Old 12-24-2016, 08:15 AM   #71
Tor
Tor's Avatar
Drives: Toyota GT86
@TeutonicShift89 , as far as I can imagine the shifter is maintenance free. The only part that could wear/need greasing is the link at the button of the lever that connects to the shift rod. Of course, I can't say what e.g. 100.000 miles of wear would do to it. In any case, I don't see any short-term maintenance requirement.
@redlined600 , the lever has a great shape and the finish has a nice feel to it (anodized = not quite smooth). I don't miss the stock leather shift knob (which I think felt great).
@sw20kosh , you may not have it at all. I think it's like the stock shifter were some cars have it even after having the TSB applied. In any case, as I have it, I am working on a solution.
Tor is offline   Reply With Quote
Old 12-24-2016, 08:58 AM   #72
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Can/do you ship to upside down land (Australia)? If so I may want to upgrade from the Kartboy I currently have. Stiffened mounting and braces diff has greatly increased the vibration in the Kartboy which is starting to get on my nerves.
COO86L is offline   Reply With Quote
Old 12-29-2016, 12:24 AM   #73
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Finally got the car out on track! Absolutely in love with this shifter. Another shop owner sat in my car to check it out, and bought the last one I had! Time to order more
Camera was specifically angled to get more footage of the shifting
The Racers Line is offline   Reply With Quote
The Following 6 Users Say Thank You to The Racers Line For This Useful Post:
COO86L (01-14-2017), Cybmx (12-29-2016), icybrzzz (12-31-2016), Jonsey (12-29-2016), Tor (12-29-2016), why? (01-07-2017)
Old 12-29-2016, 09:33 AM   #74
Cybmx
Drives: 2016 Hyperblue Brz
Do you need stiffer engine/trans mounts for the shifter? If it can work normally without these additions, I might have to get one sooner
Cybmx is offline   Reply With Quote
Old 12-29-2016, 10:22 AM   #75
Jonsey
Jonsey's Avatar
Looks great. Excited for my car to get finished up in the shop so I can install mine.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
The Racers Line (12-29-2016)
Old 12-29-2016, 10:56 AM   #76
The Racers Line
At the very least I'd recommend a transmission insert bushing. Something like the white line or super pro insert. I have the white line, and stock engine mounts and had no issues.
The Following User Says Thank You to The Racers Line For This Useful Post:
Cybmx (12-29-2016)
Old 12-29-2016, 08:11 PM   #77
icybrzzz
Drives: 2015 Scion frz
Videos like this make me want this so much more!
icybrzzz is offline   Reply With Quote
The Following User Says Thank You to icybrzzz For This Useful Post:
The Racers Line (12-30-2016)
Old 01-03-2017, 08:10 PM   #78
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
New RACING short shifter from Individual Racing Parts
So would this shifter be less effort to shift than the usdm Trd shifter mod? Basically that sucker makes it very high effort to shift in and out of gear even when it is warmed up. I've used it for about a year and would be more likely to go this route if the irp is direct but not "hard" to shift.
Also does this get rid of some of the 2nd and 4th gear "crunchiness?"
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 01-03-2017, 09:40 PM   #79
ryoma
ryoma's Avatar
I suggest you change your transmission and differential oil. I personally use Motul Gear 300 and love it, though it is "harder" to shift into gear when cold. it is not a problem for me since I am in 1st gear when I leave my community anyways so it gives it plenty of time to warm up when I hit the main road.
Old 01-04-2017, 12:02 AM   #80
TeutonicShift89
I've already changed to a millers oil synthetic. The effort is entirely due to the design of the Trd kit.
Old 01-04-2017, 12:20 AM   #81
ryoma
ryoma's Avatar
the crunch might not be the shifter though. to me, it sounds like old transmission oil that causes the crunch when shifting
Old 01-04-2017, 12:22 AM   #82
TeutonicShift89
It's not that big of a deal really. Changing the transmission oil did not make that big of a difference in my car at least. Mostly I'm interested in the shifting effort which I would think is easier based on the greater leverage from the taller shifter arm.
Old 01-04-2017, 12:49 AM   #83
ryoma
ryoma's Avatar
this is on my list of "to buy" items, though not at the very top. if no one else gives any input regarding shifting effort then I might later on (depending on when I actually buy it). however, from what I have gotten from all the posts is that it is not as "forceful" as the CAE shifter and more casual, meaning that you do not have to commit to a shift in order for it to go into gear (which means that it will take less force to get into gear)
Old 01-04-2017, 06:33 AM   #84
Tor
Tor's Avatar
Drives: Toyota GT86
It probably always a good idea to committing before actually shifting, no matter which shifter.
There is no resistance getting it into gear, more than what the gearbox naturally produce. The shifter itself has no resistance what so ever.
I am still not 100% sure about what the spring on the CAE shifter does, so take this with a grain of salt. I suppose it is spring loaded back to neutral and hence you need to overcome the spring force getting it into gear. I also suppose the purpose is for the spring is to assist getting it out of gear faster and maybe artificially create more force on the shifter so it feels more springy during the shifts and encourages to make the shift more forcefully.
The springs that counts are those centering the shifter side to side (so you don't e.g. go into 5th instead of 3rd). These springs are located inside the gearbox itself and can be upgraded with e.g. MTec springs. I did this in combination with the IRP shifter and would highly recommend doing so.
I can't give an opinion about what is better. What I can say is that the IRP shifter shifts very easily and effortlessly even during casual driving.
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
WTB: Megan Racing Cat-Delete pipe And short shifter AZ_Racer_1 Want-To-Buy Requests 1 01-25-2015 12:54 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Short Vid about Okinawan Street Racing vividracing BRZ Photos, Videos, Wallpapers, Gallery Forum 1 03-03-2014 10:29 PM
TOM'S Racing Parts, First from Vivid Racing! vividracing Exterior Parts - The Rest 4 09-11-2012 04:20 PM
