Old 01-06-2017, 10:25 AM   #43
Tokay444
Originally Posted by VeloxEric View Post
I have no had any issues overheating currently with the kit even in stop and go traffic with 120 degree ambient Phoenix heat. No issues at the 1/2 mile event I've been at either. We run our radiator and hood louvers though, but I'm sure other radiators could work as well.
Thanks,
Eric
What kind of oil temps are you observing?
Old 01-06-2017, 10:31 AM   #44
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
The highest I've seen to date is 225 having some "fun" on back curvy roads.
I do not believe (and it has been proven from other forum members) that the Forester oil cooler setup would last a full 20-minute track session on full kill. I'm *currently* okay with this due to where *we're* at with the car, but an air to oil or a larger water to oil unit may be in the future if we want the BRZ to become a more track serious car.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Tokay444 (01-06-2017)
Old 01-06-2017, 10:38 AM   #45
Tokay444
Thanks,
Eric
Thank you.
Are you still running 0w20?
Old 01-06-2017, 10:39 AM   #46
VerusEric
VerusEric's Avatar
Thank you.
0w-30 Amsoil, though I'd probably be safe with 20 weight right now as I haven't seen temps over 230.
Old 01-06-2017, 06:51 PM   #47
_debo
Drives: Corsa VXR Stage 3
The kit that we recommend is twin scroll, and an UEL manifold will reduce performance. The manifold Full-Race designed and produce is very good, and there is no reason to go UEL unless you just want that boxer rumble.
Turbo placement isn't massively important. Keeping hot, fast moving exhaust hitting the turbine is a big goal, as is ensuring that the turbo can properly drain the oil from its CHRA. Hope that helps some.
Thanks,
Eric
Significantly or in a neglegible way for a street car? Yes that's exactly the reason, I just want to boxer rumble on top of the performance boost.
Thanks for the reply and the explaination, that clarifies better.
_debo is offline   Reply With Quote
Old 01-06-2017, 07:37 PM   #48
Tokay444
Using an unequal length manifold on a twin scroll turbo just seems pointless.
Old 01-06-2017, 07:41 PM   #49
_debo
I understand that... but the boxer rumble
Old 01-07-2017, 08:09 AM   #50
Tokay444
It's not a boxer rumble. It's an unequal length manifold rumble and it's performance robbing.
Old 01-08-2017, 08:28 AM   #51
_debo
I know, I know and I do understand better the impliclations now that I read more about twin scroll turbos... well, something to ponder on for sure. If anything I made up my mind about the turbo brand I would be happy to go with and those are Garret, Precision and Borg Warner because they seem to be the best one out there; now it's matter to start looking for suppliers in UK.
Old 01-18-2017, 12:09 AM   #52
VerusEric
VerusEric's Avatar
For those people more in tune with Facebook... I have started a Facebook group for the turbo kit .
https://www.facebook.com/groups/1713782728933540/
Thanks,
Eric
Old 01-22-2017, 06:32 PM   #53
Ashikabi
Ashikabi's Avatar
Thanks,
Eric
Any issues with rain on the turbo? My hood is vented and my car is a DD. I know most things under hood aren't bothered by water
Edit, addition: the guys above were talking about the UEL vs EL headers. I know with a twin scroll turbo it's pointless. Assuming the turbo wasn't twin scroll, what kind of performance loss would you be looking at for UEL?
The Following User Says Thank You to Ashikabi For This Useful Post:
Yoshoobaroo (01-22-2017)
Old 01-22-2017, 09:18 PM   #54
Tokay444
What exactly is pointless about the twin scroll?
Old 01-22-2017, 10:30 PM   #55
Ashikabi
Ashikabi's Avatar
UEL with twin scroll
Old 01-23-2017, 12:24 AM   #56
VerusEric
VerusEric's Avatar
No issues, though being Arizona, it doesn't see rain THAT often. The kit is made with good materials and should not have an issue in rain or snow with hood louvers. I'm not bothered or worried about it (minus the extra dust that comes in, it's a tad annoying).
You'd still have some loss in performance, probably not significant enough to really worry about unless you're racing. I don't really like the boxer rumble, twin scroll efficiency for life !
Different turbos but same concept: http://dsportmag.com/the-tech/twin-s...-great-divide/
Here's a decent comparison from DSport as well: http://dsportmag.com/the-tech/full-r...spirated-fa20/
It's not exactly apples to apples (different dynos, different tuners, etc) and it doesn't have a boost curve on the plot, but it sure looks like the twin scroll turbo (Velox Shop Car) spools quite a bit faster than the single scroll 7163 (DSport shop car).
DSport Single Scroll V-Band 7163, stock engine, 15psi, e85
Velox Twin Scroll 7163, stock engine, 13.5-14psi, E80
Thanks,
Eric
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
Full-Race Motorsports White_Lightning Forced Induction 259 04-11-2017 01:04 AM
best turbo kit - currently Full Race? TEAM SCION Forced Induction 41 10-14-2016 08:41 PM
Full Blown Motorsports turbo kit exhaust question. Jtbirchfield Forced Induction 2 09-09-2015 04:19 PM
Full blown turbo kit owners Joeycokeboy Engine, Exhaust, Transmission 2 09-02-2015 09:49 PM
