Old 08-17-2016, 01:39 AM   #71
Irace86
Drives: BRZ + Ducati M796
No hole
New hole
Taped up
Irace86 is offline   Reply With Quote
Old 08-17-2016, 01:44 AM   #72
Irace86
Assembled
Installed
With chrome accent
Old 08-17-2016, 03:35 AM   #73
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Originally Posted by Irace86 View Post
Assembled
Installed
With chrome accent
Looks good!
kuczynskika is offline   Reply With Quote
Old 08-18-2016, 10:15 AM   #74
Spectre20
Spectre20's Avatar
Drives: 2013 BRZ Limited
Wow, that really came out great!
Spectre20 is offline   Reply With Quote
Old 08-25-2016, 08:02 PM   #75
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Working on my fender. I pulled everything apart and dremeled out the inside. Then I bought some perforated aluminum online. I cut the aluminum to fit and bent it to the mold. Then I cut up an old plastic handle from a tool and sanded it to shape and then epoxied it to the center. After it dried I drilled pilot holes for screws to hold the aluminum to the garnish. I also epoxied one of the clips to the end.
Damn that looks just like the prova one. LOL
Old 08-25-2016, 09:58 PM   #76
Irace86
Yes it does. Except the Prova one is made to fit the fender without cutting and even with mine so formed there would be interference. Im thinking the Prova one was designed to accommodate the perforated aluminum and thus is less tucked into that fender depression.
Old 12-07-2016, 10:38 PM   #77
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
My take on this DIY. Thanks for the awesome write up that made this possible.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 12-08-2016, 08:52 AM   #78
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
That looks good!
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 12-08-2016, 09:34 AM   #79
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
i wish i had the courage to do this. anybody interested in cutting up my trim if i send it to you?
malubawla is offline   Reply With Quote
Old 12-08-2016, 01:04 PM   #80
Bramick
Bramick's Avatar
What about the fender? That has to be cut also...
Old 12-08-2016, 01:18 PM   #81
olsonpg
olsonpg's Avatar
The trim is the easy part. Just tape up everything GOOD so if you slip with your dremel or file you don't mark up the paint. I managed to complete the process scuff free.
Using the dremel to cut the fender requires a little more finesse. But again, use some nice thick tape ( i used gorilla tape ) so if the cutting blade does develop a mind of its own you should still be ok. Although I did ding the paint in one spot with the dremels collar that spins with the blade. I wasn't using tape at that point as it was a touch up cut
Fairly easy modification for the most part.
Old 12-08-2016, 01:59 PM   #82
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
yeah i dont mind to cut the fender, i will be covered by the trim anyways. i need someone with more finesse than me to do my trim pieces.
Old 12-08-2016, 01:59 PM   #83
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
any interest to do the trim? pm if you are a price, thanks.
Old 12-08-2016, 03:29 PM   #84
nisti
nisti's Avatar
Drives: BRZ & XV
How is everyone cutting grill material to line up with the trim piece?
Tin snips?
Some of the pictures look like the grill material really matches the trim lines well...
Wondering how they got the mesh to fit so well.
nisti is offline   Reply With Quote
Want to trade my white Frs fender vents for Brz fender vents White0utFrs Exterior Parts (Aero, Lighting, Etc.) 0 09-23-2013 03:17 AM
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 11:58 AM
Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents DC-FRS Exterior Parts (Aero, Lighting, Etc.) 15 11-01-2012 11:41 PM
