#141 |
4 pages. Fix your newb settings and bring on the boobs!
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#142 | |
Drives: 2016 BRZ Limited
| The Following User Says Thank You to vintagemxer For This Useful Post: | Capt Spaulding (01-09-2017) |
#143 |
| The Following 3 Users Say Thank You to vintagemxer For This Useful Post: |
#144 |
Well, actually, and to fess up, my first car was an auto. Once you stepped on the crank and got that puppy running, you got in the cockpit and pushed this steel rod with your foot that was connected to an idler pulley that tightened the drive belt that ran between the pulley on the axle and the drive pulley on the crankshaft.
The engine had a governor, however, I had a piece of baling wire that ran from the governor through the firewall, so as I could reach out and over ride the governor...... giving it "boost". Note the staggered wheels, California rake, aluminum pulley and straight through header. In addition, I milled the head on a piece of metal sandpaper on the basement floor, ground the valves with a hand grinder, installed new high compression rings and a had a "hot" spark plug. Yep ........it was a fine machine ........ but it was still an automatic ...... ![]() humfrz |
| The Following 4 Users Say Thank You to humfrz For This Useful Post: |
#145 | |
[quote=humfrz;2828722]
| The Following User Says Thank You to vintagemxer For This Useful Post: | Ultramaroon (01-10-2017) |
#146 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#147 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Three on the tree. And all I ever heard growing up was "standard gearbox."
Lately I've heard some folks referring to "manual transmissions," but I write them off as zit-faced-hot-wire-artists. It matters not how many "gears" it has, if you have push in (or squeeze) a clutch and move a lever to change actual toothed metal "gears" it is and forever will be a "standard gearbox." Now where is my "Old age is no place for sissies" t-shirt?
Slow is smooth, and smooth is fast
| The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
#148 | |
[quote=vintagemxer;2828805]
humfrz |
#149 | |
Yep, it had it's speed limitations, but at least my gal would ride with me (reluctantly). My Cushman motor scooter was faster ...... but she wouldn't get on the back of it. Maybe it was my driving ....... ?????? ![]() humfrz |
#150 | |
#151 | |
| The Following 2 Users Say Thank You to finch1750 For This Useful Post: | Ultramaroon (01-10-2017), vintagemxer (01-12-2017) |
#152 |
By golly, you may be onto something, there, @finch1750 ......
![]() Come to think about it ....... I can't recall any girl that was ever comfortable with my driving ........ ![]() I turn 74 tomorrow ........do you think I should turn in my drivers license .....?? humfrz |
#153 | |
Bonus: You can do donuts in BOTH the AT and MT so it doesn't even matter which you own! |
| The Following 2 Users Say Thank You to finch1750 For This Useful Post: | humfrz (01-10-2017), vintagemxer (01-12-2017) |
#154 |
Drives: BMW
Location: 9 Lt. J. Francisco St. Quezon City, Philippines
Didn't try it at all but thinking to try it. Then it would probably be wasted and damage all over if I tried it.
| Tags |
| know it all, richardsfrs sucks |
