#29 |
Drives: FRS Silver LS1 swapped.
Happy to see another swap project .
| The Following User Says Thank You to cf6mech For This Useful Post: | Sportsguy83 (12-10-2016) |
#30 |
I Love custom Turbo kits
Drives: Limited BRZ
#31 |
As they would say, as in critics, it isn't self built. But it was a concept I and it seemed another entity had and it came together. Another shop actually planted the seed and have been very helpful as well......The can- bus guru was found by another shop in Seattle who through this forum contacted me.......so this forum and car forums in general which many are critical of has been extremely helpful to me and I'm thankful for all involved, Truly wish you luck on your conversion.
| The Following 9 Users Say Thank You to cf6mech For This Useful Post: | Calum (12-12-2016), civicdrivr (12-12-2016), Draco_PR23 (12-11-2016), DustinS (12-11-2016), kmbkk (12-11-2016), Sojhinn (02-12-2017), Sportsguy83 (12-11-2016), wooly35 (12-11-2016), wparsons (12-19-2016) |
#32 |
Use the FiTech Ultimate LS ECU. It will be released next month. I am running it on my own swap and it is great.
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | Sportsguy83 (12-18-2016) |
#33 |
That Guy
Drives: 2013 asphalt FRS MT
#34 |
Drives: 10 Series Scion FR-S
Papi's thread... can't miss this
| The Following User Says Thank You to Cartman For This Useful Post: | Sportsguy83 (12-18-2016) |
#35 |
Full self tuning kit with aluminum LS style intake manifold, throttle body, injectors, engine ecu & ignition box, wire harness, knock sensor control, boost control, etc. literally everything for only $1500. Designed, tested, and supported here in California. It's as kick ass as it gets.
| The Following 2 Users Say Thank You to Amir Ghadiri For This Useful Post: | Calum (12-19-2016), Draco_PR23 (12-19-2016) |
#36 | |
Drives: Limited BRZ
#37 | |
It's a standalone EMS. Not meant to integrate with CAN systems. You can still setup your EPS, Tach, ABS with an Arduino, but no TC, Cruise, etc.
#38 |
2010 WRX - 2015 FRS
Drives: 2015 FRS
so besides the engine swap... what transmission are you getting? what about the drivetrain and axles, power steering, fuel system, cooling?? wtf happens to all that?
Although i wana do the same to my FRS this sounds like a nightmare and you"ll lose some of the luxuries that came with the car
2010 Subaru WRX - 2015 Scion FR-S
"Life's too short to drive boring cars" |
#39 | |
Drives: 2015 Raven V8
#40 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
You lose nothing. All OEM features work. It's expensive and time consuming, but not prohibitively so. A proper kit will supposedly exist... Eventually. For MT, most people use t56. TR6060's and TKO's get used, rarely. The frs differential is very robust. Power steering is electric and self-contained. It needs a few ECU signals to start and work. Stock returnless fuel system can be used, with a pump change only necessary for peak flow. There are plenty of pumps available off-the-shelf. There is plenty of space for a sufficient radiator... The stock A/C system needs 2 new compressor lines, but can otherwise be completely reused. Weight increase is negligible. The car needs only 1 sheetmetal mod in the transmission tunnel. It involves cutting a few spot welds and throwing away a small stamped steel brace, which can be replaced.
There are many ways to displace.
-Spartarus Last edited by Spartarus; 12-23-2016 at 11:08 PM. |
| The Following 4 Users Say Thank You to Spartarus For This Useful Post: |
#41 | |
Panda Trueno
Drives: No twin now.
#42 | |
2010 WRX - 2015 FRS
Drives: 2015 FRS
| Sportsguy's LS2 Swapped BRZ | Sportsguy83 | Member's Car Journals | 2969 | 08-20-2018 11:12 AM |
| FS: (Sold) Sportsguy ArmRest | kvnchu | Interior Parts (Incl. Lighting) | 22 | 03-13-2014 02:40 PM |
| Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly | Sportsguy83 | Forced Induction | 155 | 08-05-2013 06:17 PM |
| Motegi 126 customs | kioton32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-26-2013 12:34 AM |
| FS: NY - Sportsguy Handcrafted Armrest | xxscaxx | Interior Parts (Incl. Lighting) | 43 | 05-04-2013 05:30 PM |
