Old 11-30-2016, 05:00 PM   #841
Teseo
Drives: frs
Highest available here is 91. There is a special station that I go to sometimes that has 91 through 100 though. Will try going there soon and getting 94.
Will also try switching to Shell 91 after this tank is done.
Edit: The special gas station is conveniently located after a lot of twisty roads. Should I avoid spirited driving with an adv multiplier this low?
Try to run a tank with higher octane and do some pulls to see what you get.
The Following User Says Thank You to Teseo For This Useful Post:
Strife26 (11-30-2016)
Old 12-05-2016, 08:55 PM   #842
novice
novice's Avatar
Drives: Fr-S 2.0 Release
Hi all, just got one of these in the mail from ft86 speedfactory. The touch screen is not working at all. Tried a stylus and everything. Is it DOA?
novice is offline   Reply With Quote
Old 12-05-2016, 09:26 PM   #843
randomthoughts
Drives: 2014 White BRZ
I have to press pretty hard on my screen. It is not very sensitive like a phone or tablet.
randomthoughts is offline   Reply With Quote
Old 12-05-2016, 09:40 PM   #844
novice
novice's Avatar
I'm afraid if I press any harder it will break the screen. I assume i' pressing hard enough
Old 12-05-2016, 10:50 PM   #845
Teseo
Drives: frs
You have more fingers, try with the others. Mine's also have that quirk if i dont press it with my thumb
Old 12-05-2016, 11:02 PM   #846
novice
novice's Avatar
I tried everything, shouldn't be this difficult it is brand new. Got it today.
Old 12-06-2016, 01:03 PM   #847
Riftur
Riftur's Avatar
My 2013 A/T is completely stock except a drop in K&N filter. I run 93 octane and am looking for a bit more 0-60 speed. Is it possible to safely do with the OFT or do I need to change the diff gears?
Riftur is offline   Reply With Quote
Old 12-06-2016, 01:16 PM   #848
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Change diff gears? You should be fine flashing a base tune and will see a little improvement in power delivery. I am not sure it would improve overall 0-60 speed.
justinco is offline   Reply With Quote
Old 12-06-2016, 01:35 PM   #849
Riftur
Riftur's Avatar
I already use the base stage 1 tune and it actually made the 0-60 slower by .5 secs. The only thing it did was get rid of the torque dip.
Old 12-06-2016, 01:39 PM   #850
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ah, gotcha.
Old 12-06-2016, 05:18 PM   #851
steve99
Drives: FT86
log your wide open throttle AFR and compare to Commanded AFR, it possible its running quite rich, if so you will need to adjust maf scaling
Old 12-07-2016, 07:19 AM   #852
Riftur
Riftur's Avatar
I am a complete novice when it comes to tuning a car. My entire experience tuning a car consists of clicking the button to write the A/T stage 1 93 octane tune. lol If you could provide me with some instructions that would be great. Also I am thinking of mounting the tablet in my car and was wondering if the heat will ruin the tablet. I live in south Florida so it gets pretty hot.
Thanks in advance,
Old 12-07-2016, 12:40 PM   #853
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks in advance,
OFT Data Logging
DATA VIEWING/LOGGING INSTRUCTIONS
First, plug the OFT into your car. Start the engine. Then select DIAGNOSTICS. Then MY CAR. Then SELECT REALTIME DATA DISPLAY. With the engine running, you will see several active data channels (engine speed, throttle, etc,.). You can view up to 14 different channels at a time. To select which 14 channels you want to view, go back to the DIAGNOSTICS menu (LEFT arrow) and select ENABLE DATA CHANNELS. The list of available channels is quite long so you will have to keep scrolling downwards (down arrow) to see them all. To add a channel to the viewing/logging list, just select it by touching the box next to the channel. Once you reach a maximum of 14 selected channels, you will not be able to select any more channels. You can deselect channels as well by touching the box again. Once you have the list of channels you want to view/log, press the RIGHT arrow. Then select REALTIME DATA SCREEN and you will see the desired channels.
To data log (record data to memory), simply press the record (REC) button to the left of the screen. The disk icon will flash when data logging is active. To end the data log, simply press the disk icon again. At this point, you will be asked to name and save the file to memory. To download the data log files from the OFT to your PC, launch OpenFlash Manager and click on Data Logging. Then select Download All Files from OFT. You will then see a list of all the data log files that you have named and saved. Select the desired file and click on Export Selected File (.CSV) at which point you will then name and save the file to your PC. There is a limit to how many files the OFT can store so eventually you will need to delete old files. You can do this by selecting a file and then clicking on Delete Selected File. Or you can delete all the saved files by clicking on Delete All Files.
The Following 2 Users Say Thank You to justinco For This Useful Post:
Riftur (12-07-2016), Teseo (12-08-2016)
Old 12-07-2016, 01:00 PM   #854
Riftur
Riftur's Avatar
OFT Data Logging
Gonna try this out tomorrow. I have the day off. How do I know if it is running to rich or lean? What should I look for? Also thanks for helping me out. Do you think the tablet can withstand the heat if I leave the tablet mounted in the car?
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
