Drives: 13 BRZ, 13 Raptor, 69 Nova, 07 675
Spyder Headlight help!
So I bought Spyder headlights for my 13 BRZ and I'm completely lost on how to hook them up, I'm guessing I'm missing a ballast or something because When I bought the car it came with the stock FRS headlights. Below is a link to the lights I bought and 2 pictures of the connections. Picture 1 is the headlights connection and picture 2 is the 3 connection the car has. Any help would be appreciated it. Thank you
http://www.spyderauto.com/product.ph...-DRL-LED-Black |
#2 |
Drives: 2025 BRZ, ex-2012 GT86
You are missing stock ballasts and actually xenon lightbulbs
BRZ came with FRS galogens??... Why? The FRS headlights come with 6-pin connectors, so it wont be plug and play for you. The bottom pic shows some aftermarket stuff I think.
#3 |
Drives: Asphalt 2015 FRS
Here in the US, you won't have xenons with a ballast..I don't remember what the connections on the car end look like exactly, but you are holding 3 connectors there that look more like the connections for the turn signal/fog/side marker area
Edit: Followed the link you posted and looks like you bought the BRZ version which have the turn signals incorporated in the headlight. You can either repin your car so your headlights are your blinkers or you should return the headlight for the FRS version (6-pin connector)
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
#4 | |
#5 |
Drives: 13' Satin White Pearl BRZ
From your link, it seems that you purchased the correct ones. However, what did you actually get? Can you verify P/N on the box? It looks like you may have been shipped the FRS version? Can you call Spyder and ask? When you removed the OEM lights, did you have any parts that need to be moved from one headlight to another?
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
#6 |
Drives: FRS
so you have a BRZ but had the stock halogen FRS headlights installed instead?
#7 |
#8 |
Drives: Black 86 GTS
Are you sure that's the headlight connectors in the bottom pic? They look like 2pin connectors so can't be right. The triangular 3 pin connector is one of the correct ones, it will connect to the level motor. Check under your stock headlight the connector is usually there
#9 | |
#10 |
I think what I need to do is buy a 8pin pigtail to plug into the headlight, and use the diagram below to cut the 2pin plugs and wire them to the 8pin
#11 |
My bad. Your post reads a little confusing. Couldn't wrap my head around why a BRZ would have FRS headlights...seems like quite the downgrade
#12 |
Ok I see what's going on.
You need to follow those 2 pin connectors eventually they join into a single connector. Which is 8pin for brz and 6 pin for frs. But if previous owner has installed frs lights it was probably custom and the cable may have been removed. |
| Spyder Headlight install wiring guide. | sk900 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-05-2018 09:54 PM |
| F/S Invidia n1 catback exhaust system/ spyder smoked headlight | KevinLy | Engine, Exhaust, Bolt-Ons | 12 | 02-10-2016 01:02 AM |
| WTB: TRD Exhaust, borla UEL, Valenti taillight, spyder headlight, Eibach | BTXP.XD | Canada Classifieds | 1 | 06-22-2015 03:46 PM |
| **PHASTEK** Spyder Headlight Preorder List | PhastekSport | Exterior Parts - Lighting | 141 | 02-03-2015 02:12 PM |
| **Spyder LED Headlight Black or Chrome FR-S/BRZ/GT86 Pre-Order -Vicious LED** | Vicious LED | Exterior Parts - Lighting | 21 | 12-05-2013 01:40 PM |
