Old 12-07-2016, 09:16 PM   #2031
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
Sorry. 18x9.5 +38.
Sent from my SM-N900W8 using Tapatalk
adrixe is offline   Reply With Quote
Old 12-08-2016, 12:29 PM   #2032
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by adrixe View Post
Sorry. 18x9.5 +38.
I would read through page 1 of this thread to start with. Tons of great info.
Quoted from page 1.
"1) Most of us run a coilover, you really won't fit a 9.5 wheel up front with stock struts"
Good luck!
Jive Turkey (12-08-2016)
Old 12-08-2016, 07:19 PM   #2033
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yeah a 9.5 up front on stock struts just won't work.
255/35-265/35 those are the tire sizes to consider...
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
Leonardo (12-08-2016)
Old 12-08-2016, 08:08 PM   #2034
adrixe
adrixe's Avatar
Thanks!
Old 12-09-2016, 11:16 AM   #2035
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Haha. So Mark @RavSpec had to stop me 3 times to confirm I knew what I was ordering. They keep insisting my offsets are too high and conservative. 18x9+47 R disk / 18x10+50 A disk.
Ill be buying 265/35 and 285/35 respectively and dont want to roll fenders on a 1.5-2.0" drop and -0.5F/0.0R camber.
Crossing my fingers I havent made a HUGE mistake. I guess we'll see in 12-15 weeks when they get here. Ill post pics as soon as they get mounted. #turbocarfitment
xkalelx is offline   Reply With Quote
Old 12-09-2016, 04:58 PM   #2036
djdnz
1337
Drives: 2013 BRZ WRB S/C
You might rub on the inner side of the fender liners in the front a little bit at close to full lock and hard turns. I have 19x9.5+43 with 265/30/19 which is pretty close to your setup and it rubs inside (as well as the fender itself ). Depends how low you are as well.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
xkalelx (12-11-2016)
Old 12-12-2016, 12:11 AM   #2037
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
You'll likely rub on the inside. Likely the brake line brackets and possibly your coils. You have coils right.?
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 12-13-2016, 09:46 AM   #2038
xkalelx
xkalelx's Avatar
Yeah, I posted pictures on pg145. Im running Ohlins and measured how much room I had to play with before ordering. I should have plenty of room... Ill move the brake line brackets if they get in the way but I doubt they will. Only concern right now is full lock rubbing. Ill post results!
Old 12-14-2016, 08:25 AM   #2039
15limited
15limited's Avatar
You have to wait HOW LONG for wheels? 😱
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 12-15-2016, 03:02 PM   #2040
xkalelx
xkalelx's Avatar
Yeah, I know... the only thing they have in stock is the 18x9.5+38. So they are being built to my specification request. Doesnt cost anymore to do it that way, just takes 3-4 months to get them custom wheels in mah hands.
Old 12-16-2016, 08:07 AM   #2041
nima314
Drives: Subaru BRZ 2017 (almost)
I got mine after around 12 weeks from WORK custom made
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 12-16-2016, 11:08 AM   #2042
gregman
gregman's Avatar
Drives: Boner Garage
Originally Posted by DustinS View Post
Throwing this out there before you get roasted. Wrong thread... This is the Meaty Tire Thread...
You want: "Aggressive" Wheels Thread
Thanks for the help.
still new to the site.
gregman is offline   Reply With Quote
Old 12-20-2016, 10:47 AM   #2043
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
To anyone else running 265/35/18 in the rear, what are your alignment specs? I'm sitting on factory settings now after getting new wheels and was having rubbing issues with the tire sidewall actually hitting the fender. I took the car in for a realignment and they said they couldn't add any more rear camber without rubbing the inside??
I'm only lowered about 3/4" in the rear, something sounds fishy.
amaciose is offline   Reply With Quote
Old 12-20-2016, 12:20 PM   #2044
FaDuck
Drives: 2014 UltraMarine FRS
My plan is to go with 265's as well, and from what Ive gathered on this site, as long as you have coilovers/atleast a +40 offset/and -2 degrees camber, you should be fine. Hmmm...
FaDuck is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
