Old 07-04-2012, 03:20 PM   #29
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
I've had a bit of a rattle inside and my passengers have been NO help in tracking it down. I have only taken my FR-S on the highway one time for about two miles, have not had it above about 62 mph indicated (has only around 600ish miles now). The rattle happens at various speeds.
I'm pretty sure I'll just have to live with it. With all the road destruction going on these days around here, finding smooth pavement is rare.
One thing I did find early on was that the rear low mounted lighting assembly seemed fairly loose and rattly to the touch underneath the car, so I wedged in some adhesive damping pads. Not sure if that helped at all.
Nepenthe is offline   Reply With Quote
Old 07-09-2012, 09:35 AM   #30
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Originally Posted by Citified View Post
I've heard a similar sound at speed. My first thought was that the sound was coming from the dash vents. It seemed to me that the intake for the cabin circulation system must be pointed forward and that air pressure at high speeds was causing the fans or diffusers to get overwhelmed and make noises in protest. I only hear the noise at 65-70+ mph, so it's definitely speed related.
Originally Posted by YukiHachiRoku View Post
just noticed this today, but it seems to happen more when I'm at WoT.... my buddy was in the car, we thought the sound was also coming from the top of the dash or in the vents as well.
We had the windows rolled up since I just washed the car and didn't want water to get all over the windows.... It was intriguing. It felt like vibration with air intake baffle thingy, idk it's weird thouoh...
could it be crankshaft or cams rattling?
no check engine light or anything though.
Same boat. Rattling sound *apparently* coming from the dash under WOT or heavy acceleration.
Doesn't seem to happen under mild acceleration or when revving with the clutch out.
Any clue what it is yet guys?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 12-21-2016, 07:28 PM   #31
KHANrad_SIN
Drives: Whiteout
It's a pretty old thread but I thought I'd chime in. I had that flapping noise too. It only appeared at highway speeds at around 70mph cruising. It sounded like it was coming from the passenger side rear (perhaps near the wheel well). Turns out it was. It was the rear plastic covering for the wheel well. If you tap it you can hear it hitting the metal behind it. I just lifted it up a bit and put some double sided foam tape and the sound has gone away for now.......
KHANrad_SIN is offline   Reply With Quote
The Following 2 Users Say Thank You to KHANrad_SIN For This Useful Post:
DocWalt (12-21-2016), mrjj (09-02-2022)
Old 12-21-2016, 08:15 PM   #32
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I had the exact same issue, with the same fix.
Old 12-21-2016, 11:31 PM   #33
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
I've been noticing a slight sound coming from the right rear when I am traveling about 75-85 mph. It sounds like something is fluttering or a hard plastic rattling. I have looked all over the area and can't find anything loose. I may take the car in for the dealer to look at, but I'd love to hear if anyone has any ideas what may be causing it.
Take literally everything out of the car (all your personal things). Then try again. Rule out things in your coin tray / glove box / wherever first.
Ganthrithor is offline   Reply With Quote
Old 12-22-2016, 06:18 AM   #34
JD001
JD001's Avatar
Drives: Subaru BRZ
Say no more... are you sure no one has left an intentional "gap" in the exhaust....
Old 12-22-2016, 06:42 AM   #35
Between my exhaust, radio and tire noise I don't think I would know if I had a soft rattle if there was one.
Old 12-22-2016, 01:23 PM   #36
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I think people have forgotten that the underbody panels flap a little . There's a spot where two panels are secured by 1 fastener over seas. In the US there is only 1 panel there and it creates a small gap due to the absence of the second panel that small space flaps up and down at speed. Stick a washer in it and you are good to go no rattle
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 10:09 AM
Soft Touch Materials in car are easily scratched! Spd229 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 06-21-2012 11:05 PM
Depth of speed DIG1992 Other Vehicles & General Automotive Discussions 6 05-22-2012 01:13 PM
Speed TV FR-S review Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 10 05-09-2012 11:41 AM
Need For Speed Shift 2 Dragonitti Other Vehicles & General Automotive Discussions 12 04-09-2011 10:49 PM
