Drives: 2013 Scion FR-S (Firestorm)
After some cold weather, the passenger window no longer works
It's also stuck in the "door open" position (where the window goes down just slightly). I've warmed up the car in the garage and the window doesn't do anything. It seems stuck in this position. Has anyone experienced this and knows a fix?
#2 |
#3 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Hold the switch for that window all the way down (window "down" position) for 10 seconds. Then hold the switch in the "window up" position for 10 seconds. This will reset the window motor settings and it should work fine after.
Same fix works for the driver's side. Do this after every time the window freezes in the future. It is a common issue, and my windows have done it at least once per season since I got the car. You're welcome.
@bpennerz
| The Following User Says Thank You to SLVRSRFR For This Useful Post: | humfrz (12-16-2016) |
#4 | |
of the day for not ![]() ![]() humfrz |
| Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 02:14 PM |
| The cold weather is here... | echo419 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-17-2015 09:28 AM |
| Power window fault in cold weather | Suberman | Issues | Warranty | Recalls / TSB | 5 | 01-09-2014 09:24 AM |
| e85 in NY cold weather | whitefrs | Forced Induction | 5 | 12-10-2013 09:52 PM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
