Old 12-22-2016, 11:55 AM   #43
1000 gallons of gas (note MO chalked on tailgate behind my ass).
5 ton truck.
Baffled tank.
Sudden stops.
Jerk 3 feet forward then 2 feet back then 1 foot forward then stop.
Twin would be doomed with 100 gallons sloshing even in a baffled tank.
Don't do it.
cjd (12-22-2016), dp1 (12-22-2016)
Old 12-22-2016, 08:17 PM   #44
dp1
driving smoother faster
Drives: Sold
Custom trailer to carry 100 gal of E85 to track
So many good people on this forum
I read all replies and talked to many people. There are ways to minimize risks but not within my tolerance.
I will have a custom small trailer built to carry 4-6 5gal jugs or cans, a toolbox and a spare set of wheels, with upgraded suspension. Now looking for ways to have E85 or E100 delivered to tracks.
Thank you all kindly for your valuable feedback.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Tcoat (12-23-2016)
Old 12-22-2016, 09:47 PM   #45
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
5 ton truck.
Baffled tank.
Sudden stops.
Don't do it.
But just for funsies:
BRZ + trailer = 1.75 tons
1.75 / 5 = 35%
60 gallons vs. 1000 gallons
60 / 1000 = 6%
So his setup would have roughly 1/3 the weight, but only be carrying 6/100ths as much fuel. Or to put it another way, his setup is the equivalent of your truck having weighed more than 29 tons.
Of course its not that simple since this would be a trailered load, but still. Wanted to put your example in perspective
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
dp1 (12-22-2016)
Old 12-22-2016, 10:18 PM   #46
dp1
Drives: Sold
1.75 / 5 = 35%
60 / 1000 = 6%
Great point, guess I should clarify - it wasn't the weight ratio that turned me off, no doubt that 700lb total trailer/load weight would work fine 99% of the time.
However, accidents happen. Regardless of the exact shape, the tank couldn't be too tall and would be mounted onto a fairly low hanging frame. Even with fully upgraded trailer frame and the best baffled tank money can buy, significantly upgraded suspension to improve the ride and protective barriers around the tank...somebody running a red light or rear ending me has that tank more/less directly on the impact path...
Old 12-22-2016, 10:46 PM   #47
Stang70Fastback
A.K.A. Starlord
Psh. Just gotta buy a GOOD tank. Jeez...
[ame="https://www.youtube.com/watch?v=1mHtOW-OBO4"]Nuclear Flask Endurance Testing in USA - YouTube[/ame]
dp1 (12-22-2016)
Old 12-23-2016, 06:35 AM   #48
1.75 / 5 = 35%
60 / 1000 = 6%
Well I must have missed where it went from 100 gallons to 60 and that would make a big difference. The capacity of the truck was 5 tons and I don't remember the GVW of the actual truck but it was more than 5. You also sort of nailed it when you said it is a trailered load so you can include the weight of the trailer as vehicle.
Old 12-24-2016, 10:44 AM   #49
redlined600
redlined600's Avatar
Drives: Fr-s
Have you looked into the possibility of having the fuel delivered straight to the track for you. Or if you could connect with shops near the tracks you frequent that would deliver it for you.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
dp1 (12-24-2016)
Old 12-24-2016, 01:47 PM   #50
dp1
Drives: Sold
I'm investigating that now, also looking at Torco fuel accelerator
Old 02-01-2017, 10:23 PM   #51
dp1
Drives: Sold
In conclusion, I backed away from E85 altogether as it's not readily available at or near my favorite tracks...just not worth the hassle. Car is set up really well, it's a blast to drive and everything should last longer with current 93oct setup, fully built engine, etc. May try torco or boostane for fun (already have 100oct Ecutek map) but not necessary.
The Following 2 Users Say Thank You to dp1 For This Useful Post:
Allch Chcar (02-01-2017), cjd (02-02-2017)
Old 02-01-2017, 10:49 PM   #52
Pat
Pat's Avatar
Drives: 2023 BRZ
I really enjoy reading your posts. Thanks for taking the time to share your journey in such great detail.
The Following User Says Thank You to Pat For This Useful Post:
dp1 (02-02-2017)
Old 02-02-2017, 09:28 AM   #53
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Just read this entire thread (I kind of stalk you dp1) bc I am a track guy living in upstate NY like you. I have also had this E85 debate and ran into the same transportation/availability issue and also backed away from the idea. It just isn't cost effective in this part of the country.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
dp1 (02-02-2017)
Old 02-04-2017, 05:48 PM   #54
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I'm surprised I wasn't tagged in this. I built a trailer and towed an 800 lb load from LA to DC in 2015. I still have the trailer, which is 150 lbs empty, and I use it all the time, empty, half a load, full load, etc. With no problems what so ever.
I use the Slambert trailer hitch. The only troubles I had was when I had too little tongue weight. Originally I had 80 lbs of tongue weight at ground level, but it was way too low at hitch height. Once I remounted the tool box and I had 80 lbs of tongue weight AT TOW BALL HEIGHT! Everything was smooth as butter.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
CarzCarzCarz (02-08-2017), dp1 (02-04-2017)
Old 02-07-2017, 10:36 AM   #55
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
this might come off as a stupid idea but,
what kind of fuel cell would fit in an 86?
Maybe if you kept your extra fuel in a high capacity fuel cell IN the car and kept the tires and tools on a trailer you would be better off, wouldn't you?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
anyone selling tire trailer for track/autox? didinyc NY / NJ / CT / PA 2 03-30-2015 12:19 PM
Custom tunes safe for track usage? Sleepless Software Tuning 21 12-23-2014 08:54 PM
Any shops in the bay area that carry the Berk Technology Dual Exit Track Pipe? FRZ-BRS Northern California 7 12-01-2014 01:24 PM
Custom Track pipe drambo136 Engine, Exhaust, Transmission 6 02-11-2014 10:49 PM
BRZ in Born To Race Fast Track Trailer switchlanez BRZ First-Gen (2012+) — General Topics 34 06-28-2013 07:21 PM
