Drives: 2014 Sterling Silver BRZ
CEL P2097
Little backstory. I have Gruppe-S Catless UEL header and overripe, JDL ultra quiet high flow front pipe, and Corsa Cat-back. Also Stage 2 93 OFT tune. Everything was runnin fine with this set up.
A couple months back I added a Perrin inlet tube, and freshly oiled K&N air filter. Around this time I started throwing P219a. It would come and go every tank or two of gas. Checked all seals around airbox and O2 sensor. Everything seemed good. Got some MAF cleaner and that seemed to do the trick. Now I started throwing CEL P2097. My LTFT is 2.34 % at idle to about 6.25% when accelerating.Which I guess seems to be "acceptable" range? Also was under the car about a month ago changing diff and tranny fluid and checked for exhaust leaks. Looks like there may be some near the muffler (coupler loosened up is all) but that shouldn't be the cause of my code. What should I check for next in the diagnosis progress? Thanks in Advance Last edited by Zeuseidon; 11-26-2016 at 10:04 AM. Reason: Forgot Tune info |
#2 |
Drives: Raven FR-S 6M
P2097 is coming from your post cat heated oxygen sensor. The ECU is doing a second check on the oxygen level in the exhaust to adjust LTFT once you are in closed loop. The code is triggered when it detects continuous o2 readings higher than expected. I would check for leaks near or at the sensor also. I would wait and see if the code comes back.
“The World is Flat”
[||•]=(86)=[•||] |
#3 | |
#4 |
Update! There was a leak at the Exhaust gasket to overpipe. Damn bolt was completely missing!
#5 |
Drives: 2013 GBS BRZ Limited
| The Following 3 Users Say Thank You to Mazikowski For This Useful Post: |
| P2097 and P0451 JRSC C30 HBP - EcuTek Tuning | dj2020 | Software Tuning | 5 | 02-09-2016 02:46 AM |
| P2097 | Cryptospook | Issues | Warranty | Recalls / TSB | 7 | 05-18-2015 11:08 AM |
