Old 12-27-2016, 10:23 PM   #29
aagun
Drives: 86
Originally Posted by Songha View Post
Cool, does this only affect noise at idle? If it's harmless I can't see why I wouldn't try it.
yes at idle only with in 800-1200 range . here the car iske at 1000
aagun is offline   Reply With Quote
Old 12-30-2016, 08:34 AM   #30
Nah
Drives: 2013 Scion Frs 6mt
So... how do we do this care to share 😂
Nah is offline   Reply With Quote
Old 12-30-2016, 11:05 AM   #31
Kodename47
Kodename47's Avatar
Drives: UK GT86
You need a patched ROM
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-30-2016, 10:57 PM   #32
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Is this similar to what you're looking at/playing with?
COO86L is offline   Reply With Quote
Old 12-30-2016, 11:20 PM   #33
steve99
Drives: FT86
Im pretty sure that you need to patch the ecu code as the standard firmware does not enable avcs in idle mode
Old 12-30-2016, 11:22 PM   #34
COO86L
COO86L's Avatar
These are only available in the beta maps section. Low RPM low load cam control might indicate idle cam control? I'm not sure
Old 12-31-2016, 05:25 AM   #35
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you look at the max/min in those settings then you'd see that they have quite a range. However changing the AVCS map in the idle range does nothing. Those are for off idle.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-01-2017, 12:16 PM   #36
BXRCHTR
Can someone post an example of the patched ROM made to do this? I can patch them to the other ROMs as well after I confirm ikt worked with my car.
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear god, protect my ride.
BXRCHTR is offline   Reply With Quote
The Following 2 Users Say Thank You to BXRCHTR For This Useful Post:
Nah (01-02-2017), Travisty75 (01-01-2017)
Old 01-02-2017, 10:54 AM   #37
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Its not possible on EcuTek yet. I sent them an email regarding implementing AVCS control at idle and have copied their response below.
Hello Ron,
Thank you for the information, it looks like it could be an interesting feature!
We have created a task to add this option in the next batch of BRZ updates.
We have linked your ticket to this task so we will contact you once this has been completed.
Mervyn Carroll
EcuTek Technologies Ltd
On EcuTek, we'll need to wait for them to implement something like this likely via a RaceROM update. What OP did was debug the factory ROM, and add in a section of code which allows enabling AVCS at idle. This isn't possible to do via current defined tables in EcuTek / RomRaider... you'd need OP's patched ROM or the know-how to debug and patch a stock ROM yourself.
I'm just an end-user though (retail). I'd recommend someone who is licensed as a dealer / master tuner to contact them to possibly get more information.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 01-02-2017, 02:37 PM   #38
Nah
Aye^ that'd be legit
Old 01-02-2017, 03:40 PM   #39
BXRCHTR
Yeah. OP just needs to post something with more info for us. Please and thank.
Old 01-03-2017, 03:43 AM   #40
aagun
Drives: 86
updated
Old 01-17-2017, 09:15 AM   #41
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Anything new?
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
The Following User Says Thank You to rjgough95 For This Useful Post:
BXRCHTR (01-19-2017)
Old 01-19-2017, 09:36 AM   #42
BXRCHTR
Bump!
AVCS - Intake and Exhaust Timing Kodename47 Software Tuning 274 02-28-2021 11:39 AM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 03:12 AM
AVCS tuning Turdinator Software Tuning 9 11-24-2015 01:31 PM
Turbo AVCS/VVT settings ztan Forced Induction 8 05-10-2015 04:17 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 03:01 PM
