Old 12-15-2016, 09:11 PM   #225
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Originally Posted by Reamer View Post
Starting in 2015 they put larger tips on them, but they're still not the original ones for the GT86.
I had to find some similar pics of an early GT86 and a 16 FR-S to see for myself. Seems you are indeed right.
Hang on, uploader is begin stupid. Brb with an edit.
EDIT: There we go.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 12-16-2016, 02:59 AM   #226
churchx
churchx's Avatar
Drives: 2014 GT86
CounterSpace Garage: can you guys tell how that center exhaust works temps/bumper non-melting wise, when/if stress-tested by eg. CSG Mike on track?
P.S.
There are misc. rules for street legality lights regulation wise .. at least according local ones i'll still need to have stock lights installed & working. Have you guys thought some options for relocating stock rear center light cluster if original space is used by Ace's muffler-s center exhaust? (my idea sounds like: cut out new hole for mounting relocated lights above old place, but turn 180deg, so that center triangle light points up.)
Old 12-16-2016, 03:20 AM   #227
FirstWinter
Drives: Car
P.S.
Could use Diode Dynamics Tail as Turn module as an alternative solution.
FirstWinter is offline   Reply With Quote
Old 12-16-2016, 03:47 AM   #228
churchx
churchx's Avatar
Drives: 2014 GT86
FirstWinter: not legal choice by local rules here.
Old 01-04-2017, 10:39 PM   #229
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Happy to report the Laguna 90 muffler fits with Velox Diffuser and Differential Cover Plates.
Unfortunately, the non-stick material isn't so good with stickers...
The muffler in the picture is a prototype we've been testing with and does not represent the production versions.
AceHeader-MT is offline   Reply With Quote
The Following 7 Users Say Thank You to AceHeader-MT For This Useful Post:
DAEMANO (01-05-2017), Jmonty (01-05-2017), Kestrel (01-04-2017), Reamer (01-04-2017), Silverfox (01-04-2017), Teseo (01-11-2017), VerusEric (01-23-2017)
Old 01-04-2017, 11:10 PM   #230
Reamer
Drives: 2015 FRS
Dual center exit means I'm cutting out the entire black plastic part, happily.
Reamer is offline   Reply With Quote
The Following 2 Users Say Thank You to Reamer For This Useful Post:
cactus (02-14-2017), MaximeT (01-05-2017)
Old 01-05-2017, 02:47 AM   #231
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
me too
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 01-09-2017, 11:26 AM   #232
AceHeader-MT
Drives: 2012 FR-S
The "Do It Yourself" (DIY) twin tip version will be coming soon.
In the meantime the center exit Lauguna 90 is almost ready for our testers. Since each car is different, the exit is able to be moved left, right, up and down to fit your car.
The Following 14 Users Say Thank You to AceHeader-MT For This Useful Post:
Andrew025 (01-11-2017), churchx (01-09-2017), civicdrivr (01-09-2017), CSG Mike (01-09-2017), Jmonty (01-12-2017), MaximeT (01-09-2017), new2subaru (01-09-2017), psybre (01-11-2017), Reamer (01-09-2017), Silverfox (01-09-2017), Teseo (01-11-2017), Ultramaroon (01-11-2017), VerusEric (01-13-2017), weederr33 (01-15-2017)
Old 01-09-2017, 11:28 AM   #233
Reamer
Drives: 2015 FRS
Wow, I can't wait to get my mitts on one of these.
Sent from my Pixel using Tapatalk
The Following User Says Thank You to Reamer For This Useful Post:
AceHeader-MT (01-09-2017)
Old 01-09-2017, 11:36 AM   #234
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Looks beautiful as expected 👍🏼
Silverfox is offline   Reply With Quote
The Following User Says Thank You to Silverfox For This Useful Post:
Old 01-11-2017, 03:24 AM   #235
psybre
psybre's Avatar
Awesome. I really wanted the center-exit exhaust FT86SF was working on, but nothing ever seems to have come of that. This looks gorgeous. Can't wait to cut out the black trim, mount that beauty and throw on a velox diffuser.... sweet
psybre is offline   Reply With Quote
Old 01-11-2017, 04:15 AM   #236
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Now I have to think of a good reverse light replacement...
Old 01-11-2017, 06:54 AM   #237
churchx
churchx's Avatar
Drives: 2014 GT86
I'm thinking of simply to mount it higher/above such exit & upside down, for pyramid to point up.
Old 01-11-2017, 11:52 AM   #238
Cybmx
Drives: 2016 Hyperblue Brz
Sold!
Cybmx is offline   Reply With Quote
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 04:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-23-2013 11:54 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 07:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
