Old 12-19-2016, 06:50 PM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Hissing clutch noise
Hi,
When I cold start my car this morning, my clutch is making a hissing sound when I press and release, and it is gone after the car is warm up.
Is it a problem i should concern or it is normal because of the cold weather?
Thanks
FR-Sky is offline   Reply With Quote
Old 12-19-2016, 06:56 PM   #2
Oh, maybe the clutch parts (TOB) and transmission are just getting warmed up.
I wouldn't worry about it unless it gets worse.
Old 12-19-2016, 06:59 PM   #3
Can you make a recording?
Does it hiss when your foot is off of the clutch, or when you are pressing it?
Old 12-19-2016, 07:35 PM   #4
FR-Sky
FR-Sky's Avatar
Yea it just happened this morning between 1C-5C
Old 12-19-2016, 07:36 PM   #5
FR-Sky
FR-Sky's Avatar
It only happen when press and depress, its gone when my foot completely off the pedal.
Also, its gone like 5-10mins after driving.
Old 12-19-2016, 07:45 PM   #6
Is it more like a "squeak" than a "hiss" ... ??
Squeak, like an old rusty spring ... ??
Old 12-19-2016, 07:48 PM   #7
FR-Sky
FR-Sky's Avatar
I am pretty sure its hissing noise, its like air leaking sound.
The Following User Says Thank You to FR-Sky For This Useful Post:
Ultramaroon (12-19-2016)
Old 12-19-2016, 07:48 PM   #8
Do you mean as you are moving the clutch pedal?
FR-Sky (12-19-2016)
Old 12-19-2016, 07:49 PM   #9
FR-Sky
FR-Sky's Avatar
Yes!
Old 12-19-2016, 07:53 PM   #10
Yes!
Wow! Ok, I've never heard that.
Check your clutch fluid level in the reservoir. I can only make a crazy guess. that it might be air bubbles being forced through the small orifices in the master cylinder/clutch delay valve.
Hopefully someone else will recognize the symptom.
FR-Sky (12-19-2016)
Old 12-19-2016, 07:56 PM   #11
FR-Sky
FR-Sky's Avatar
What can I do at this point =[ ? I search alot on google and i cant find answer.
add fluid clutch? ignore it? normal in cold weather?
sad
Old 12-19-2016, 08:15 PM   #12
sad
Well, to follow up on what @Ultramaroon mentioned, first check the fluid level.
If it is up to the full mark, you may consider bleeding the clutch system to rid it of any air.
But, like I mentioned before .....I wouldn't go messing with it (other than bleeding the system) unless it gets worse.
FR-Sky (12-19-2016)
Old 12-19-2016, 09:26 PM   #13
sad
Impossible to know. What color is your clutch fluid? Is it nice pretty yellow?
Like @humfrz said, if the reservoir is full just give it time to feel/listen for it to get worse.
Things to watch:
1. Extra pedal resistance. If it feels like it's binding then be careful to not break the clutch fork.
2. Trouble getting into gear. If the pedal feels mushy and you have trouble getting it into gear then there is air getting into the system. The only way that happens is by completely draining the fluid from the reservoir. Watch the level carefully.
Old 12-19-2016, 09:33 PM   #14
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Mine is doing the same. Haven't though about old fluid. Might try a new stuff.
I was thinking it could be the TOB. But is been shifting fine since it began in the summer.
Hissing/rattle from 3.5-4k RPM after OFT illmatic_frs Engine, Exhaust, Transmission 28 03-21-2017 08:02 PM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
clutch grinding noise BoxerBlock88 Engine, Exhaust, Transmission 13 11-14-2015 06:12 AM
Clutch scraping noise 8 six Scion FR-S / Toyota 86 GT86 General Forum 31 01-05-2015 02:39 PM
Winding Noise From Clutch Bach415 Northern California 0 06-24-2013 07:19 PM
