Old 12-16-2016, 12:37 AM   #15
koast2koast
Drives: 2015 Toyota 86 high spec Auto, TRD
Had a cap too, but did not need it, so did not install it.
My headlights dimmed in my Acura.
That tells me you did need the cap.
koast2koast is offline   Reply With Quote
Old 12-16-2016, 12:55 AM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Lol. No. The cap came out of the acura. Did not need it in my FR-S.
I was going to get an extra battery and a dual charge kit for the acura. But, already had zero trunk room. Sold the earthquakes. (26lbs each) went to two JL 12's in a smaller box. More efficient.
I have one 10" in my FR-S...
Welcome to the forum!
Edit: clarification...
Old 12-18-2016, 02:33 PM   #17
koast2koast
Ah ok thanks for the details! I'm actually busy putting in two 12" subs (800 RMS each) so the big three is the beginning of my fitment escapades. Fun times ahead!
Thanks for the welcome
The Following User Says Thank You to koast2koast For This Useful Post:
Leonardo (12-18-2016)
Old 03-01-2017, 04:07 AM   #18
jslack
Drives: 2017 Red subaru BRZ Limited
Just finished installing my wiring in the engine bay for the big 3. Used 0 gauge and went from positive battery terminal to the post of the alternator. Then from negative battery post to the factory ground on the right strut tower wall, and then from the back of the engine block to the same grounding point. Soldered the ends on and used heat shrink. also ground down the metal at the grounding point to bare metal just to make sure.
jslack is offline   Reply With Quote
Old 03-01-2017, 10:56 PM   #19
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Originally Posted by crazyfrenchbiker View Post
The total system should be around 2500W RMS.
Class A, B or D?
or better yet, what amps?
Class D I wouldn't even worry. if it's Class A (Which i'd highly doubt), upgrade everything.
I am running a Audison Voce 5.1k, haven't upgraded anything apart from the battery, and running 4g
One of my older setups in a previous car, 5kw class D and 300-400wrms Class A/B (5kw was swapped out for 800wrms A/B for SQ comps)
Never upgraded Alternator/earth from the battery.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 03-01-2017, 11:01 PM   #20
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
If your lights are dimming, you don't need a cap.
it's a myth that just won't die.. probably cause car audio companies want you to keep buying them.
Upgrade your power system, better battery, better alternator if you are really dragging out some power and the alternator is old.
The Following User Says Thank You to fuddbutter For This Useful Post:
kmbkk (03-02-2017)
Old 05-26-2018, 12:45 AM   #21
ILLEST_GT86
Drives: 2017 Toyota 86
Started my big 3
Preparing for my stereo install
ILLEST_GT86 is offline   Reply With Quote
Old 12-10-2018, 04:02 AM   #22
Nosreves
Drives: 2017 Toyota 86 Raven
I have my stereo in, but neglected my big 3 because I'm lazy and dumb. I will be doing it with 0 gauge wire, and the from inspecting the engine bay it will be the easiest big 3 I've ever done haha. My question for you is why did you route over things instead of tucking wires?
Nosreves is offline   Reply With Quote
Old 12-19-2018, 04:26 PM   #23
Go Frogs
Go Frogs's Avatar
Drives: '19 WRX Base in Lapis Blue
Red wires for ground (wires). Is that a good idea?
I know the car is red, but it just seem off and unnatural.
Also, when running a grounding kit, isn't it a good idea to have the wires go from fender to fender while making connections in between (block, manifold, etc.) to tie several engine grounds together to make one large ground array?
-- Yay for mk4 jetta in the background.
#Savethemanuals
#Savethewagons
#Savethemanualwagons
Dear SoA, what petition do I need to sign to bring the LeVorg 2.0t 6spd to North America?
Go Frogs is offline   Reply With Quote
Need to upgrade the oil pan for the FRS/BRZ? Hanakuso Engine, Exhaust, Transmission 5 12-28-2014 12:54 PM
HU upgrade briang0901 Electronics | Audio | NAV | Infotainment 15 11-05-2012 11:17 AM
Anyone Looking To Upgrade Their LSD? SpeedBRZ Engine, Exhaust, Transmission 27 07-19-2012 06:33 PM
FR-S HID Upgrade? frsinpa Cosmetic Modification (Interior/Exterior/Lighting) 25 06-18-2012 08:43 AM
What will be the first upgrade you buy for your FR-S / BRZ? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 9 02-26-2012 07:30 PM
