#2605 | |
APEXHNTR
Drives: 10 Series FR-S #1867
Late to the party, I know we're talking about airbags right now but I'm wondering if the STi parts were legal on FR-S too?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2606 |
Drives: 2017 BRZ
#2607 |
btr.life
Drives: 2022 GR86
Same with me. In fact, only reason I have a trailer is so my family and I can travel together to events, instead of taking 2 cars.
#2608 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
On the topic of driving your car I daily my car and just got my first set of 200tw tires (RS-3s) with plans to run my first full autox season and am looking for help in making them last as long as possible.
I currently have -2.5 front and -2 rear camber with zero toe all around. I have camber plates, crash bolts and spc bolts in the front for adjustment. I was thinking of maybe pulling the crash bolts for my next alignment and then install them only for events to get to the -3 mark then swap back after. I am hoping to get the most use out of the tires since I wont have a second set of wheels until summer time when I can daily those instead of the RS-3. Any suggestions on my idea or what your guys have done that has worked? |
#2609 | |
Drives: '22 BRZ
I ran similar alignment to your current specs and got some inner edge wear (~7k street miles) and outer edge wear (track/autocross abuse)... I'd bet you'd see a little bit more inner edge wear than I did on the street and less outer edge wear with the increased camber. That said, toe wears tires a lot more quickly than camber. Flip the tires halfway through their life and you can extend the life a bit.
| The Following User Says Thank You to DocWalt For This Useful Post: | finch1750 (01-03-2017) |
#2610 |
Drives: 2013 FRS, 2024 Trueno
The RS3's are hard enough to deal with running daily and doing autox for a season before being bald even with those camber settings. You will heat cycle them out at around the same time as the season will be over or slightly before.
At least this was my experience in 2015 when I communted 60+ miles a day and did 10 autox events. By the end of the season the tires were nearly bald and I didn't flip the tires, but would recommend it.
| The Following User Says Thank You to Shneegle For This Useful Post: | finch1750 (01-03-2017) |
#2611 | |
#2613 | |
The Stig's German cousin
Or as others have suggested, flip tires halfway through their life and forget about it. You have zero toe and not a crazy amount of camber. |
| The Following 3 Users Say Thank You to renfield90 For This Useful Post: |
#2614 | ||
#2615 |
Drives: 2017 BRZ
Or just drive -3 camber, zero toe. The wear you get from the camber will probably be far eclipsed by the wear you get when you're pushing the car hard, especially if you don't have enough camber. Flip the tires anyway and it'll all work out. I got nearly two full seasons on a set of 255 RE71R and just hit the wear bars at ~run 260... probably 5-6000 miles on the road to/from events in addition before I started driving the PSS and swapping at the events. Hockey pucks? Yes... but still, ... Oh, and -3.3 front camber. But zero toe. And I didn't flip.
| The Following User Says Thank You to cjd For This Useful Post: | finch1750 (01-03-2017) |
#2616 | |
#2617 | |
Drives: 2017 BRZ
If you're really concerned about wear, get a set of commuter tires eventually. They'll be quieter, and you can go narrower which will mean less fuel... if you aren't fussed over the looks.
| The Following User Says Thank You to cjd For This Useful Post: | finch1750 (01-04-2017) |
#2618 | |
For anyone with plates who goes in for a custom alignment, it's worth having the tech work through a few different settings on the plates to see what values they generate. If your plates don't have markings, add some. That way you don't need to cough up more money if you decide you want 0.5 degrees more camber in a couple months. |
| The Following User Says Thank You to renfield90 For This Useful Post: | finch1750 (01-04-2017) |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
