Old 11-01-2016, 05:45 PM   #673
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Originally Posted by novice View Post
will I need these to have no poke? or can i slap the wheels right on there?
Eh... there's a small bit of poke on the +35 without any negative camber... to tuck in mayyybe quarter to half inch -ish of rubber visible from looking at the front of the car head-on... at the top of the wheel wells, but people can run that setup still without rubbing. The natural camber with the drop in the rear will work itself out perfectly.
Toyarzee is offline   Reply With Quote
Old 11-01-2016, 08:04 PM   #674
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Has anyone here switched from a 18x9.5 wheel to these?
I've got Gramlights right now, and they're fairly heavy. I like how they look, but they make the car seem super sluggish.
Is it worth the switch to these RPF1's?
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 11-02-2016, 12:18 AM   #675
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Steering feel will be better. How do you use your car? If you've got 57dr or the such, a switch from those to 17x9 rpf1's should be around a 7-8 pound weight saving per corner in wheel weight alone.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Bowen (11-02-2016)
Old 11-03-2016, 12:43 AM   #676
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Has anyone tried these centre caps from Flatout Graphics? I'm thinking about purchasing a set.
You can choose the colour of the Enkei sympbol. They're made from plastic with a metal retaining clip, but they look alright for the price.
https://flatoutgfx.com/products/enkei-rpf1-center-caps
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
DocWalt (01-25-2017)
Old 11-04-2016, 12:22 AM   #677
Wise
Circle Work Clerk
Pulled the trigger and purchased a set with the red enkei logo for my black RPF1's.
I'll post some pics when I receive them.
Husker BRZ (11-04-2016)
Old 12-09-2016, 12:15 AM   #678
86fit
86fit's Avatar
Drives: 2016 Asphalt FRS
17x9 +35 245/40R17 Polished Aluminum base coat with Deep Red Candy
Alignment
front:
camber -1.5
toe +.05
rear:
camber -1.2
toe zero
86fit is offline   Reply With Quote
Old 12-09-2016, 07:02 AM   #679
novice
novice's Avatar
Drives: Fr-S 2.0 Release
nice. I'd like to see this with less flash on there or subtle daylight. Looks vampiry though, rock n roll!
novice is offline   Reply With Quote
Old 12-13-2016, 08:19 AM   #680
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Jesus. I thought my RPF1s were bright.
Old 12-18-2016, 02:16 AM   #681
Wise
Circle Work Clerk
Finally gave the car a wash today so I thought I'd post some pics of the wheels with the flatout graphics centre caps on.
Overall I'm pretty pretty happy with the result. They look like they're made by Enkei, but look less conspicuous than the chrome RPF1 centre caps that Enkei actually makes.
The Following 3 Users Say Thank You to Wise For This Useful Post:
DocWalt (01-25-2017), smg1138 (01-25-2017), swarb (02-22-2017)
Old 12-20-2016, 11:37 AM   #682
86fit
86fit's Avatar
The Following 2 Users Say Thank You to 86fit For This Useful Post:
Hostile_Kittens (01-01-2017), swarb (02-22-2017)
Old 12-20-2016, 11:38 AM   #683
86fit
86fit's Avatar
The Following User Says Thank You to 86fit For This Useful Post:
Old 01-25-2017, 02:15 PM   #684
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
This is a repost from the official rpf1 thread...
For those wondering how much the 17x9 +35 weighs....
Used a bathroom scale (bought November 2016). The center cap was mounted on the OE wheel as were some weights from getting the wheel/tire balanced.
For those wondering how much the said size pokes with 245/40 MPSS....
The car has been dropped by -1.2". Rears were 3mm/ .19" higher.
Camber out back was -1.7 with a 1/16" total toe (1/32" per side)
Camber up front was -2.0 with 0 toe.
I'd say that the lip of the wheel is pretty flush. The top of the tires tuck into the fenders. Some people would say that the setting sits flush. I say otherwise. There's a sidewall poke...though the tire treads tuck into the wheel well.
Edit:
My steering wheel was straight when I took the photo so there shouldn't be any more/less poking going on in the shot(s).
For those wondering what having the 17x9 +35 with 245/40's on -2.0 camber up front....0 toe. Steering wheel was straight for the shot. I'm dropped about 1.2" from Tein Flex Z's. Everything else is stock. No additional camber bolts and what not.
Note the angles of the shot. The fender doesn't go straight down...it's angled...you can see how the tire tucks in relative to the angle of the fender's flat part.
SHWNBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to SHWNBRZ For This Useful Post:
akahenry (02-03-2017), MyNameIsKeh (01-25-2017), Wise (03-01-2017)
Old 01-25-2017, 05:06 PM   #685
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Nice find! I'd have rocked those instead of the OEM Enkei caps, especially for the price!
Old 04-01-2017, 02:55 PM   #686
nyfries
Drives: 14 FRS Whiteout
Dont want to bump up an old thread but how can i find a set of these in silver in the +35mm offset? its literally discontinued everywhere.....
nyfries is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
