that is way to much dedication for me to run e85 in this area. How do you do it lol? Isn't there only 2 stations here?
Old 01-16-2017, 10:21 AM   #52
Deep Six
Deep Six's Avatar
My office is near the Michigan Citgo and I also have 6 VP jugs for track weekends. I usually drive the FRS once or twice a week when I don't expect to deal with a lot traffic. Drove this morning on I4 into Orlando and actually got 22mpg cruising between 65 and 70. As soon as it's stop and go I'm back in the mid teens.
[SIGPIC][/SIGPIC]
Old 01-25-2017, 09:06 PM   #53
scraejtp
Drives: 2013 Subaru BRZ
Just to chime in, mine took a bigger dip than I expected but still not bad.
Stock car except for the Edelbrock kit, CARB tune. Car says 29 mpg after ~7k miles, reset fuel mileage at install, never reset again. This is mixed driving, ie some highway and some/long stop/go traffic.
This is still a decent drop as I recall the computer showing 33 mpg prior to the kit. So a 10-15% drop.
scraejtp is offline   Reply With Quote
Old 01-30-2017, 11:27 AM   #54
taiguy
Drives: 2013 Black BRZ Limited
There has to be some sort of physical discrepancy across cars. I find it impossible to believe that some are getting high twenties and other are getting mid to high teens, with the same hardware.
Different injectors? Something is fishy and right now all we can do is just throw our hands up and deal with it.
taiguy is offline   Reply With Quote
Old 01-30-2017, 02:14 PM   #55
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I'm curious if the year the car was manufactured makes a difference.
Although i have to say i've never been above 30 mpg even when i was stock. I averaged 29. And i just checked yesterday and i'm 26.6 mpg. So for me it really didnt change much.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 01-30-2017, 06:00 PM   #56
bfrank1972
Drives: 2013 FR-S Argento
No, it's driving style & conditions. Consider these scenarios:
1) "I commute 50 miles each way on the highway, I live in rural Indiana, I'm a safety conscious driver" = you will get amazing average gas mileage, even with a supercharger. Flat, steady throttle, car gets nice an warmed up, nothing crazy
2) "I commute 50 miles each way on the highway, I live in Florida, I'm sometimes in bumper to bumper traffic" - Flat, car gets warmed up, even with some stop-n-go, your average mileage will still turn out ok
3) "I commute 25 miles each way, back roads, I live in Connecticut" = hilly, car gets warmed up, but you're constantly changing throttle and bleeding speed with your brakes, your mileage will be significantly worse than 1 or 2.
4) "I commute 6 miles each way, back roads (or not), I live in Connecticut" = this is me, I get average of 18 mpg. Without a supercharger. On 93 pump gas. For about 1/2 the trip my oil temps are < 150 deg. It's hilly. With stop signs.
That's not even taking into account the average speeds you drive, how aggressive you are on the throttle, etc. Take these scenarios with any make/model of car and you'll see these patterns (exception might be hybrids).
OFT Tuning for Edelbrock SC Shiv@Openflash Software Tuning 37 03-01-2021 09:30 PM
EDELBROCK SUPERCHARGER BRZFRSSTORE Forced Induction 1 12-05-2016 04:41 AM
OFT Tuning for Edelbrock SC Shiv@Openflash Forced Induction 22 07-03-2016 12:43 AM
MXP SP Exhaust and Edelbrock? JGalp Engine, Exhaust, Transmission 2 05-18-2016 09:44 AM
Edelbrock's Custom BRZ with SC Lonewolf Southern California 9 08-02-2015 05:17 PM
