Old 01-09-2017, 11:20 PM   #141
Still too early for boobs? Already 10 pages in...
4 pages. Fix your newb settings and bring on the boobs!
finch1750 (01-09-2017), soulreapersteve (01-10-2017), vintagemxer (01-10-2017)
Old 01-09-2017, 11:31 PM   #142
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Originally Posted by why? View Post
Holy crap this thread became crazy fast.
Op, the best way to learn manual is to buy a car with it. I bought my first manual car because I wanted to learn it and I loved every second of it. If you really want to learn how to do it, you should buy a manual. The 86 manual is really easy to use and would be great for a beginner.
Saying that if you really don't want to learn the auto in the 86 is not a normal auto and there is a thread around here about how they developed it.Here it is.
Great thread about the automatic transmission development in the 86. It is a must read.
Thanks...Great read
vintagemxer is offline   Reply With Quote
The Following User Says Thank You to vintagemxer For This Useful Post:
Capt Spaulding (01-09-2017)
Old 01-09-2017, 11:44 PM   #143
vintagemxer
Europe calls it 'standard', suppose it came over with the French connection y'all had. US has called it Manual Transmission forever.
The blank look on the face of anybody under about 50 when I say "oh ya it is a six speed standard" is priceless.
The Following 3 Users Say Thank You to vintagemxer For This Useful Post:
Dadhawk (01-10-2017), Ultramaroon (01-09-2017), why? (01-10-2017)
Old 01-09-2017, 11:54 PM   #144
Did your shift knobs look like this back then?
Well, actually, and to fess up, my first car was an auto. Once you stepped on the crank and got that puppy running, you got in the cockpit and pushed this steel rod with your foot that was connected to an idler pulley that tightened the drive belt that ran between the pulley on the axle and the drive pulley on the crankshaft.
The engine had a governor, however, I had a piece of baling wire that ran from the governor through the firewall, so as I could reach out and over ride the governor...... giving it "boost".
Note the staggered wheels, California rake, aluminum pulley and straight through header.
In addition, I milled the head on a piece of metal sandpaper on the basement floor, ground the valves with a hand grinder, installed new high compression rings and a had a "hot" spark plug.
Yep ........it was a fine machine ........ but it was still an automatic ......
The Following 4 Users Say Thank You to humfrz For This Useful Post:
caus (01-10-2017), finch1750 (01-10-2017), soulreapersteve (01-10-2017), vintagemxer (01-10-2017)
Old 01-09-2017, 11:54 PM   #145
vintagemxer
[quote=humfrz;2828722]
Europe calls it 'standard', suppose it came over with the French connection y'all had. US has called it Manual Transmission forever.[/QUOTE]
Back before about 1940 ...... there was no conversation about what kind of transmission. Then from about 1940 to about 1950 only the rich folks had a choice......but, the automatic went with the more expensive cars.
About 1950, the common folk had a choice ...... "standard" or automatic transmission. That's about when I started to recall that people (in Ohio at least) started to refer to a manually shifted transmission as a "standard" shift transmission.
Now, I usually refer to most automobile transmissions as a 5 speed, 6 speed or auto.
You forgot the 3 speed on the column !!! ")...This thread has become quite entertaining...hopefully the youngster who started it is enjoying it as much as me
Ultramaroon (01-10-2017)
Old 01-10-2017, 12:05 AM   #146
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Hot damn. What'd that thing top out at? 3mph after the governor override?
Old 01-10-2017, 12:07 AM   #147
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Three on the tree. And all I ever heard growing up was "standard gearbox."
Lately I've heard some folks referring to "manual transmissions," but I write them off as zit-faced-hot-wire-artists. It matters not how many "gears" it has, if you have push in (or squeeze) a clutch and move a lever to change actual toothed metal "gears" it is and forever will be a "standard gearbox."
Now where is my "Old age is no place for sissies" t-shirt?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post:
Dadhawk (01-10-2017), Ultramaroon (01-10-2017), vintagemxer (01-10-2017)
Old 01-10-2017, 12:08 AM   #148
[quote=vintagemxer;2828805]
Yep, ol @Tcoat addressed that a few posts back ...... and yep, my first car, that I could legally drive on the road, had a "3 on the tree" ....... hmmmmm ..... I wonder if I could still find my fuzzy dice ......??
Old 01-10-2017, 12:24 AM   #149
Yep, about that ...... before the front end would start to wobble (the steering gear was a half rotten piece of old cotton cloths line screwed to the front axle and wrapped around a box under the hood, which was attached to a piece of water pipe with an old Oliver tractor steering wheel on the end.
Yep, it had it's speed limitations, but at least my gal would ride with me (reluctantly). My Cushman motor scooter was faster ...... but she wouldn't get on the back of it.
Maybe it was my driving ....... ??????
caus (01-10-2017), Scrappydoo (01-10-2017), Ultramaroon (01-10-2017), vintagemxer (01-10-2017)
Old 01-10-2017, 12:29 AM   #150
vintagemxer
That's what it was...a tree LMBO !!! Sometimes getting old is just a kick in the ass
Old 01-10-2017, 02:25 AM   #151
finch1750
finch1750's Avatar
I'm starting to notice a pattern...
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Ultramaroon (01-10-2017), vintagemxer (01-12-2017)
Old 01-10-2017, 03:21 AM   #152
By golly, you may be onto something, there, @finch1750 ......
Come to think about it ....... I can't recall any girl that was ever comfortable with my driving ........
I turn 74 tomorrow ........do you think I should turn in my drivers license .....??
Old 01-10-2017, 03:25 AM   #153
finch1750
finch1750's Avatar
I'm not the one to make that call. Maybe go stop by the DMV and do some donuts in the parking lot to prove you still got it. That way the professionals there will know for certain whether to let you keep it or not.
Bonus: You can do donuts in BOTH the AT and MT so it doesn't even matter which you own!
humfrz (01-10-2017), vintagemxer (01-12-2017)
Old 01-10-2017, 03:53 AM   #154
abigailcarson73
Drives: BMW
Location: 9 Lt. J. Francisco St. Quezon City, Philippines
Didn't try it at all but thinking to try it. Then it would probably be wasted and damage all over if I tried it.
abigailcarson73 is offline   Reply With Quote
know it all, richardsfrs sucks
