#4397 | |
Drives: 2017 BRZ
The stiffer front bar does increase understeer, but it's done because of the assist in transitions it provides - something you see a lot of in the typical AutoX. |
#4398 | |
Student Driver
Drives: 2016 Subaru BRZ Limited
#4399 | |
Drives: 2017 BRZ
Most of the time I have obvious understeer problems it's a driver correction away from being solved... going in too hot is the usual cause; I don't typically have understeer except corner entry after an open straight; once I'm into a transition sequence it's rare - even when it's a fast one. And in some cases, it's because I'm not turning the wheel far enough
#4400 | |
Student Driver
like you, I tend to get in too hot. I'll be working on that this year for sure. Having stickier rubber should help too. I've been doing some more research, and it seems like main benefit is keeping the inside rear planted in transition. So I'm thinking I'll go for a bar that's stiffer than stock, but not one of the super stiff ones. |
#4401 | |
Dismember
Drives: 2013 Red Scion FR-S
#4402 | |
Drives: '13 FRS - STX
You could also mess with tire pressures a bit to help the car rotate, I know it's very very common in the stock classes. The other thing that really really helped my car rotate was the pedal dance. I had some trouble adjusting my braking technique but after a day of messing with it, and then trying to go back to the way it was before I'm convinced it's well worth doing in autox. http://www.ft86club.com/forums/showthread.php?t=25494 And as previously mentioned, driver mod is king. The best drivers can make even the most fucked up POS go fast. A couple autox resources try their best to hammer it home, a lot of champions are champions despite their setup skills. |
#4403 | |
#4404 |
Drives: Fr-s
Anyone have experience with this product or company?
Press in spherical bushings http://www.esmrace.com/product-p/brzfrs.esmfrlkb.htm
#4405 |
Drives: 2013 BRZ Limited
We should separate this thread into "Got a track related question..." and "Got an AutoX question..." threads because they couldn't me more different, especially when it comes to vehicle build and setup. New members could get quite confused since the majority of people don't read information completely or in context. Just a thought.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#4406 | |
Drives: anything you let me
![]() Good idea on separating the performance Q/A threads so at least each one has the same general discussion goals. |
#4407 |
The original intent of this thread was track, but it has digressed into a mix of both and with 300+ pages, it is quite a mess of info.
#4408 |
Drives: 2017 BRZ
While the target handling characteristics for best performance are different, I think the setup information itself is relevant across the board - you just take it a little further one way or another. There are already threads for the two common classes for the twin, and lots of setup info there too.
#4409 | |
My idea was just a thought. This is Mike's thread so it is really up to him. His OP is 100% track, 0% autocross. I only get on here to try to help, so I have to wade through pages of AutoX stuff to figure out which posts are relevant and/or could benefit from some input. I don't see a down side to separating them and it would add clarity for new people trying to get into either AutoX or tracking their cars. I think it is a testament to what Mike started with this thread and what we've built here on this forum and it is a good problem to have.
#4410 | |
Drives: 2017 BRZ
I've learned more about what to look for, and what changes to make to achieve a desired outcome from this thread than the AutoX threads. C |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
