Old 12-01-2016, 01:16 PM   #1
max20s14
Drives: 14' Raven M/T - 02' is300
Tire Suggestion for new wheels? :)
Alright guys just got my 2014 fr-s a few weeks ago. Got some xxr 527s 17x8.25 on black Friday.
Trying to find the right tire.
I am looking for a 225/45/r17 tire that will retain the slide-ability/fun of the stock primacies for fairly cheap.
I know the primacies will fit but I don't want to stretch them. not a fan of stretched tires.
Some I am considering:
Sumitomo HTR Z II
Yokohama avid
Hankook ventus s1 noble
Contenental extreme contact dw(I hear these have a weak sidewall)
General amax as-03
Thanks in advance
max20s14 is offline   Reply With Quote
Old 12-01-2016, 01:37 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
I have the DW. Have run them for 2 years on my brz. Great tire in the rain and dry well worth the money in my opinion.
jasonojordan is offline   Reply With Quote
Old 12-01-2016, 02:19 PM   #3
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Try throwing the newer Firestone Firehawk Indy 500 on your list. Had the opportunity to test these recently and they grip much better than the stock Primacies, but without the crazy amount of grip or turn in response of the MPSS. Comes in very affordable in the 225 size. I plan to put a set on my new wheels in the spring, except I may size up because the tread width is about the same as the primacies and not as wide as the max performance tires, so a small size may look stretched.
I've also driven the continentals, and they are also a very good option, and are also inexpensive when on sale.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 12-01-2016, 02:48 PM   #4
DarkSunrise
DarkSunrise's Avatar
If you're considering Sumitomos, go with the HTR ZIII instead of ZII. I used the ZIII a few years ago for street and track, and it was a solid budget MP tire. Quiet & smooth on the road, but sporty enough for some track use. Not as sticky as an EP tire (or even Pilot Super Sports), but sounds like you're not looking for something too grippy. Only negatives are they squeal loudly when you push them in corners, and will chunk if you track often and without enough camber.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
yelsew (12-01-2016)
Old 12-01-2016, 02:52 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+1 HTR Z III
IMO a great budget tire.
Old 12-01-2016, 02:55 PM   #6
max20s14
Yeah I am not going to be tracking often and would prefer a tire I can break loose on stock power
Old 12-01-2016, 07:50 PM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Then honestly the tires you listed probably all have too much grip. General Altimax might be a better solution if you want them to slip a little at normal driving speeds.
Even high performance all seasons can have too much grip for fun on the streets. I run altimax on my yaris and they have boatloads more grip than the previous crappy all seasons I had.
why? is offline   Reply With Quote
Old 12-08-2016, 12:08 PM   #8
max20s14
I picked up some Firestone Firehawk Wide Oval Indy 500's for $67/per tire. Not Bad. Loads more grip.. Now I just have to make up for it with more power.
Old 12-09-2016, 12:15 PM   #9
Vital
Drives: 2015 BRZ
Would you mind posting some pics? i'd like to get these wheels too and go with a 225/45 tire I'd like to see how it looks on that tire size. Most of the pics i see are with a 245/40 tire.
Old 12-09-2016, 03:09 PM   #10
max20s14
let me know If this link works:
https://goo.gl/photos/hGQo71KpZqNHVQsu8
If not I can upload it elsewhere when I get a chance.
It looks really good to me. Just needs more low..
I did not like the pics I saw of the stock tires on these wheels.
The Following User Says Thank You to max20s14 For This Useful Post:
Vital (12-09-2016)
Old 12-09-2016, 04:10 PM   #11
Vital
Drives: 2015 BRZ
Yep that link worked. Looks great! Do you happen to have a side shot just so i can see how much gap there from the fender. Also, whats the offset you have +35?
Old 12-09-2016, 04:39 PM   #12
max20s14
I do not have one on hand, but I will take one when I get a chance.
and yes these are +35
Old 12-12-2016, 11:36 AM   #13
FX86
Nitto Motivo or Nitto Neo Gen
Old 12-12-2016, 01:49 PM   #14
Vital
Drives: 2015 BRZ
Were you able to get some side shots yet? lol
New Tire Suggestion FloridaBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-28-2015 11:19 PM
Tire Size Suggestion ExxelDistributions Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-12-2014 07:39 PM
Wheels color suggestion~~ PLZ Quanye BRZ First-Gen (2012+) — General Topics 5 09-14-2014 12:31 PM
Tire suggestion...245/35/18 with good grip and 20k continuecrushing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-01-2014 07:24 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
