Old 12-22-2016, 01:20 PM   #715
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Originally Posted by Tokay444 View Post
If that were the case, you'd need a different tune for every different weather condition, and that simple isn't the case.
That's not what he's saying. The bends in the tube and the flow smoother set the maf value as well as the diameter. He said nothing about temperature.
JohnJuan is offline   Reply With Quote
The Following 3 Users Say Thank You to JohnJuan For This Useful Post:
GrimmSpeed (12-22-2016), gtengr (12-22-2016), wparsons (12-22-2016)
Old 12-22-2016, 01:50 PM   #716
Kodename47
Kodename47's Avatar
Drives: UK GT86
Anything upstream or downstream can change the way the air flows through the intake, the MAF sensor only measures air passing the sensor area. If you change the snorkel, the airflow over the sensor will likely change as well. How much/little can only be determined by testing, I did some basic tests on removing various parts of the OEM intake years ago and it made quite a difference to the MAF readings.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-22-2016, 03:51 PM   #717
Lantana frs
Drives: 13 frs red
The airbox itself helps to somewhat stabilize the atmospheric conditions that the motor breathes in. I have a k&n drop in which I may remove because the fitment is sketchy and makes it difficult to push the airbox halves together.
Lantana frs is offline   Reply With Quote
Old 12-22-2016, 04:39 PM   #718
HunterGreene
Hail Magnet
HunterGreene's Avatar
I have the same filter, no issues here. Did you put it in correctly? There is a proper orientation.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Old 12-22-2016, 05:12 PM   #719
Teseo
Drives: frs
Well, now im worried if i change anything on intake components
Old 12-22-2016, 05:42 PM   #720
Lantana frs
Drives: 13 frs red
Yes and you are right. I believe the difference is in the thickness of the rubber lip on the k&n. I take it you installed it on your own?
Old 12-22-2016, 06:30 PM   #721
Tokay444
Seems there are a great deal of people in here who don't know how a maf sensor works, or what it communicates to the ecu.
Old 12-22-2016, 09:45 PM   #722
wparsons
wparsons's Avatar
Seems there are a great deal of people in here who have maf sensor works, or what it communicates to the ecu.
Might want to read through the many threads documenting intake testing and development...
flickr
Old 12-22-2016, 09:54 PM   #723
Tokay444
No need.
Old 12-23-2016, 04:04 AM   #724
Kodename47
Kodename47's Avatar
Drives: UK GT86
I wouldn't the ECU is designed to accommodate changes to some degree, that's what the fuel trims are for.
I have MAF sensor works!
.: Stealth 86 :.
Kodename 47 DJ:
The Following 4 Users Say Thank You to Kodename47 For This Useful Post:
GrimmSpeed (12-23-2016), Teseo (12-23-2016), Tokay444 (12-23-2016), wparsons (12-25-2016)
Old 01-02-2017, 09:42 AM   #725
HunterGreene
Hail Magnet
Yeah, dropped it in myself. Everything has clicked in tight, I have even removed, cleaned, oiled and replaced it with no issues.
Old 05-19-2020, 10:27 PM   #726
moda3
moda3's Avatar
Drives: FR-S RS 2.0
Is there a dry filter replacement for the TRD intake system? I want to use the TRD intake but not the oiled filter..
moda3 is offline   Reply With Quote
The Following User Says Thank You to moda3 For This Useful Post:
Jdmjunkie (05-20-2020)
Old 05-20-2020, 12:03 PM   #727
moda3
moda3's Avatar
Drives: FR-S RS 2.0
Anyone?
Old 05-20-2020, 12:59 PM   #728
churchx
churchx's Avatar
Drives: 2014 GT86
I'd wish for one too. I'm sure that even more resistive (but better filtering) paper filter in TRD intake should still be less resistive then OE due from it's big size/filtering area alone. Would simplify replacement, add extra trust in quality of dust filtering, and eliminate any chances of oil excess ever dirtying MAF sensor.
But given that TRD intakes make up relatively small number from all the twins out there, imho there is too little market to make very small runs of making that intake specific sized filters, so most probably there will be no choice but that oiled filter it has or it's replacements of same type.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
