Old 12-29-2016, 10:55 PM   #15
Xiges
Drives: White 2015 FRS
Thanks everyone!
Sadly, if there was an amp the old owner took it and left the cables
I'm thinking of doing a sound tube delete tomorrow lol, anyone do the same?
Xiges is offline   Reply With Quote
Old 12-29-2016, 11:19 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Battery has been replaced, suspicious on a <2 year old car with only 12k miles.
Also missing the red plastic terminal cover.
Worst case scenario it was a ghetto wiring job for the amp that killed the OE battery (mine is doing fine after 4 years and 55k miles) and the problem is still lingering unfixed despite removal of the amp and whatever other changes there were, best case it died on the lot or by some sort of user error (left the lights on a few too many times), or the PO replaced it for something lighter (it does look a bit smaller) or for some silly reason.
Check out a regular 2015, maybe I'm wrong and they changed battery suppliers, but I doubt it, that Panasonic battery seems to be ubiquitous in every photo I see.
Edit: Looking at OP's photo the battery does not appear to be secured at all and the handle is broken, secure it asap please.
Everything else looks reasonable (aside from the use of armorall in the engine bay, fuckin' dealerships man) based on the pics, maybe it's nothingn, enjoy.
ineedyourdiddly
Old 12-30-2016, 12:31 AM   #17
Originally Posted by Xiges View Post
Thanks everyone!
It's simpler (and reversible) just to take the plug, that's for the cigarette lighter outlet (behind the glove box), and stick it in the sound tube outlet, which is located behind the passenger side floor mat on the firewall ......
finch1750 (12-30-2016)
Old 12-30-2016, 01:14 AM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Dont forget the pcv plug for the whole in the intake
Old 12-30-2016, 01:31 AM   #19
Xiges
I'm going to be doing this tomorrow
http://www.ft86club.com/forums/showthread.php?t=72263
(ps how do you thank people)
Old 12-30-2016, 02:14 AM   #20
After you have made about 10 posts, a "thanks" button will appear at the bottom of people's posts. You may punch it, if you think the post is noteworthy......
Old 12-30-2016, 02:15 AM   #21
Xiges
Ah okay thanks, halfway there lol
Old 12-30-2016, 02:17 AM   #22
I just plug up the outlet ...... in case I get tired of going ynnnn-ynnnn-ynnnn .....then I can reach down and unplug it .....
jcw99 (12-31-2016)
Old 12-30-2016, 12:54 PM   #23
If you haven't already done it fix the above before worrying about sound tube deletes.
With a loose battery and open positive terminal you are one hard stop or light tap away from an exploding battery at best and a burnt up car at worst. Head to the nearest auto wrecker and grab a tie down and cover ASAP.
Ultramaroon (01-01-2017)
Old 12-30-2016, 01:35 PM   #24
Morchkin
Morchkin's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by KnightRyderx2 View Post
Bass boost knob for a aftermarket amp for a subwoofer.
I can confirm this. The previous owner of my FRS had the knob mounted on the dash, wire ran through the console, and coiled up in the trunk. But for some odd reason forgot to leave the amp/sub it was attached to! So it's there if you run a compatible amp. Plug your land-line phone into it in the meantime.
Morchkin is offline   Reply With Quote
Old 12-31-2016, 02:57 PM   #25
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by MarkR171 View Post
The muffler says Borla. I'm assuming the exhaust is a Borla.
edit: Smartass comment aside, looks like Borla axleback.
https://www.borla.com/products/frs_b...rt__11839.html
If it came from the dealer, it's this one:
https://www.borla.com/products/brzgt...__1014034.html
Old 12-31-2016, 03:07 PM   #26
Xiges
That does look like the one that's on, thanks!
Luckily I'll be upgrading my audio at some point, but idk if I'll be actually using the knob lol, I'll probably find out how to remove it
Also I'm getting on the battery stuff asap
What were the first things everyone did to their cars? (Upgrade audio, new rims, etc?)
Old 01-01-2017, 03:29 AM   #27
Heck, "everybody" has done almost "everything" to their cars ......
IMHO, with you living in Florida (don't need winter tires), there is really nothing that you need to do to your car, for average driving, especially since you already have a aftermarket muffler and a drop in air filter.
I would suggest you drive it stock for a few weeks, then decide if there is anything you would like it to do/look better/different.
Just because some folks modify their car, the modification(s) don't necessarily make it better, other than for specialized uses (tracking for example).
Old 01-01-2017, 04:44 AM   #28
+1 to what strat61caster noticed. Get that battery tied down properly and cover that positive post before the whole thing goes up in flames.
Dead serious. Do this today.
I bought and totaled a BRZ. Then I bought another. unhappymeal BRZ First-Gen (2012+) — General Topics 51 06-07-2017 08:54 AM
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 11:36 PM
Random question Junglist Scion FR-S / Toyota 86 GT86 General Forum 4 02-12-2015 05:41 PM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 04:57 PM
Best store bought or online bought wax ThatManAnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 03-12-2013 10:32 PM
