Old 11-17-2016, 03:07 PM   #1779
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by ATL BRZ View Post
Thank you!
My debate with the JRSC ended when the Edelbrock/Harrop SC outperformed it on the dyno and on the track in pretty much every application. Lots more usable torque from a TVS 1320 supercharger than even a big C38 Rotrex.
Any plans when? Or will you keep your subscribers on the edge of their seat? lol..
pgranberg11 is offline   Reply With Quote
The Following 2 Users Say Thank You to pgranberg11 For This Useful Post:
ATL BRZ (11-17-2016), Takumi788 (11-17-2016)
Old 11-17-2016, 03:20 PM   #1780
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The Following User Says Thank You to ATL BRZ For This Useful Post:
pgranberg11 (11-17-2016)
Old 11-17-2016, 03:29 PM   #1781
gramicci101
Off Topic
What about extended track sessions and heat soak of the air-to-water intercooler? Would a larger heat exchanger help? Is it even an issue?
Also, you should check out GSpeed's track rat development thread. They posted some interesting and concerning information about rear diff temps under track conditions. A diff cooler might not be a bad thing to consider.
Old 11-17-2016, 03:38 PM   #1782
ATL BRZ
ATL BRZ's Avatar
I've been following Michele Abbate (SCCA STU racer and 2015 SCCA US Majors Tour Western Conference champion) and a few other Edelbrock SC owners who track their cars and so far the LTR is sufficient given the coolant is mostly distilled water and Amsoil coolant booster. Properly ducting the incoming air straight into and through to the LTR and other heat exchangers is critical as well. Nothing some sheet aluminum and creative cutting with shears can't handle.
I've also seen logs of the intake temps being significantly lower with E85 running on an EForce kit at the track as well. The heat soak will likely become a bigger issue with smaller pulleys than the stock 3.25" pulley that makes ~10psi.
I follow them on here and on Facebook and I'm very confident in my Millers gear oil's ability to put up with temperatures like that, but I do still want that Harrop diff cover to keep more fluid in there and help cool it down.
MaximeT (11-18-2016)
Old 12-02-2016, 11:16 PM   #1783
ATL BRZ
ATL BRZ's Avatar
Removed the stock fuel rail covers
Replaced with Velox units, saving 4 pounds from the top of the engine.
The injectors and HPFP are now exposed and can be easily seen/inspected, which I kinda like.
DocWalt (12-02-2016)
Old 12-06-2016, 01:36 PM   #1784
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Any chance you might throw your BRZ on a dynojet dyno before throwing the Edlebrock on? 205whp on a mustang dyno is VERY impressive... But most dyno's that I could compare it to come off of dynojets which read a good but higher... I'm trying to decide between moto-east flex fuel soon or just waiting a year or two and grabbing an Edlebrock kit myself... So I'm looking for every dyno and review, of both, I can get my hands on.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
The Following User Says Thank You to Keenercarguy For This Useful Post:
ATL BRZ (12-06-2016)
Old 12-06-2016, 09:04 PM   #1785
ATL BRZ
ATL BRZ's Avatar
I don't think there's a Dynojet near me.
Old 12-06-2016, 09:23 PM   #1786
CSG Mike
CSG Mike's Avatar
The physics doesn't make sense; IAT is measured in the manifold, before E85 ever comes into play!
Old 12-06-2016, 09:59 PM   #1787
ATL BRZ
ATL BRZ's Avatar
I know, but it's the only log I've seen that's apples to apples.
@NotSoJDM
Old 12-22-2016, 02:20 PM   #1788
ATL BRZ
ATL BRZ's Avatar
Added TRD style carbon fiber fender fins
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (12-22-2016), SkAsphalt (01-18-2017), supra2nv (01-20-2017), Teseo (12-23-2016), TeutonicShift89 (12-22-2016)
Old 12-22-2016, 02:56 PM   #1789
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
I've been eyeing these too.
Do those replace the fender garnishes or attach on top of them? Seem pretty sturdy after install?
I'd feel tempted to clear tape carbon pieces to keep oxidation at bay for as long as possible
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 12-22-2016, 03:02 PM   #1790
ModBargains.com
ModBargains.com's Avatar
Wow this thing looks like an absolute monster! The mod list looks well-sorted
ModBargains.com is offline   Reply With Quote
The Following User Says Thank You to ModBargains.com For This Useful Post:
ATL BRZ (12-22-2016)
Old 12-22-2016, 03:13 PM   #1791
ATL BRZ
ATL BRZ's Avatar
They attach on top via mounting tape. Yes they've seen triple digit speeds and have stayed secure. They're clear coated finish so hopefully there will be no issues with oxidation.
Old 01-18-2017, 02:01 PM   #1792
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
subscribed!
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
ATL BRZ (01-18-2017)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
