Old 11-22-2016, 11:57 PM   #253
-Willis-86touge
Drives: Stock
Originally Posted by Alltezza View Post
Well then......learned something new lol I'll tell him to run 4th gear next time I hop on. Thanks, but yeah lol I hope everyone finds this heart breaker dyno useful.
5th gear is 1:1 the other person was wrong and the dyno guy was right
-Willis-86touge is offline   Reply With Quote
Old 12-10-2016, 09:05 PM   #254
n0thing
Drives: Subaru BRZ
Originally Posted by brzd View Post
Just installed & flashed to stage 2! It's great! A lot quieter than I expected on the stock exhaust. Maybe after driving with an N1 my ears have been damaged LOL
Anyways I have that ticking/hissing/puttering noise under load that other owners have claimed as well. Did it eventually go away?
just had the header + op installed with stock fp, i'm noticing this hissing/rattling noise during cold start (around 1800rpm), very noticeable from outside below passenger fender/door area. noise goes away when the car is warmed up. while driving i notice it in the cabin around passenger floor area every time i accelerate/blip the throttle above 2krpm, the noise goes away if i hold the throttle though. does this header rub against the skidplate like some headers do?
n0thing is offline   Reply With Quote
Old 12-10-2016, 09:13 PM   #255
brzd
brzd's Avatar
Drives: Firestorm FRS
Startup with a catless uel is sounds pretty loud rattly until it warms up if you didn't edit your start up values in your ROM.
The sand rattling on the passenger side under acceleration never went away but you get used to it. I went to a few exhaust shops & did a smoke test no leaks. I think it's just the thin walls on the header.
Sent from my SM-G920W8 using Tapatalk
brzd is offline   Reply With Quote
The Following 2 Users Say Thank You to brzd For This Useful Post:
drew_kar (12-11-2016), shellslinger (12-11-2016)
Old 12-12-2016, 05:53 AM   #256
dratom
Drives:
My header rubbed the skid plate. If the bar for the slip joints points down then look for rub marks on the alloy plate. It was pretty obvious on mine. Fixed it with a hammer and punch.
dratom is offline   Reply With Quote
Old 12-12-2016, 09:20 AM   #257
brzd
brzd's Avatar
Got a few PM's about my cold start values. Here's mine:
Car starts up pretty quiet after doing this; like what it normally would with just a catback but with a rumble cause of the UEL
PS. Now that it's winter and the temps are lower I find that my remote starter has been finnicky at times. I'm not exactly sure if it's connected to this or why but I'm trying to figure it out
Old 12-12-2016, 10:56 PM   #258
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
This is what works for me
I wonder why your RPM delta is at 3600? Mine is at -10000. It affects when Overrun Enrichment activates. These are the lowest MAF settings I've been able to use, and still get it start reliably, even in cold weather. I also warmed up the timing a bit, since retarded timing causes loud starts.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 12-13-2016, 09:41 AM   #259
brzd
brzd's Avatar
Oh that's for launch control... not overrun overrun fueling. I took the pic to remind me of the changes I made sorry for the confusion
Old 01-30-2017, 10:15 PM   #260
Qc86
Drives: 2017 Toyota 86 M6
I'm in the market to buy uel for my 2017 86 and I really love the gruppe s. Do any of you that had the gruppe s header for over a years had any problems (leaks, cracks etc)? I've done a lot of research but overall the gruppe s seems to be a really good header for the price and I haven't seen bad review about yet. Thanks for any output
Qc86 is offline   Reply With Quote
The Following User Says Thank You to Qc86 For This Useful Post:
Strife26 (01-30-2017)
Old 01-30-2017, 10:31 PM   #261
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Maybe a year but no problems so far and I've replaced the down pipe 3x now
Sent from my SM-G930T using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 01-31-2017, 08:45 AM   #262
Qc86
Nice and by the downpipe you mean the frontpipe? Why did you replace it 3x?
Old 01-31-2017, 10:08 AM   #263
Strife26
Strife26's Avatar
Took off stock for an aftermarket (cheap) then got a while new exhaust (after the header) and had to replace it again. I think it goes downpipe, front pipe, mid pipe exhaust? I replaced the smallest shortest pipe 3x.
Old 01-31-2017, 10:34 AM   #264
jawnthen
Drives: 2013 BRZ Limited 6AT
Originally Posted by Token11b View Post
Added sound clip for those curious
Can you do one from inside? Is there any drone with the stock exhaust?
Sent from my Pixel using Tapatalk
jawnthen is offline   Reply With Quote
Old 01-31-2017, 11:21 AM   #265
Strife26
Strife26's Avatar
I have some in cabin videos. I think those were with spec d exhaust and catted stock fp.
The Following User Says Thank You to Strife26 For This Useful Post:
jawnthen (01-31-2017)
Old 01-31-2017, 11:30 AM   #266
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I've had mine arguably the longest, and everything is still good!
A few thousand miles n/a, and the rest have been with boost.
Highly recommend this header!
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
brzd (01-31-2017), Strife26 (01-31-2017)
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 09:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 12:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 07:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
