Old 01-01-2017, 03:51 PM   #701
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So I'm working on installing the OEM Oil cooler, and after removing the skid plate, I notice this!
I take it, it's a head gasket leak? This wasn't hear last time I went under the engine... which was when I installed the Nameless headers about a year ago.
MS, CSCS, TSAC-F, CPT
Old 01-01-2017, 04:09 PM   #702
Teseo
Drives: frs
Try an engine compression
Old 01-01-2017, 06:17 PM   #703
weederr33
weederr33's Avatar
What do you mean?
Old 01-01-2017, 06:25 PM   #704
Teseo
Drives: frs
Originally Posted by weederr33 View Post
What do you mean?
Sorry, i was not clear. If compression of cylinders are lost then you are fuck up. If not, then is an external leak. Also check your coolant if have a milkway color. Prepare for an overhaul and good idea to go forged internals for moar pawa
The Following User Says Thank You to Teseo For This Useful Post:
weederr33 (01-01-2017)
Old 01-01-2017, 08:43 PM   #705
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Looks like a valve cover leak to me. Where exactly is this located? Is this the driver or passenger's side?
If it's a head gasket leak, you'll know it. Like said, you may have low compression or antifreeze in the oil which will make it milky. You may even smell antifreeze in the exhaust. If your oil looks fine, then I would clean the engine off and put some UV dye in it. You can get it from Advance, Autozone, Walmart, etc...
Clean everything off at the car wash and then put in a small bottle of dye. Drive it for a few days and then check with a UV light. Most mechanics can do this. They can pinpoint exactly where the leak is and tell you what you need to fix it.
sly is offline   Reply With Quote
The Following User Says Thank You to sly For This Useful Post:
Old 01-01-2017, 08:56 PM   #706
weederr33
weederr33's Avatar
It's the passenger side. But the leak but be very slow as the gunk on the skid plate looked more like old soot. I'll try the dye. I haven't noticed any smell of antifreeze, let alone the grime associated with a gasket leak. So it could be the valve cover. Any idea at the cost to fix it?
Old 01-01-2017, 09:05 PM   #707
sly
sly's Avatar
No idea. But it would be a lot cheaper to fix a valve cover leak than a head gasket. I'd start with the dye and go from there.
Old 01-03-2017, 10:39 PM   #708
Insurme1
Drives: 2013 Scion FR-S 10-Series
Can someone tell me the part # for a spare belt? I know I read it here somewhere but can't find it?
Insurme1 is offline   Reply With Quote
Old 01-04-2017, 11:42 AM   #709
weederr33
weederr33's Avatar
It's the Gates 6PK2315
The Following User Says Thank You to weederr33 For This Useful Post:
Insurme1 (01-08-2017)
Old 01-05-2017, 05:28 PM   #710
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
If you've not been losing coolant its certainly an oil leak from either the rocker cover or the front cover
there's no actual gasket for either both are sealed with sealant
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
weederr33 (01-05-2017)
Old 01-20-2017, 05:15 PM   #711
weederr33
weederr33's Avatar
OEM Oil Cooler, via the capped off throttle body pieces was installed today. Wasn't very hard. The only problem was trying to bleed the coolant since the supercharger throttle body is directly over the bleeder.... Otherwise, looks great with the Stage 2 kit!
Old 01-30-2017, 10:46 PM   #712
Insurme1
Matt, was this pulley ever produced?
Old 01-31-2017, 02:08 AM   #713
ajc209
Drives: GT86 Cosworth
It will be fine for road use, but I think that cooler will benefit from a direct water supply from block as per the forester setup it was taken from. Its not really designed to use the throttle body feed.
I will be interested what you oil temp settles to on the highway. Do you have the low temp theromstat?
ajc209 is offline   Reply With Quote
Old 01-31-2017, 10:17 AM   #714
weederr33
weederr33's Avatar
I do have the Cosworth low temperature thermostat. I did attempt the engine block option but stripped the hex bolt when trying to unscrew it unfortunately. Which is why I went the throttle body route. I'll do some data logging on the Temps soon and post them up for sure.
Since I don't really track my car, it should be OK for now.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
