Old 12-07-2016, 01:17 PM   #855
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by Riftur View Post
Gonna try this out tomorrow. I have the day off. How do I know if it is running to rich or lean? What should I look for? Also thanks for helping me out. Do you think the tablet can withstand the heat if I leave the tablet mounted in the car?
I forgot to mention, the 2nd part of datalogging is that you want to record a 3rd gear WOT (wide open throttle, ie: floor it) pull from 2000rpm to redline. Making sure to record that whole process...so find a deserted stretch of road where you can safely do this.
Once you get the datalog, you can upload the csv to the site or http://www.datazap.me/ is popular as well. Let the folks that know about tuning tell you how the AFR is It can be a bit overwhelming at first getting to learn things...
The tablet will probably be fine mounted in the car. Not much of a benefit in doing that in my opinion, but that's just me. I plug mine in and out as needed.
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
Riftur (12-07-2016), Teseo (12-09-2016)
Old 12-07-2016, 03:48 PM   #856
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Hey guys I have a few quick questions. I have Perrin 2.75" intake, and I've recently revised my MAF scaling to the values that Perrin provides, and at WOT my AFR is now just under the Command AFR by about 0.4 the majority of the time, but my LTFT goes up to +3.91.
On my previous MAF Scale (the default OFT Stg2 one), my AFR was a good bit lower than the Command (usually lower by 0.6-1), but the LTFT value was around -2.34.
Would a positive or negative LTFT value be preferable over the other? And is it better to be closer to the target AFR but have a slightly larger LTFT value?
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 12-08-2016, 05:37 AM   #857
steve99
Drives: FT86
I am a complete novice when it comes to tuning a car. My entire experience tuning a car consists of clicking the button to write the A/T stage 1 93 octane tune. lol If you could provide me with some instructions that would be great. Also I am thinking of mounting the tablet in my car and was wondering if the heat will ruin the tablet. I live in south Florida so it gets pretty hot.
Thanks in advance,
Have a read og the Green link below ECU Logging" and the OFT TIPS link as well
Should get you started with logging :-)
Riftur (12-08-2016)
Old 12-09-2016, 01:54 PM   #858
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Fuel trims can be the result of multiple things, but i think +/- 5 is okay for the fuel trims combined. And your AFR's sound close, both command and actual will vary a little bit as well. There are spreadsheets/tools available to help scale MAF more accurately.
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
The Following User Says Thank You to MurderousPandas For This Useful Post:
BFIFE22 (12-13-2016)
Old 12-09-2016, 02:58 PM   #859
ImDatSlaya
ImDatSlaya's Avatar
Drives: No
Wow after reading this thread apparently I need to do some data logging to make sure everything is running smoothly.
Sent from my ONEPLUS A3000 using Tapatalk
ImDatSlaya is offline   Reply With Quote
Old 12-10-2016, 05:21 AM   #860
steve99
Drives: FT86
most usa/Canada cars will be fine, its mainly the European/Australian ones that need a bit of tweaking due different fuel formulation and qualities
OrangeGuitar (12-10-2016)
Old 12-10-2016, 05:56 AM   #861
ImDatSlaya
ImDatSlaya's Avatar
Drives: No
I'm running Perrin 2.5 exhaust, invidia front pipe, OFH, perrin pulleys, perrin drop in filter with e85 stage 2 tune.
Old 12-10-2016, 09:25 PM   #862
steve99
Drives: FT86
That should be fine, just log you afr vs commanded afr and see its not running too rich higher rpm your looking for low 12 afr on e85
Old 12-15-2016, 01:57 PM   #863
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I put in a tank of Shell 91oct and it only went up to 0.21
Originally Posted by Teseo View Post
Try to run a tank with higher octane and do some pulls to see what you get.
Originally Posted by humfrz
I'm old and lazy
Old 12-15-2016, 06:52 PM   #864
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Just bought used OFT from one of the users here. I plugged it into car but nothing happens - screen stays 100% black. Plugged it into computer and it turns on just fine. Also, OFM recognizes it, reads it, but says there are no devices installed. Any ideas?
carsebuco is offline   Reply With Quote
Old 12-15-2016, 07:04 PM   #865
steve99
Drives: FT86
If it turns on when plugged into computer oft is likely ok.
If it wont power up connected to obd port in car make sure the obd plug is in all the way and the other end of cable in oft is in tight.
If still no go the obd port fuse may be blown in car. check you have volts at pin 16 on obd port to chassis ground (or pin 5) should see 12v on pin 16 with ignition on.
also the oft/ofm software does not like usb-3 ports try a usb 2 port
The Following 2 Users Say Thank You to steve99 For This Useful Post:
carsebuco (12-17-2016), Teseo (12-15-2016)
Old 12-15-2016, 07:23 PM   #866
Teseo
Drives: frs
How much heat can handle the oft? Leaving it inside of the car with hot or bloody hot weather
Old 12-15-2016, 07:31 PM   #867
ImDatSlaya
ImDatSlaya's Avatar
Drives: No
Was the same thing when I was cruising at 80mph.
Old 12-15-2016, 08:35 PM   #868
steve99
Drives: FT86
log commanded AFR instead of Atmospheric pressure.
save a log file with a few minutes of normal driving and a WOT run.
The LTFT looks high positive +15% , which is a bit unusual, if you had residual petrol in tank it would be high negative.
Im suspecting you might have exhaust/intake leak, or your running a petrol tune :-) on E85
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
